How to Remove the Exhaust Manifold?? [late BJ8]
crispy
Hi All - I'm a new owner of a late BJ8, and new to the forum. Can someone please post the order of operations for removal of the exhaust manifold. Gaining access to the fasteners, especially the ones on the bottom, has me baffled. I'd appreciate your help.
Thanks Again,
Crispy, 67 BJ8, Portland, OR
British_Recovery
Bronze
As a new owner, you will need a factory shop manual. It will give you step-by-step information on just about everything.
Get one - you won't be sorry.
I have a BJ8, and I haven't removed the exhaust manifold in situ, but I think it's doable (I assume the engine's still in the car?). You'll need to get the car on a lift or at least jackstands; most of the work will be from underneath (be safe). You have to undo the nuts on the studs on the bottom flange to disconnect the down pipes; if your pipes' flexible sections are in good order you shouldn't have to pull the pipes out of the muffler. The nuts are likely brass and should come off fairly easily, but if you have to really torque on them you could snap a stud, which means you're committed to removing the manifold*; I use a ratchet with a couple long extensions and a deep socket. The top nuts on the studs on the head should be accessible, but I don't know about the bottom ones (you should be able to tell when you get under the car). Some of the nuts clamp both the exhaust and intake manifolds; I don't know if it's absolutely necessary to remove the intake manifold, but it would certainly make things easier. The hard part of getting the intake manifold off is getting the carburettors off, esp. the rear as the bottom nuts on studs are hard to get to; some of us have modified wrenches--1/2"--to make the chore a little easier (I use a 'stubby' wrench I got from Harbor Freight).
I don't have my shop manual handy, but I don't recall any instructions for R&Ring the manifolds; it's pretty self-evident what needs to be done.
EDIT: When reinstalling, check the manifold->downpipes and downpipes flanges. The manifold flanges can erode or even warp a little, sometimes making it difficult to get a good seal, and repop downpipes' flanges are sometimes installed erratically (flat-filing may be in order). The repop gaskets are failure-prone--since they can't use asbestos anymore--and I haven't had good luck with the brass nuts; double-nutting with steel nuts and a good anti-seize works for me. Use a high-temp sealant on the gasket for good measure.
* I broke one once with the engine in the car, but was able to get the stud out by MIG-welding a nut onto the remnants of the stud.
CaptRandy
From below use a 1/2"deep well swivel socket on an 18" extension to remove flange nuts. The heat shield will make it almost impossible to remove them without removing the intake. I did drill holes in mine to allow me to loosen and tighten the nut if ever necessary. The Carbs have to come off using a 1/2" stubby open end to remove the heat shield. Use 9/16 socket on the lower exhaust manifolds, you can reach under and feel them to install the socket with a 6" extension. The upper ones are easier to see and remove. I have bought extra open end wrenches at garage sales in the past and used a sawzall to cut them down to 1-2" long-much shorter than stubby wrenches available commercially.
steveg
Or direct from Bentley:
crispy
crispy
Thanks guys, very helpful :smile:. I do have the manual published by Bentley, pictured above. I have a half height lift so hopefully that will make things a bit easier.
So I'm assuming the carbs and the intake manifold have to come off 1st? Can anyone confirm that is true?
If so, then how to i get a wrench on the lower right nut on the rear carb? I don't see an obvious way in. Do I get there from the top, or the bottom?
Really appreciate you help...thankyou.
John Turney
The carbs come off first. That bottom rear nut needs to be reached with a short open end wrench from the top. It's easier if you have the throttle linkage out of the way.
The manifold nuts can also be reached from the top with an open end wrench. You will be working blind, though.
Michael Oritt
Crispy
Having a 100 I can't give you specific advice on your BJ8 but I can suggest that you get a set of 1/4" drive sockets with a few extensions and a universal and also some stubby wrenches. Though it may seem impossible to reach and undo some fasteners this is simply a part of the diabolical scheme to test your mettle. Stick with it and keep us posted.
LarryK
Big secret in working the British cars, contortionism and patience.
steveg
Once you get the air cleaners and carbs off, the rest is easily accessible. Be sure to keep track of which manifold nuts are the tall ones.
Don't worry about taking off both manifolds - you'll need new gaskets anyway. I modified these cheap HF wrenches for carb nuts.
Notching the choke cable brackets makes them easier to remove and reinstall:
John Turney
I tack welded nuts to my choke brackets. that not only makes the brackets easier to R&R, but the nuts too.
crispy
crispy
Just to close out this thread...After grinding down a couple of wrenches, and a busting a knuckle or 2, I'm pleased to report that the exhaust manifolds have successfully been removed. They're off to ceramic coating 1st thing in the AM. My next project is installation of a new SS exhaust system. Any advice you all have is certainly welcome. Thanks to all for your help...and the inadvertent custom tool thread :smile:
Crispy, '67 BJ8, Portland, OR
dougie
Hey Crispy -
I didn't see you were in Portland (Go Blazers) I could have set you up with everything you needed and a lift .......I'm in SW near Lewis & Clark College. My lift is still the available to you if you want PM me.
Rob Glasgow
Crispy, befor you install the SS exhaust system, spend a few moments enjoying how beautiful it looks. If you've bought the Moss Version, it will go together without issue. I don't have experience with other brands, but I will assume they are also great. I don't want to start a kurfuffell but "Go Warriors".
crispy
crispy
I did indeed buy the MOSS SS offering...having no experience w/it, i was a bit dubious. So, i'm relieved and pleased to hear that it is working well for you.
Dougie, great to hear from someone in the hood!! I'm in Raleigh Hills. Let's get together and commiserate sometime soon. I'll reach out once I get her rolling again, and after my vacation...so stay tuned :smile:
B Remove exhaust manifold carbon buildup Spridgets 2
1 Best way to remove this snapped head exhaust stud? MG 13
2wrench Trying to remove nut from exhaust Triumph 14
L remove heat wrap on exhaust? MG 6
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
CARSINC How to remove factory contact cement? Spridgets 9
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
drooartz Bugeye jack points to remove rear axle Spridgets 18
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
drooartz Hose from water pump to head, remove water pump? Spridgets 12
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
tahoe healey Nano Magic scratch remove Austin Healey 2
F I can’t remove Wire wheels from new hubs - help Austin Healey 43
Basil 7 Ways to remove stripped screws Restoration & Tools 2
C How to remove entire dash panel on BN6? Austin Healey 4
hondo402000 TR6 TR6 Windscreen remove and now windows dont fit Triumph 3
edkap2002 TR6 fuel line compression fittings....how to remove Triumph 3
C MGB How do you remove "speed nuts"? MG 9
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
55modified Should I remove driver's side fender to work on footbox on my BN1? Austin Healey 14
R Remove engine/transmission advice needed Austin Healey 4
abarth69 Should I remove this section Spridgets 8
K TR2/3/3A What is best way to remove old nylon/rubber bush 525-020 from steering box shaft? Triumph 5
D TR2/3/3A wooodruff keys... how to remove Triumph 25
B remove BJ8 dash ? Austin Healey 1
Steve1970 TR6 Can I remove the shim on the rear gearbox mount [J-type OD] Triumph 11
4tecdog Access to remove Ariel Austin Healey 15
L Best Polish to remove surface scratches Austin Healey 12
T TR4/4A Does the water pump need to come off to remove the cylinder head? Triumph 5
C TR4/4A Best way to remove transmission fill port? Triumph 8
P How to remove the lever control? Austin Healey 9
Martinld123 Drain Pipe Rear Main Bearing Cap BN2, remove? Austin Healey 2
D BJ 8 How to remove chrome trim strip from door tops Austin Healey 7
S TR2/3/3A remove protective covering off floor pans Triumph 6
bighealeysource Best way to remove dried polishing compound Austin Healey 10
AngliaGT Easiest Way to Remove/Replace Rear Axle Seals/Etc.? Spridgets 9
NutmegCT How to remove old weather stripping Restoration & Tools 8
J TR2/3/3A What is the best way to remove and replace carb shaft bushings. Triumph 4
Got_All_4 General TR How can I remove the finish on this center console for my 7 Triumph 9
B Remove Crank Nut Austin Healey 55
R Can't remove rear flexible brake hose Spridgets 5
C Any tips on how to remove frozen pistons from drum brake Wheel Cylinders??? Austin Healey 11
S TR2/3/3A remove a clutch fork Triumph 1
maxwedge5281 remove 100-6 grill emblem Austin Healey 1
J TR2/3/3A Remove old dash vinyl. Triumph 2
drooartz MGB-GT Any gotchas when remove/replace rear axle? MG 4
Boggsy64 MGB Advice - Remove the seats MG 8
