Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
Thread: New Tires or Keep Old Ones
  1. #21
    Join Date
    Oct 2009
    Location
    Arizona
    Posts
    20
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Re: New Tires or Keep Old Ones
    Currently have Michelin 165 SR 15's on my BN2, and do not think they are steel belted. Is there a steel belted type for these? They seem like a safer design.
  2. #22
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    4,159
    Thanks Thanks Given
    5
    57
    Thanked in
    Are you sure the Michelin's aren't steel belted? I think pretty much every tire made in the last 30 years or more are steel belted. Anyway, I did a lot of looking for tires for my BN2; I think I found a few that were outrageously priced but settled for Nexens from Walmart for about $40 ea. and they're fine for casual use.
    EDIT: Just saw this on another forum:
    https://www.ahexp.com/forum/the-3000...r-real.211131/
  3. #23
    Luke Skywalker dougie's Avatar
    Join Date
    May 2008
    Location
    Portland, Oregon
    Posts
    1,591
    Blog Entries
    1
    Thanks Thanks Given
    30
    Thanked in
    Quote Originally Posted by Michael Oritt View Post
    Neither: Toss them all and get five--not four--new ones.
    Ditto - New tires if you drive over 45 mph and further then 25 miles from home.
    Dougie
    '65 BJ8 3000 MKIII GN.29
    '57 100-SIX MM Vintage Racer GN.1 #414
    Team Healey PDX
  4. #24
    Yoda steveg's Avatar
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,975
    Thanks Thanks Given
    114
    171
    Thanked in
    Longstone also sells the 165SR15 XZX as well for $129.60 w free shipping.
    Steve Gerow
    Altadena, CA, USA
    Maker of most complete Big Healey rear disc kit
    Check out my galleries:
    http://www.pbase.com/stevegerow
  5. #25
    Yoda Michael Oritt's Avatar
    Join Date
    Jun 2001
    Location
    Lusby, MD, USA
    Posts
    3,359
    Thanks Thanks Given
    9
    29
    Thanked in
    Before I got the present set of XAS 180's I had XzX 175's. They were good tires but the XAS's seem better in the wet and have a great road feel.
    I believe the XzX's are still only available in 165 size and for several reasons I am a fan of as big a tire as will fit.
    Best--Michael Oritt
    1954 Austin-Healey 100 Le Mans
    1959 Elva MK IV Sports Racer
    1961 Ginetta G4
  6. #26
    Jedi Hopeful CessnaTPA's Avatar
    Join Date
    Apr 2015
    Location
    Tampa, Florida
    Posts
    129
    Thanks Thanks Given
    Thanked in
    I received the tires yesterday and got them installed. It was actually much easier than i thought it would be. I have always changed my motorcycle tires and usually have to curse and fight them on, not so with these tires.
    I used a bead breaker from Harbor Freight, tire irons/spoons, tire mounting lube & paste and used a tire balancer from Harbor Freight.
    Was it worth the $100 I saved doing it myself? Probably not but I have never changed a car tire and like the challenge and satisfaction of doing it. Hopefully I won't have to mess with them again for a long time and change them because of mileage not time next time.
    1957 Austin Healey 100-6 BN4
  7. #27
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    4,159
    Thanks Thanks Given
    5
    57
    Thanked in
    Nice work. Did you put talc on the tubes?
  8. #28
    Jedi Warrior Bob McElwee's Avatar
    Join Date
    Dec 2001
    Location
    Kirkwood, MO
    Posts
    542
    Thanks Thanks Given
    24
    6
    Thanked in
    and remove any stickers on the inside of the tires.
    Bob McElwee
    '62 AH Tri-Carb(sold)
    Miss BT
  9. #29
    Join Date
    Apr 2015
    Location
    Tampa, Florida
    Posts
    129
    Thanks Thanks Given
    Thanked in
    Quote Originally Posted by Bob_Spidell View Post
    Yes I used powder on the tubes and used rim protectors while using the tire irons. My father in law owned a tire shop and recommend after inflating deflate it again so everything adjusts in place properly.
  10. #30
    Join Date
    May 2004
    Location
    Dove Canyon, CA
    Posts
    396
    Thanks Thanks Given
    3
    7
    Thanked in
    Thanks for sharing your experience with the tire and tube change-out. Glad everything worked out for you and the solution was somewhat inexpensive.
    I'm curious about the DIY approach and been tempted to purchase HF's aluminum tire levers just in case. Was any modification needed for the wheel balancer to work on center lock hubs? Any tips you would like to share? GONZO
  11. #31
    Yoda tahoe healey's Avatar
    Join Date
    Aug 2002
    Location
    South Lake Tahoe, CA
    Posts
    3,539
    Thanks Thanks Given
    3
    Thanked in
    Some tricks I found with the HF wheel (bubble) balancing and HF tire unit. Because the wire wheel won't center, I put a PVC pipe end cap in the hub to take up the space and center the wheel. On the tire remover, I mounted an old wire wheel hub that I had to hold the wheel as the "pins" are made to fit the lug holes. Watch for sales or 20% off coupons. This works well for me as I tend to break spokes often.
    What is used to protect the rim?
  12. #32
    Join Date
    Dec 2002
    Location
    West Chester, Ohio
    Posts
    377
    Thanks Thanks Given
    1
    2
    Thanked in
    I slide old bicycle tubes over the tire irons to protect the rims. Never a scratch or marred spot.
    John Kuzman
    West Chester, OH & Bonita Springs, FL
    1959 Bugeye, 1275 w/5 speed; 1960 Bugeye Project
    1963 BJ7; 1969 Corvette; 1972 Spitfire; 1980 El Camino
  13. #33
    Join Date
    Aug 2002
    Location
    Posts
    3,539
    Thanks Thanks Given
    3
    Thanked in
    I like that inner tube idea. I used plastic that moved all over the place and gave up.
  14. #34
    Join Date
    Apr 2019
    Location
    Oak View CA
    Posts
    5
    Thanks Thanks Given
    Thanked in
    I have had over 100 cars & trucks and many of them very old. My personal opinion is the tire companies want you to replace tires as often as possible. I am still using some tires 30 or 40 years old without a problem, but I don't go very fast on crowded freeways with them. I know most of you will not agree with this.
  15. #35
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    4,159
    Thanks Thanks Given
    5
    57
    Thanked in
    Ask your insurance company if they 'agree with this.'
  16. #36
    Great Pumpkin Keoke's Avatar
    Join Date
    Apr 2004
    Location
    LosAngeles Calif.
    Posts
    12,652
    Thanks Thanks Given
    9
    Thanked in
    Well we sure agree with Curt Johnson here.
    Last edited by Editor_Reid; 04-26-2019 at 02:23 AM. Reason: No need to thank me. Just doing my job.
    1966 Daimler V8 Saloon; Safely Fast, Built to Last & and; Smooth as Glass.
    1966 BJ8 [ 2 ] Lil Red & Miss bLU
    1985 XJ6 Saloon
    1948 & 70 Lincoln continentals
    1973 Volvo P1800ES
  17. #37
    Join Date
    Apr 2015
    Location
    Tampa, Florida
    Posts
    129
    Thanks Thanks Given
    Thanked in
    Quote Originally Posted by Curt Johnson View Post
    Finally 1 vote to keep the old tires, this is what I was wanting to hear two weeks ago before I bought all new tires. But you are only one out of about 20 people who said keep the old tires.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
