Windshield and Wheeler Dealers
JPSmit
Sitting just now and watching Wheeler Dealers. They are doing a 1973 Saab 9-6. The windshield was cracked so they went to a guy - (This in California BTW) - with a massive auto glass warehouse. They literally walked around with the glass until they found a windshield with the same profile (Impala) and then, in the shop cut it down to fit with a glass cutter, a propane torch and some flammable liquid. It was absolutely amazing.
Boink
Bronze
I saw that one too. Didn't know you could do that!
dklawson
I was wondering how they knew that the compound curvature was a good match to what the SAAB needed. I'd like to think the guy has a database that helps with such things... but maybe it's all in his memory.
JPSmit
JPSmit
If it is in his head I hope someone coddleshim for the rest of his hopefully long life!
what I was thinking too!
I have seen/ read stories of people chopping their hot rods - and hence their windshields. Much to do with string and fire and buying extra windshields - this seemed quite easy (assuming of course you knew what you were doing and what fit.
In terms of the knowledge, I can't imagine it would be terribly difficult to create such a data base - I suspect manufacturers already have it - though not necessarily in usable form.
pdplot
Why are those shops always in California or England? I don't know if CT even has any machine shops left that could work on an engine. There seem to be a few fancy high-priced places catering to the 1% and that's about it. Are there shops in your area that could do line boring, head shaving and all the other engine work that you see on TV?
JPSmit
JPSmit
I think so, There are a couple of engine shops (I have used 3, 2 locally - mind you Toronto is a big place) I have not had them do anything but boil the block and measure since I like to rebuild myself. I will say there is a local carb shop - I haven't used them but I think it is carlos and Carlos - both getting long in the tooth with no one to take over, and, I know of one machine shop that just closed - the owner was both tired of the hassles and of being stiffed.
waltesefalcon
I can think of two that can. We have a fairly robust Sprint car culture around here and the local shops will cater to their needs.
glemon
There used to be probably a dozen or more machine shops around here. Now there are two that I know of. The last two I worked with are both gone, and too bad, nice guys to work with and reasonable. I don't think newer stuff is rebuilt much anymore, it is more often a sensor or electrical issue. The last guy I used said he mostly re-did warped aluminum heads and not too much else on modern stuff.
I saw that Wheeler Dealer's too, the windshield guy just seemed to have an eye for the curve. Pretty amazing, both the picking out and the carving it to shape.
John Turney
We have a really good machine shop not too far away. About 20 years ago, I had him do my Austin 3000 engine. When he was done, he said he would never do another one. A couple of years ago, one of our club members went to him to ask if he would do his Austin 3000 engine and he said "No."
JPSmit
JPSmit
Not windshields but, British Car TV (which is Mostly Waaaay better than North American Car TV) - one show I kind of like is the Motorcycle Show, while on holiday, they were restoring (I think) a Triumph something or another.
More to the point they sent the speedometer away to be rebuilt and the rebuilder used a strap wrench to remove the bezel holding the glass in place.
Top Tip thinks I
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
D TR2/3/3A Windshield glass doesn't fit Triumph 6
P Post-War Other Herald Windshield: Is it the same as.... Triumph 2
D TR2/3/3A Windshield assembly question Triumph 6
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
T TR2/3/3A TR3A Windshield Question Triumph 4
Popeye General TR Old imperfect windshield - keep it toss? Triumph 3
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
P Austin A40 Devon windshield. British Motor Corp 2
K TR2/3/3A The Harley Davidson side mirror that mounts to the TR3 windshield stanchion? Triumph 11
R TR2/3/3A Windshield Wiper System Triumph 2
P Cracked windshield Other Cars 0
B TR4/4A Windshield Capping Strip Triumph 5
D TR2/3/3A Windshield frame fitting. Triumph 2
M TR6 Windshield Trim TR6 Triumph 14
Sopwith_Camel mk2 windshield wiper nozzles Jaguar 4
Michael Oritt 100 Windshield seal Austin Healey 0
S Bugeye Windshield Seal Austin Healey 1
BoyRacer Windshield Wiper Wheelbox Austin Healey 4
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
B Windshield glass, where to buy Restoration & Tools 4
S TR2/3/3A Cutting the finish end on the windshield top rubber Triumph 4
C MGB 1966 MGB windshield glass MG 4
M General MG Midget MK1 windshield replacement MG 2
B MGA Windshield glass MG 11
R TR2/3/3A Fitting windshield Triumph 3
steveg Rebuilding roadster windshield Austin Healey 24
B TR2/3/3A Windshield Wiper mount rubber Triumph 3
Z TR2/3/3A Windshield Aftermarket Triumph 22
B Longbridge 100-6 Windshield Posts - Body Color or Silver? Austin Healey 16
D TR2/3/3A Windshield difficulties Triumph 24
Rut Cut down windshield Spridgets 22
R Windshield Washer Pump Repair Austin Healey 9
M BJ8 Windshield Austin Healey 10
G For Sale Morgan Folding Windshield Posts, Original 1960s-70s “Small Quadrant” Style, $600 Other British Classifieds 0
A TR2/3/3A Need Helping finding windshield bracket! Triumph 5
Rut Windshield rubber seal Spridgets 6
C Removal of windshield posts from my 100-6 Austin Healey 7
Rut Wanted Bugeye, mk2, Midget mk1 windshield frame Spridgets Classified 1
BoyRacer windshield wiper motor rubber mounting grommets Austin Healey 9
P Rivets on windshield and vent window frame. Austin Healey 1
DrEntropy E-Type windshield FYI: Jaguar 1
R TR2/3/3A Putting windshield back together Triumph 13
D TR5/TR250 Windshield wiper motor Triumph 9
TR3TR6 TR6 Triumph TR6 Windshield seal on ragtop Triumph 6
Joe Schlosser BE windshield screws Spridgets 4
M Wanted Windshield 1959 tr3a Triumph Classifieds 3
