BJ8 Turn signal help needed.
John O'Brien
Hi Guys and Gals:
I'm new to the forum, and I joined because of the excellent articles in Healey Marque inm Feb. and March by Bill Young showing the Ladder logic diagrams for our Healeys. I have a
'65 A-H BJ8 (Madelyn). My BJ8 is an early Phase 2 model, meaning I have single marker lights front and rear, but I have left and right signal indicators on the dash fascia. I'm having problems sorting a wiring issue. When I turn either left or right signal on, both dash indicator lights flash, and they flash on when the exterior light is off, and off when the exterior lights are on. I have been studying the very excellent articles in Healey Marque, but they don's seem to address this configuration. ideas on how to proceed, or test to find the problem will be appreciated. I was hoping to convert to LEDs but I know I need to have everything working properly before making the changeover. Wiring diagram for my car seems to be shown in the original service manual on page NNN 10
L
ooking forward to collective wisdom.
John O'Brien
RAC68
Hi John,
Welcome to the Forum.
The dash indicators on a BJ8 P2 are not as straight forward as you would expect. Power is supplied from the flasher to both dash directional indicators but the ground is provided by the wiring from the non-selected side rear bulb grounds. The selected side will not have access to a ground and, therefor not be illuminated.
Take a look at the left diagram for my BJ8 P1 as the dash directional power concept is similar to yours but I don't know if your P2 has the flasher relay. Either way, if both dash indicators are illuminating simultaneously, if it because you have a bad ground on either the front or rear directional of the non-selected side. You will be able to determine which as it will be the one that doesn't light or illuminates dimly when that side is selected.
The diagram on the right was how I modified my BJ8P1 when creating a electronic version of my original Flasher Relay.
Enjoy your Healey,
Ray(64BJ8P1)
J
John O'Brien
I think I may have figured out what's going on. I installed a flasher unit from NAPA, that they said was listed for mycar, but what I discovered is that the L tab and the P tab on the flasher energize alternately instead of simultaneously. This means that the off-setting 12 volts that are supposed to keep the non-selected side indicator from illuminating, are instead getting alternating voltage first from one side and then the other. What I actually found was that the dash lights were flashing bright and then dim but still illuminated. I have ordered a correct flasher unit from a trusted British car parts supplier, so I expect/hope that the problem will be fixed when it gets here. I'll keep you posted.
John
Keoke
Ray(64BJ8P1)
Very nice drawings thanks.
John Turney
John
That type of flasher unit is correct for earlier cars.
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
G Correct location of front turn signal on bj8 3000 Austin Healey 3
Patrick67BJ8 1967 Phase-2 BJ8 - Front parking & turn signal lights alignment Austin Healey 8
M BJ8 turn signal switch Austin Healey 3
ooman Looking for dash turn signal indicator - '67 BJ8 Austin Healey 10
L 67 BJ8 Turn signal indicators Austin Healey 5
G BJ8 Phase II conversion to LED turn signals Austin Healey 11
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
Patrick67BJ8 BJ8 Factory Hardtop Rear Window Austin Healey 6
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
AUSMHLY BJ8 Clutch Pressure Plate Brand Preferences Austin Healey 3
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
AUSMHLY BJ8 Overdrive Oil Passages Austin Healey 2
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
C For Sale BJ8 original dash Austin Healey Classifieds 3
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
B BJ8 Centre Console Chrome Strips Austin Healey 5
B Wanted Chrome strips centre console BJ8 Austin Healey Classifieds 0
