Rotisserie question?
Bayless
For anyone who has built one, can you please estimate where the center of gravity is on a bare '67 Sprite tub? The only things still attached are the doors and boot lid and I can remove them too. In fact that would save a little weight.
Stan Kowznofski
Haven't built one (yet) but as I understand it, it's supposed to be right around the center of the trans tunnel arch. Keep in mind also that stripped down there isn't a lot of weight so the CG isn't terribly critical. I thing this may be one of those situations where close enough is good enough. The pictures I have looked at vary a little up or down and nobody seems to have a problem one way or the other. Also, as you add things back on it will change minimally. Just my 2 cents worth.
BlueMax
If your seeking centerline of rotation for building your rotisserie? Here's a photo of mine which I aimed for the center of deferential.
JPSmit
From memory, Top of the transmission tunnel seems about right. The shell is only about 350 lbs so, exact centering is not crucial.
Bayless
Bayless
Thank you gentlemen. That's about where we were estimating. Hope to get it done today and post pics. Also comforting to hear it isn't too critical.
Mk3Sprite
Whilst not critical is far easier to rotate with just one person if you get it right. I did mine and it needed two people to control rolling it over and also a chain to secure in position. That said I was a fair way off as I used the rear spring mounts for attachment.
B Rotisserie question Spridgets 4
timbn2 BN-2 on a rotisserie - mounting points question?? Austin Healey 5
M Mounting BJ8 Chassis on Rotisserie Austin Healey 8
Bayless The very simple rotisserie Spridgets 3
J pictures of a 3000 on a rotisserie ?? Austin Healey 5
I Chassis rotisserie..? Austin Healey 10
A Engine stand rotisserie plans Austin Healey 12
Jim_Gruber Rotisserie Pics and Lessons Learned Spridgets 1
T Healey rotisserie Austin Healey 12
J Best Rotisserie to work with Triumph 0
R I Need Rotisserie plans for midget Spridgets 18
J Rotisserie or Not? Spridgets 28
luke44 TR2/3/3A TR3 rotisserie or body buck questions Triumph 24
A Rotisserie set up? Spridgets 17
S bj8 rotisserie Austin Healey 4
Gray_Cat Engine Stand Rotisserie Spridgets 4
PAUL161 Found a Rotisserie at a Good Price. Restoration & Tools 1
motofiaccone Rotisserie or Build Table Spridgets 12
John Moore Rotisserie Spridgets 22
M Restoration on a Rotisserie Triumph 15
jackq Rotisserie Restoration & Tools 22
SHG Some Thoughts on Rotisserie Restorations Austin Healey 49
JPSmit Home Made Rotisserie - I'm sooooo Happy Spridgets 15
S TR2/3/3A rotisserie on a tr3 Triumph 7
B Poor Mans Rotisserie Spridgets 3
mcguijo Auto Rotisserie Restoration & Tools 10
D TR6 Rotisserie for a TR6 restoration project Triumph 12
B Rotisserie for E Type Roadster Jaguar 7
DonC1948 TR6 A "CLASSIC" question. Triumph 6
71TR6 TR2/3/3A A TR3A wiring question Triumph 17
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
K TR2/3/3A Brand new brake caliper question... Triumph 8
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
R TR6 question re: Engine Oil Triumph 3
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
