Results 1 to 11 of 11
Thread: Gearbox removal and refitting leaver
  1. #1
    Jedi Trainee Graham H's Avatar
    Join Date
    Feb 2018
    Location
    Perth Western Australia
    Posts
    212
    Thanks Thanks Given
    2
    Thanks Thanks Received
    3
    Thanked in
    To help with my recent gearbox removal I made up a simple leaver that worked like a charm and made the job much less stressful. The Z shaped bracket was two pieces of 1"x1"x1/8" angle welded together and bolted to the firewall the lever is inch by inch square tube 45 inches long with a 1/4 x inch extension on one end loosely bolted to the top of the Z. The lifting bracket is bolted to the top of the box at the balance point making it easy to manoeuvre forward or back. I am not planning on making a habit of removing the box but now the hardest part is lifting it in and out of the passenger door the actual fitting was a breeze.
    [SIGPIC][/SIGPIC]
  2. #2
    Jedi Knight mgedit's Avatar
    Join Date
    Jan 2009
    Location
    Kemptville, Canada
    Posts
    835
    Thanks Thanks Given
    1
    Thanked in
    Re: Gearbox removal and refitting leaver
    Looks like a good idea, just hope I don’t have to use it any time soon. Cheers, Mike
    Webmaster Ottawa Valley Triumph Club (www.ovtc.net)
    1956 TR3 - TS11537 (www.triumphowners.com/to-car/tr3-9/)
  3. #3
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,233
    Thanks Thanks Given
    27
    Thanked in
    Graham that is perfect; I needed to see that-- plus I like how routed your overdrive relay also. I wish I would have rebuilt my over drive before I installed it like John did, but my lack of understanding of the overdrive unit had me decide to install the trans and listen to see what could be wrong. I looked inside and visually inspected the gears and they looked fine, but again I might be pulling it out next week after I hear it and feel it. I have been moving slow because of back problems and your invention will defiantly help if I need to remove the trans, good idea. I have removed a few non-OD- trans out from the top, but I was younger.
    Thanks for sharing steve
  4. #4
    Join Date
    Feb 2018
    Location
    Posts
    212
    Thanks Thanks Given
    2
    3
    Thanked in
    If you have to remove and refit the OD from the gearbox I came upon a youtube ( A-Type Overdrive Overhaul -part 8 ) showing an easy way to engage the splines and it worked a treat using the pressure gauge adapter with an airline fitting.
    Photos will not download?
    Graham
    [SIGPIC][/SIGPIC]
  5. #5
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    2,528
    Thanks Thanks Given
    12
    34
    Thanked in
    That looks like a great idea.
    As I have a OD gearbox to swap out later in the year I need to build one of these rigs. Was thinking of a bracket to allow my engine hoist to do the lifting.
    I presume that you have the rear of the motor blocked up to stop it moving.
    David
    TR3A TS75524L
  6. #6
    Join Date
    Feb 2018
    Location
    Posts
    212
    Thanks Thanks Given
    2
    3
    Thanked in
    Yes, David, you need to take the rear mount and cross member out then position the height so the bell housing will clear the firewall and block the gearbox and engine take off all the bits and pieces including the starter motor which I leave in the engine bay with a piece of wire looped around it and tied to the heater tap for support, fit the lifting bar and slide the box out and up onto the floor. I think I had to add a link on the chain at one point, I can't remember if that was putting it in or taking it out I think it was to let the bar clear the tunnel but shortened again for the final fit. I used a good block of wood under the sump to support the engine and another under the gearbox but you will need to fiddle with the height as the box with OD is a different shape underneath.
    Graham
    [SIGPIC][/SIGPIC]
  7. #7
    Jedi Trainee Merlin63Tr4's Avatar
    Join Date
    Nov 2006
    Location
    Milpitas, CA. U.S.A.
    Posts
    258
    Thanks Thanks Given
    3
    Thanked in
    And right side up...
    M.
    Merlin the '63 Tr4.... it grows younger !
    "A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools." -- Douglas Noel Adams (1952-2001)
  8. #8
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    2,528
    Thanks Thanks Given
    12
    34
    Thanked in
    Hello Graham
    What about the top radiator hose did you remove it or loosen the hose clamps to prevent damage to the radiator if the engine is moved up or down during the operation?
    David
    TR3A TS75524L
  9. #9
    Join Date
    Feb 2018
    Location
    Posts
    212
    Thanks Thanks Given
    2
    3
    Thanked in
    No I didn't David the flexible bit in the middle seams to handle it ok
    [SIGPIC][/SIGPIC]
  10. #10
    Senior Member Simmo's Avatar
    Join Date
    Sep 2012
    Location
    NSW Australia
    Posts
    101
    Thanks Thanks Given
    4
    Thanked in
    How did you manage to lift high enough to clear that blasted clutch leaver?
  11. #11
    Join Date
    Feb 2018
    Location
    Posts
    212
    Thanks Thanks Given
    2
    3
    Thanked in
    It's a bit of a fiddle but got there in the end.
    Graham
    [SIGPIC][/SIGPIC]
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
