TR4/4A A type OD working in 3rd but not in 4th
TRclassic3
This seems like a bit of an odd problem. A little history: After OD and transmission rebuilt an installed, a test drive gave sporadic results. Initially seemed fine but began dropping out of OD or not engaging at all. After a bit of analysis it was determined that the new switch was the culprit as it would not consistently work when testing. A new switch work every time. Feeling confident the problem was solved the interior was reinstalled. Test drove today. Again initially seemed fine, but then started acting up in 4th. Oddly, no problem was experienced in 3rd, but rather only in 4th. If in OD and going from 3rd to 4th it would drop out of OD. If not in OD and in 4th OD would not engage. Upon return I tested to see if I could hear the solenoid in both 3rd and 4th (car had sat for maybe 10 minutes). I could hear it actuate every time regardless of gear. Any thoughts? could it be a wiring issue with the isolator switch that only raises its ugly head with car in motion?
Thanks
Sarastro
It really sounds like a lockout switch to me, probably right on the edge of working. There are shims under the lockout switches, which adjust the protrusion of the switch actuator into the shifter assembly. If they are not right, the OD may not work or may just work sporadically.
TR3driver
Great Pumpkin - R.I.P
FWIW, I had exactly the same symptoms from a failing lockout switch. Initially, it would just sometimes fail to go into OD and I could usually get it to work by shifting to neutral and back to 4th. Sometimes, just wiggling the shift lever fore and aft a little would get it to make contact.
Connecting a test light to the relay (so it could be seen while driving) confirmed that the lockout switch (or the wiring to it) was the problem. This switch had been working correctly for a very long time, so I'm inclined to believe it was just wear that made it fail. Anyway, replacing the switch (and adjusting the shim pack for the new switch) solved the problem.
But it's also possible for the relay or OD solenoid to go intermittent. A bad solenoid will often work OK when the car isn't moving, because it doesn't have to work against as much hydraulic pressure. Relays seem to be more temperature sensitive (ie they get hot in operation and quit making good contact).
FWIW, adding a kickback diode to the relay seemed to really improve the life of replacements. I went through 3 different replacements in just a couple of years (including a fairly expensive reproduction of the original) before adding the diode. With the diode, my "Made in China" brand relay has held up fine for some 20 years.
I wanted to do the same thing to the new solenoid, but realized later that I didn't wire it correctly. It seems to be working OK without the diode, though :smile:
PS, I don't mean to suggest those are the only possibilities, just the ones that have given me the most grief.
JerryVV
I had a similar issue which was finally traced to a loose ground wire that attached to the transmission top cover. It was frustrating in that it didn't always drop out of OD.
HAWAIICJ
Just as a curiosity has any one measured the height dimension of the machined OD switch mounting (through the threaded hole) to the neutral surface of the shift forks? I understand this can be adjusted with the fiber washers, I am looking for a measurement for the installed height with out washers so that I may modify my shifter housing in preparation for installing my A-type.
TR3driver
Sorry, my mistake. He just matched the height of the hole for the reverse switch.
J General TR D Type overdrive not working need suggestions Triumph 5
H MK2 lover, but... what about an E type? Jaguar 5
D TR2/3/3A layout for lap type seat belt Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
71TR6 TR6 Type-J Overdrive identification Triumph 4
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
Editor_Reid V-12 E-Type Body Number Location Jaguar 3
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
K TR2/3/3A The Amco chrome tube type grille ....... Triumph 9
T TR2/3/3A A type overdrive hard engagement Triumph 36
S TR2/3/3A Wedge type and Dzus type side- curtains Triumph 1
R TR6 J-Type overdrive will not disengage when warm Triumph 8
6 E-Type brake light pressure switch location Jaguar 5
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
M General Tech J Type OD Stuck in OD - Fixed Triumph 2
ROARRR Is there any problem swopping in a 3.0 in place of the 2.5 L engine in my Jag X Type? Jaguar 0
M General TR Source for J Type O/D Solenoid Circlip Triumph 0
M Wanted Wanted: Inoperative J Type OD Solenoid! Triumph Classifieds 2
V vintage glue type for veneer? Sunbeam (Rootes) 13
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
Basil Remember the Royal Electric E-Type Electric Upgrades of All Sizes 0
S TR2/3/3A lifter type Triumph 3
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
M TR6 1973 TR6 Coolant Type? Triumph 5
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
S TR2/3/3A 187 NOS sleeved type thermostat Triumph 16
Basil The new Kia E-Type? Jaguar 6
H TR4/4A A-type overdrive pump Triumph 4
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
P Wanted E type spare tire bracket Jaguar Classifieds 2
P Wanted 62 E Type spare tire bracket Other British Classifieds 1
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
I GT6 A type OD vs D type - engagement speed? Triumph 3
J For Sale Jaguar E Type and MK2 spares Jaguar Classifieds 0
VooDooDaddy63 Basic E-Type Question: Fasteners - Metric or SAE or ...? Jaguar 15
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
S For Sale Lotus Elan Factory Workshop Manual on CD/ROM - Type 26 - 1963 - 1965 Other British Classifieds 1
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
K TR4/4A TR4 Fuel Gauge'"light bulb socket" type? Triumph 11
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
AH67 Heat Shield finish 66 Type Jaguar 5
AUSMHLY Grease type for zerk fittings Austin Healey 7
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
