Help ID gearbox/bellhousing?
Jake
Hi,
I have an old Moss gearbox with a strange bellhousing and tailshaft mounting/extension. I got it from a guy who recently parted with an XK140 project, but I don't think it's 140. Closest I can figure it's from a pre-war Jaguar SS. The center and tailshaft look to be similar to one out of an AC Aceca. Asking mostly out of curiosity, I don't think it's rebuildable. Top two photos are mine, third is Aceca, last is '39 SS chassis.
If you know what this is, please let me know. Current plan is to make the bellhousing into a flowerpot.
Thanks,
Jake
Deleted member 8987
There should be another number on the bell portion, like a C and four numbers.
That said, not an early 120, as they had an open bottom for clutch changing.
120 and 140 had manual mechanical clutch, not hydraulic, that one is manual mechanical.
So if it fits an XK block, 120-140. I think MK1's were hydraulic on all.
Cannot remember the bigger MK bells.
Jake
Jake
I'll check when I get home. Other than the C700-1 shown above?
The issue is that the starter recess is in a strange spot, I don't think it'd fit a standard XK block.
I had a response from another guy who thought maybe a '48 MK IV, I haven't been able to find any detailed pictures to confirm.
Thanks,
Jake
Deleted member 8987
Could be, but I am not seeing a full frontal shot of the bell to determine exactly. Oblique views are hard to quantify.
Deleted member 8987
I see. Odd starter placement, like for a V block to clear the bank and head. Plus what looks like an on-purpose big hole at the back of the starter bulge.
On the trans, on a flat cast pad, take sandpaper and clean it off, looking for part number/serial number. On the main cast body. Identifies where it came from.
I looked at Rover and Morgan and Jensen bells, not seeing it there.
The mechanical clutch sets a type, and two holes for two cross shafts is indicative of....something!
Jake
Jake
Right, that's what I figured, clearance for the starter pinion gear.
I found two stamped numbers on the cast iron case.
DA10177
C2071
Maybe these mean something?
Thanks for helping with this mystery.
Jake
Deleted member 8987
On Jags anyway, the prefixes indicate a lot....but the DA shows up in none of the databases I have access to. Yet.
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
J TR4/4A Help with gearbox dissassembly Triumph 5
TR6BobNF Gearbox Identification - Help Triumph 5
eschneider Help! Rover P3500S gearbox lubricant???? Rover / Land Rover 4
NardisCNC 4 spd gearbox stuck in Reverse! Please help! Spridgets 13
R gearbox identification help & required gearbox oil Spridgets 4
Team_Sprite HELP! Driveshaft / Gearbox Spridgets 19
S MG Midget 1275 Gearbox Oil - Help Needed MG 3
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 26
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
algot1901 HELP with wheel bearings Other British Cars 1
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
