Results 1 to 6 of 6
Thread: Rotisserie question?
Discuss the Austin Healey Sprite and the MG Midget. Two different but similar cars sometimes referred to collectively as the Spridget.
  1. #1
    Obi Wan Bayless's Avatar
    Join Date
    Mar 2007
    Location
    Oklahoma City
    Posts
    2,341
    Thanks Thanks Given
    Thanks Thanks Received
    6
    Thanked in
    For anyone who has built one, can you please estimate where the center of gravity is on a bare '67 Sprite tub? The only things still attached are the doors and boot lid and I can remove them too. In fact that would save a little weight.
    Never express yourself more clearly than you can think.
    '48 Ford Prefect
    '67 Sprite (project)
    '74 Super Beetle
    '73 MB 450SE
    '04 Saab Arc
    http://enfoprefect.org
  2. #2
    Join Date
    Feb 2019
    Location
    Bellefonte, PA
    Posts
    13
    Thanks Thanks Given
    Thanked in
    Re: Rotisserie question?
    Haven't built one (yet) but as I understand it, it's supposed to be right around the center of the trans tunnel arch. Keep in mind also that stripped down there isn't a lot of weight so the CG isn't terribly critical. I thing this may be one of those situations where close enough is good enough. The pictures I have looked at vary a little up or down and nobody seems to have a problem one way or the other. Also, as you add things back on it will change minimally. Just my 2 cents worth.
  3. #3
    Jedi Warrior BlueMax's Avatar
    Join Date
    Dec 2010
    Location
    Easley, South Carolina
    Posts
    708
    Thanks Thanks Given
    Thanked in
    If your seeking centerline of rotation for building your rotisserie? Here's a photo of mine which I aimed for the center of deferential.
  4. #4
    Great Pumpkin JPSmit's Avatar
    Join Date
    Nov 2004
    Location
    Toronto, ON
    Posts
    18,121
    Thanks Thanks Given
    42
    Thanked in
    From memory, Top of the transmission tunnel seems about right. The shell is only about 350 lbs so, exact centering is not crucial.
    John-Peter Smit
    1976 MG Midget
    1969 Vauxhall Viva GT
    1958 Fiat Multipla (Barn art)
  5. #5
    Join Date
    Mar 2007
    Location
    Oklahoma City
    Posts
    2,341
    Thanks Thanks Given
    6
    Thanked in
    Thank you gentlemen. That's about where we were estimating. Hope to get it done today and post pics. Also comforting to hear it isn't too critical.
    '48 Ford Prefect
    '74 Super Beetle
    '73 MB 450SE
    '04 Saab Arc
  6. #6
    Join Date
    Mar 2018
    Location
    NSW, Australia
    Posts
    5
    Thanks Thanks Given
    Thanked in
    Whilst not critical is far easier to rotate with just one person if you get it right. I did mine and it needed two people to control rolling it over and also a chain to secure in position. That said I was a fair way off as I used the rear spring mounts for attachment.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
