Koni Shocks Installation
maxwedge5281
I found a very reasonably priced used Koni kit on eBay and bought the kit.
I have a question: Do you remove the shock valve from the original shock?
I know that I did with the Putzke kit that I have on my other Healey! Thanks for any help!
Re: koni shock installation
Yes, remove the plug, extract the valve assembly__and any shims fitted__then replace the plug and some oil (unless you did it on the bench, and didn't lose any oil ;) ).
maxwedge5281
maxwedge5281
thanks, randy!!! i miss the old z3 days in greenville!!!
Yes, we do too! Had an opportunity to talk with a few of the old faithful here lately, and we all miss those days. We were fortunate to have been able to partake with BMW's generosity ($25, then later $35 registration per car, for everything they did for us, and all the banquets and gifts).
maxwedge5281
maxwedge5281
i did not receive any instructions with the kit and still have a ouple of questions> does the lower mount for the koni shock go on top of or below the control arm. and which direction is the actual shock mount arm turned….up or down?
steveg
I had briefly installed one of these kits on loan a while ago.
I believe the lower mount installs across the bottom of the spring pan with spacers for clearance, requiring approximately 1/2"-longer bolts.
IIRC the shock mount points up. You can verify this by extending the shock tube all the way and measuring the center-to-center on the mounts, then installing the top mount and measuring the fully extended point of where the lower shock mount would be. If the lower mount is upside down, I don't believe the shock tube will extend that far. I believe the spring may interfere if you try to bolt the lower mount across the top of the lower A-arm.
maxwedge5281
maxwedge5281
thank you steve. I had come to this conclusion . and yes it will interfere with the spring mounted on top. do you know of any way to pick a more modern externally adjustable shock to replace the early internally adjustable shock! I called koni but they offered no help.
steveg
Shouldn't be hard to find shocks that will fit. Compress and extend a Koni to determine the minimum and maximum lengths.
I've had Spax shocks for 10 years. They're externally adjustable. BP Northwest used to sell them but may have changed brands.
Check with the usual suppliers: Tom's Import Toys, BCS, Healey Surgeons. Moss sells tube shock kits for Triumphs so the TR6 shocks might fit.
Addendum: TR6 shocks won't fit - you need the ones with eyes at top and bottom for your Koni kit.
maxwedge5281
maxwedge5281
I finally have the drivers side in place. I believe that it is correct. after replacing the front wire wheel hubs with disc sheel hubs I still have a bit to do. ...new brake lines, shims for the bearings, steel line to the flex line bracket was missing, make new pipes flexline to the calipher. etc. every time I look to correct something a new can of worms develop. well most of it is stuff that I would replace or rebuild anyway! part of the "learning curve of enjoyment" and at almost 79 something to keep me active!!!
maxwedge5281
maxwedge5281
no just the regular healey lever shocks. ill be looking for a kit for the rear....I have the putze kit on my other bn6 and am very pleased with it.
John Turney
That Koni kit looks very similar to what was fitted to the cars built from kits in South Africa. There is a guy in British Columbia that has a CKD South African built car. He was parked next to me in 2017 and showed that setup to me.
steveg
So the rear Koni conversion is for the 2 + 2 seat configuration.
It should work on the 2 seaters, too. Mine is a Cape setup, which is similar. I had to bend the angled plates a little because the angle of the transom is slightly different on the 2 seater. The right-angled box area above and behind the axle is the same on both. The supplied shocks were perhaps 1/2" too short for the 2 seater setup and the lower mounts flexed and eventually broke. Make sure your shocks are long enough when extended to accommodate the lower axle when it is resting on the frame cushions.
aero3113
I believe I have the same Koni conversion. I removed mine from my 100 and installed new lever shocks. I want to see if I like the feel without them. I’m going to drive the car for a few weeks and make a decision.
John Turney
Let us know how your test goes.
S TR2/3/3A Koni shocks part number? Triumph 2
glemon General TR Koni Shocks Triumph 19
B TR2/3/3A what adjustment should i select with Koni shocks onTR3? Triumph 4
Moseso TR2/3/3A Adjusting Koni shocks [TR3] Triumph 10
abarth69 Koni shocks Restoration & Tools 6
2wrench Koni shocks promised.....again. Triumph 2
2wrench Koni shocks not coming. What to do? Triumph 8
R Koni Rear shocks, setting? Triumph 2
LastDeadLast Koni adjustable shocks anyone Triumph 8
B TR4/4A Spax, Gaz and Koni on Front Triumph 12
jjbunn Koni Coil Over and Assorted Questions Triumph 8
G Spax or Koni? Triumph 6
svtmikey GT6 Lowering springs on a GT6 /Koni's Triumph 0
Alan_Myers Koni comments Triumph 3
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
mctriumph For Sale lever shocks from a 61 Morgan plus 4 Other British Classifieds 0
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Gliderman8 TR6 New shocks (damper) question Triumph 4
Donald1107 TR2/3/3A TR3 Rear Shocks Triumph 11
D The best place to get shocks rebuilt. Spridgets 8
J Midget front shocks Spridgets 4
W Best source for Bugeye front shocks Spridgets 3
AngliaGT My '95 Dodge Dakota Needs New Shocks Other Cars 4
Michael Oritt Shocks and/or Springs Austin Healey 9
Z Front Shocks Austin Healey 19
P TR6 New front shocks & air in clutch Triumph 15
pkmh Rebuilding Armstrong Lever Shocks on a BJ8 Austin Healey 28
F Refilling and servicing Armstrong Lever Arm rear shocks Austin Healey 4
A Front Shocks Bushing Replacement Austin Healey 2
edkap2002 TR6 differential mounts, rear springs and shocks Triumph 1
JPSmit replace shocks in pairs? Spridgets 7
P TR6 Front shocks Triumph 11
nicko Front shocks Austin Healey 16
Rut TR4/4A Bilstein shocks Triumph 0
S TR2/3/3A New shocks too short? Triumph 7
M New Shocks for Otto and other winter projects Spridgets 22
jfarris TR2/3/3A Whitworth fill plug for lever shocks Triumph 2
Boink Springs & Shocks Spridgets 2
T TR2/3/3A TR-3a Rear Shocks Triumph 1
M Replacing front shocks, torque setting? Spridgets 2
S T-Series girling shocks MG 0
B Front Shocks Austin Healey 6
69MGC MGC Lever Shocks are Toast MG 7
T TR2/3/3A Rear shocks and rattle Triumph 5
S Replace original suspension for shocks? Austin Healey 2
T "Cheese-Headed Screws" on Armstrong lever arm shocks Spridgets 2
T BSW Filler Plug Armstrong Rear Shocks? Spridgets 2
T Differences in Armstrong Lever Arm Shocks Spridgets 1
CZ_Dave MGB Is it worth doing the Shock Conversion Kit or Rebuilding Exsisting shocks? MG 16
Foura TR4/4A Part number for Monroe shocks on Moss telescopic conversion TR4A Triumph 1
