Post-War Other Herald [or Spitfire] fuel pipe
TomMull
I'm replacing the fuel line on my Herald. I've done the tank to the pump and now working on the line from the pump to the carburetors (it has 2 HS4 SU carbs). I know that there were several routings on the Spits but I think the HS4 set up was basically the same as mine. The pipe goes from the pump along the left side of the engine, behind the distributor and generator and around the front to the forward carburetor.
I think this is correct but it appears that someone added a plastic in line filter and perhaps moved the pipe forward of the thermostat housing. It looks to me like it might be better to run it behind the housing and forward of the rocker cover and put the filter somewhere else.
Anyone know?
Sorry no picture as I've removed the line already.
Tom
Andrew Mace
Your car is, of course, a bit of an anomaly, having been assembled in Belgium...and then surviving another 50 years! The typical Mk3 Spitfire of the period would have had a fuel filter just before the fuel pump, which makes far more sense to me than trying to find a good spot for same anywhere between fuel pump and carbs.
As it happens, I have this photo of your car as it appeared in 1999 in Portland Maine. It appears to show the fuel line indeed running in front of the thermostat housing. That seems right to me. Of course, the photo also shows the ignition coil mounted to the metal engine valence, which does NOT seem right to me in terms of where coils usually were located on Heralds and Spitfires. There are a few other "nonoriginal" details in that photo, such as the "straight" upper radiator hose, but considering that the car was already 30 years old in that photo.... :D
Finally, that photo also happens to show a much younger yours truly, checkbook in pocket (alas, said checkbook was not sufficiently "loaded" then to obtain the car and still likely runs short of such funds :wink-new: )! underhood.jpg
TomMull
TomMull
Thanks for the reply Andy. I tried to blow up your picture since it looks to me like the pipe might pass behind the stat housing. It loops forward a bit and then back around. The generator tensioning strap on my car does have a clip on it that holds the temp wire and maybe held the pipe too at one time.
A google search showed most coils mounted on the firewall shelf. I'll see if I can find some holes.
I'll get a proper hose too.
Here's a blow up of your picture and also an old one I found of the improvised filter on the Herald (Note the unclipped wire tie that holds the fuel line away from the fan).
Tom
TomMull
TomMull
T General TR Spitfire/ Herald Suspension & Steering Triumph 13
ArcticOne Post-War Other Herald and Spitfire at Auction Triumph 5
Michael Oritt Post-War Other Triumph Herald/Spitfire steering rack Triumph 7
TR_Jim Post-War Other Safety Tip for Spitfire, GT6 and Herald Owners Triumph 9
T Post-War Other Herald to spitfire conversion parts Triumph 2
bcliff Post-War Other Need Spitfire/Herald info Triumph 2
L For Sale 1961 Triumph Herald Saloon Triumph Classifieds 0
P Post-War Other Herald Windshield: Is it the same as.... Triumph 2
P Spitfire Going up-Engine with my Herald Triumph 6
P Post-War Other Triumph Herald Engine ID Triumph 2
TomMull Wanted Herald Hood Frame Triumph Classifieds 9
7 For Sale Stainless trim for Herald Convertible top. Triumph Classifieds 0
B 1965 herald convertible Triumph Classifieds 1
TomMull Free Triumph Herald Headboard Triumph Classifieds 0
M For Sale 1965 Herald Convertible 1200 Triumph Classifieds 1
M For Sale 1965 Herald Convertible 1200 Triumph Classifieds 0
AngliaGT General TR Triumph Herald Being Parted Out [craigslist] Triumph 0
TomMull Wanted Triumph Herald Hood Finishers Triumph Classifieds 3
TomMull Post-War Other HERALD Simple Task turns into another project. Triumph 11
S For Sale Triumph Herald 1200 saloon and coupe spare parts catalog Triumph Classifieds 0
LarryK General TR 1962 Herald Convertible Triumph 10
dklawson Spitfire Bleeding Herald Brakes [similar to Spit] Triumph 9
J TR4/4A Fuel Injected Herald Triumph 1
T Wanted Herald frame Triumph Classifieds 2
bash Post-War Other Herald for racing Triumph 5
H Wanted Herald Parts Triumph Classifieds 15
H Wanted Herald headlamp Chrome Rim retaining ring Triumph Classifieds 0
H Wanted Braket that connects the boot lid to the boot lid stay strut on a Herald. Triumph Classifieds 0
P Triumph Herald Spotted 0
H Post-War Other Herald rear suspension lower block installation Triumph 3
T Post-War Other The Herald front vent windows Triumph 5
T Post-War Other The Herald front vent woindows Triumph 0
TomMull Post-War Other Herald 13/60: I didn't get the battery tray quite right Triumph 4
TomMull TR2/3/3A Herald has a friend, TS58023 Triumph 5
TomMull Post-War Other Herald: Holy Moly! [Why it took me so long to make the accelerator bracket] Triumph 2
TomMull Post-War Other Herald carpets and throttle issues Triumph 4
M Post-War Other herald 13/60 light switch Triumph 2
TomMull Post-War Other Herald Carpets, issues, and minutia Triumph 4
T General Tech Hattie the Herald, again and again. Triumph 6
TomMull Post-War Other Herald seat track mount Triumph 5
T Post-War Other Hattie the Herald, again. Triumph 3
T Post-War Other Herald flywheel Triumph 3
T Post-War Other Hattie the Herald, again. Triumph 5
TomMull Post-War Other Herald shift lever Triumph 3
AN5Sprite Post-War Other What's a '64 Herald Worth? Triumph 6
TomMull Post-War Other Herald starter Triumph 7
T Post-War Other Herald heater Triumph 2
PatGalvin General TR 64 Herald on Craigs List Triumph 5
7 Post-War Other Sold the Herald - surprising amount of interest Triumph 3
