TR5/TR250 High oil pressure
dlentlerjr
I recently installed a spin on oil adapter to my tr250. The oil pressure is now very high, indicating between 80 - 90 psi. I also replaced the pressure switch. Could the adapter be creating a blockage of some kind?
Gliderman8
The pressure will of course come down some as the engine heats up. What was the pressure before installing the spin-on adapter? Personally, I don’t think your pressure is to high. Lets see what others have to say.
trrdster2000
Not all that worrisome on start up. Carry on until that is the pressure on hot.
The new filters may have different restrictions, but do keep and eye on it. 50/60 on a rebuilt motor at hot is fine and nice to see 20 or more at idle.
Let us know.
Got_All_4
My 250 has a spin on filter and is high at startup like yours but comes down to 50/60 and 30+ at idle at full temp. I do have a higher volume pump too then stock and run racing oil so all that adds up to higher pressure. Did always bother me too but well over 20k on engine. My worries have subsided.
TomMull
Let us know.
+1
Tom
G High Oil Pressure Austin Healey 2
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
Simmo TR2/3/3A High Oil pressure Triumph 11
B TR6 TR6 High Oil Pressure Triumph 20
A New to site. High Oil Pressure Austin Healey 18
SMGoose High oil pressure and this puddle... Triumph 77
6 100M high oil pressure Austin Healey 7
Lynn Kirkpatrick MGB MGB High Oil Pressure MG 6
Dadandson New Motor Start up with Xtremely High oil pressure Spridgets 5
newmexTR3 TR2/3/3A Oil pressure running high - TR3 Triumph 6
M Oil Gauge reading high pressure MG 3
J Oil Pressure Too High Spridgets 3
Ed_K Can oil pressure too high damage something ? Austin Healey 4
M BJ8 oil pressure too high? Austin Healey 1
C 100-4 High Oil Pressure Austin Healey 3
Andy Blackley High Oil Pressure: Too much of a good thing? Triumph 11
J Oil Pressure Too High? Austin Healey 2
Slider748 TR6 High oil pressure in TR6 Triumph 17
re26 HIGH OIL PRESSURE? MG 3
F Oil leak? High Idle? Spridgets 13
O High ZDDP oil Austin Healey 0
jerrybny High milage Oil opinions Triumph 5
Carlbanan56 MGB High rpm problem MG 27
P TR2/3/3A British High Torque starter Triumph 6
MikeAH100M High Temp Engine Miss Austin Healey 2
Carlbanan56 MGB High resistance MG 2
Gatheringtree TR2/3/3A Faltering at high RPM and under load demand Triumph 34
S TR2/3/3A floundering At High RPM Triumph 29
M High-Torque Starter Austin Healey 10
Martinld123 High-Torque Starter Austin Healey 4
B TR4/4A High Torque Starter Wiring Triumph 9
LAW75 High-Pitched Noise Austin Healey 13
Hamish Racing General Tech Petrol/Gas with high ethanol Triumph 3
Taftster MGB Electric Gauges Read High, Any guesses? MG 5
B High-Torque Starter Rattling Noise Austin Healey 3
M 1275 too high? Spridgets 2
dougie Targa High Country 2021 Austin Healey 2
K TR2/3/3A High beams seem to be stuck on when the headlights are turned on? Triumph 3
J Experience with High Ratio Steering Box? Austin Healey 15
R Speedo High Beam Warning Light Color Austin Healey 14
Lin Gear Reduction High-Torque Starters: Inertia or Pre-engaged? Austin Healey 4
M TR6 High Compression in One Cylinder Triumph 28
AUSMHLY 64 front end too high Austin Healey 14
steveg High altitude mixture observations Austin Healey 4
R General Tech High altitude adjustments Triumph 3
R High Altitude adjustments Austin Healey 3
B TR6 1970 High Back Seats for TR6 - Side bolste wires squabs neededr Triumph 3
bfitz TR6 72 TR6 clutch high engagement point Triumph 16
A MGA High beam indicator light not working MG 2
D TR2/3/3A Alternator dial runs high Triumph 5
