Results 1 to 5 of 5
Thread: banjo bolts to seal up on the early SUs
  1. #1
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,096
    Thanks Thanks Given
    Thanks Thanks Received
    17
    Thanked in
    I am having trouble getting those banjo bolts to seal up on the early SUs. Are those little gaskets made poorly or any suggestions would help. They are pretty straight forward, but I cannot get them to seal.
    steve
  2. #2
    Great Pumpkin NutmegCT's Avatar
    Join Date
    Jul 2004
    Location
    Connecticut USA
    Posts
    10,756
    Blog Entries
    1
    Thanks Thanks Given
    37
    79
    Thanked in
    Re: banjo bolts to seal up on the early SUs
    Steve - I had exactly that problem on my MG. I finally got some seals directly from Joe Curto, which fixed the problem.
    https://joecurto.com/products-we-supply
    Tom M.
    Mac & Phyllis Take a Trip: http://nutmegflyer.com/trip-details-daily-updates/
    History: 1976 MGB, 1959 Triumph TR3A, 1960 Mercedes-Benz 190b, 1958 Rambler American.
    Current: 1953 MG TD27318.
  3. #3
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,096
    Thanks Thanks Given
    17
    Thanked in
    I always forget about him, but yeh I bet it is those seals. I hate to tighten them up like that and they are still leaking. Glad to hear there is another solution because something was going break. I thought about maybe block sanding the one surface, but they are new and should seal up easy.
    steve
  4. #4
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    18,977
    Thanks Thanks Given
    4
    71
    Thanked in
    Might be worth checking that they are thick enough. Try assembling just finger tight, without the fiber washers, and measure how much clearance there is. If two washers don't stack up thicker than that, use 3 of them.
    Randall
  5. #5
    Join Date
    Apr 2012
    Location
    Raleigh, NC, USA
    Posts
    597
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    I got some gasket material from Advance Auto parts and cut it in the shape of the fiber gasket and put one on each side of the fiber gasket along with some Hylomar sealant and that helped seal it up.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
