1993 xj v12 red hot catalytic converter
Tino
[h=2]1993 xj v12 red hot catalytic converter[/h]
any idea started the car, idling at 2000 rpm little high but usually, then slow dropped down to 1300 and felt had no power. only 6 cylinders working and cat was getting red hot...is clogged cat or bad sensor car has only 75k miles...thanks for any help
Thanks David & Larry ..Find the forum....
Tino​
LarryK
You actually have two six cylinders, check for spark at the bank you think is bad, then the other. Check MAF sensor on hot side, there is a cleaner for MAFs being careful not to blow out wires. Check TPS sensor, check inside distributor cap. If spark on one side coil should be fine. Thenmore you get cat red hot will actually ruin it and clog possibly ruining engine, that is whybwe recommend tow. Find a manual if you don't have one.
maynard
Your car has the Marelli ignition system. It has a unique, dual rotor, where one is stacked above the other. They had a tendency of shorting out. Check the rotor, look up Kirby Palms book on the XJS, (free on line) and read up about it.
The bad new is that the cat may be cooked (pun intended), and needs to be taken care of.
T
Tino
Thanks for all your help..Find Bad distributor Rotor and Bad Distributor Cap...But still can't get to shift from park, any association with bad bank future will prevent from using the car ??
Tino Sr.
maynard
It is possible that the shift cable's lining melted and fused the inner cable to the housing.
T
Tino
I will look close up after installed the new parts.I was on the same track after seen the Cat so Hot.. I received the Distributor Cap with no gasket...Should I use little silicon the same kind I will use to help isolate the Rotor ??
Thanks
Tino
T
Tino
Installed Cap & Rotor Engine runs fine , but still can shift..The shift is not moving even when I override, but I hear the solenoid engaging when push on brake pedal ..
If the cable is melted can I give a good pool or need to go under the carriage. Car can't be towed the way is parked.
S 1993 dodge Dakota shifter Other Cars 9
P For Sale 38k Mile 1993 Bentley Turbo R For Sale on Bring a Trailer Other British Classifieds 0
wkilleffer 1993 Cutlass convertible blowing a fuse Other Cars 7
AngliaGT Interesting Article on the V12 Jaguar 0
P For Sale v12 carbs Jaguar Classifieds 0
Paulus Thermovacuum switch for a 1973 V12 XKE Jaguar 4
drambuie Check out this Healey 100 with a Jag V12 convertion [click on the british v8 link] Austin Healey 5
CJD Valve shims on V12 Jaguar 19
P E Type V12 PCV & Smog systems Jaguar 8
V IRS selling a '73 XKE V12 Roadster Jaguar 0
B Looking for a Jaguar E-Type S3 V12 - LHD A/C unit Jaguar 0
1965_MGB XJS V12 Junkyard Sighting - West Palm Beach, Fl Jaguar 1
nissanite E-Type V12 very low oil pressure - new rebuild Jaguar 11
E 1990 XJ-S V12 Front Brake Locking Jaguar 5
Tullamore V12 E-Type Valve Covers Jaguar 10
equiprx 94, xjs 6.0, v12, coupe FF44 code Jaguar 2
Tullamore Custom V12 E-Type Project Jaguar 1
V Intermittent engine cut out 1989 v12 xjs Jaguar 9
Tullamore Zapped V12 E-type Jaguar 9
W new shocks for jag xjs v12 ? Jaguar 3
Rick60 E-Type Series 3 V12 distributor Jaguar 5
Wray XJS Coupe V12 Jaguar 11
PAUL161 So You Want A V8? How About A V12 MG 5
J V12 Marelli Ignition Jaguar 12
D v12 top hoses??? Jaguar 4
D xjs v12 tire wear Jaguar 1
A Stretching the V12 Jaguar 5
D 1991 xjs v12 irs oil leak& hot diff Jaguar 8
A V12 block cast date * 1st post * Jaguar 6
Sherlock Jaguar V12/1932 Ford Hotrod... Other British Cars 5
D 1991 xjs v12 strange pipe Jaguar 1
D grinding noise on 91 xjs v12 Jaguar 5
D 1991 xjs v12 high idle speed. Jaguar 8
D 1991 xjs v12 ,smell of fuel. Jaguar 4
G Looking at a 1988 XJ-S V12... CARFAX anyone? Jaguar 1
T Erratic idling v12 xjs Jaguar 2
Sergio MGA MGA 60 ROADSTER WITH BIG HEART JAG XJS V12 MG 6
Sergio MGA 1960 WITH A BIG HEART XJS V12 Jaguar 10
D Modifying the Jag V12 engine. Jaguar 3
J 86 XJS v12 fuel pump problem -Help! Jaguar 9
B Fuel leakage at carby on V12 Jaguar 4
K V12 Engine Fires Jaguar 8
J Spotted a V12 yellow XKE coupe yesterday at gas station in NJ. and thought maybe??? Jaguar 2
Rick O. V12 E-Type; Should I? Jaguar 6
L Upgrades for a V12 Jaguar 1
J V12 Door on 68 E-Type OTS Jaguar 7
M XJS V12 Cruise Control Jaguar 3
M V12 Jaguar 3
M How Do I Set Timing On 1990 Marelli Ignition V12 after reinstalling distributor ? Jaguar 0
R XJS V12 Problem Jaguar 5
