Results 1 to 7 of 7
Thread: 1993 xj v12 red hot catalytic converter
Discussions of Jaguar Automobiles of all styles
  1. #1
    Join Date
    Feb 2016
    Location
    Lebanon nj
    Posts
    8
    Thanks Thanks Given
    2
    Thanks Thanks Received
    Thanked in
    any idea started the car, idling at 2000 rpm little high but usually, then slow dropped down to 1300 and felt had no power. only 6 cylinders working and cat was getting red hot...is clogged cat or bad sensor car has only 75k miles...thanks for any help
    Thanks David & Larry ..Find the forum....
    Tino
  2. #2
    Luke Skywalker LarryK's Avatar
    Join Date
    Mar 2007
    Location
    Millstadt, IL
    Posts
    1,725
    Thanks Thanks Given
    12
    Thanked in
    Re: 1993 xj v12 red hot catalytic converter
    You actually have two six cylinders, check for spark at the bank you think is bad, then the other. Check MAF sensor on hot side, there is a cleaner for MAFs being careful not to blow out wires. Check TPS sensor, check inside distributor cap. If spark on one side coil should be fine. Thenmore you get cat red hot will actually ruin it and clog possibly ruining engine, that is whybwe recommend tow. Find a manual if you don't have one.
    Larry K
    58 Jag 3.4 MK 1 auto under restoration, 57 Jag 3.4 MK1 manual ,
    03 Cooper S, 2011 Cooper S Countryman, 2011 Land Rover LR4 HSE LUX, 1964 Valiant V200
    Also had , 68 Cortina 1600E, 64 Spit 4 & 80 1500, 73 GT6 3, 71 XJ6, 79 XJ6, 86 XJS V-12, 53 XK120 OTS.
  3. The Following User Says Thank You to LarryK For This Useful Post:
    Tino (04-18-2019)
  4. #3
    Join Date
    Jan 2003
    Location
    Palatine, illinois
    Posts
    499
    Thanks Thanks Given
    1
    4
    Thanked in
    Your car has the Marelli ignition system. It has a unique, dual rotor, where one is stacked above the other. They had a tendency of shorting out. Check the rotor, look up Kirby Palms book on the XJS, (free on line) and read up about it.
    The bad new is that the cat may be cooked (pun intended), and needs to be taken care of.
    Maynard
    94 Jaguar XJS 6.0 V12
    91 Jaguar XJS (RIP)
    86 Jaguar XJ6
    78MGB
    67MGB
  5. The Following User Says Thank You to maynard For This Useful Post:
    Tino (04-14-2019)
  6. #4
    Join Date
    Feb 2016
    Location
    Lebanon nj
    Posts
    8
    Thanks Thanks Given
    2
    Thanked in
    Thanks for all your help..Find Bad distributor Rotor and Bad Distributor Cap...But still can't get to shift from park, any association with bad bank future will prevent from using the car ??
    Tino Sr.
  7. #5
    Join Date
    Jan 2003
    Location
    Palatine, illinois
    Posts
    499
    Thanks Thanks Given
    1
    4
    Thanked in
    It is possible that the shift cable's lining melted and fused the inner cable to the housing.
    Maynard
    91 Jaguar XJS (RIP)
    86 Jaguar XJ6
    78MGB
    67MGB
  8. #6
    Join Date
    Feb 2016
    Location
    Lebanon nj
    Posts
    8
    Thanks Thanks Given
    2
    Thanked in
    I will look close up after installed the new parts.I was on the same track after seen the Cat so Hot.. I received the Distributor Cap with no gasket...Should I use little silicon the same kind I will use to help isolate the Rotor ??
    Thanks
    Tino
  9. #7
    Join Date
    Feb 2016
    Location
    Lebanon nj
    Posts
    8
    Thanks Thanks Given
    2
    Thanked in
    Installed Cap & Rotor Engine runs fine , but still can shift..The shift is not moving even when I override, but I hear the solenoid engaging when push on brake pedal ..
    If the cable is melted can I give a good pool or need to go under the carriage. Car can't be towed the way is parked.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
