T-Series Turn Signal Flasher
PAUL161
My flasher just slowed down and now only flashes about half as fast as it should. All circuits and connections are fine with the proper voltage everywhere. Anyone have problems with these new flashers, mine is only a couple years old. PJ
NutmegCT
Paul - how 'bout some details. What flasher (electronic or non-electronic), what bulbs (LED or incandescent, etc.)? Any bulbs not lighting up fully?
Tom M.
PAUL161
PAUL161
I found out the flasher went bad. I found the old flasher that was in the car when I bought it and it works fine, over 30 years old but made here and works like new! Only LEDs on the car are in the dash, the rest are all as original. The flasher that went south is Oriental junk, same as the brake switch that also went bad! :rolleyes2:
pdplot
When I restored a TD back in the 1970s, I installed a new flasher and it didn't work. I checked the wiring and it was fine. I took the flasher back to the store and got a new one. It worked fine. Apparently they are fragile and finicky.
PAUL161
PAUL161
I found out that the ones made here have different internals, better quality, IDEAL brand is one. The ones made in the Orient are poor quality (JUNK) and if they work and for how long is a gamble. I have a 1986 Ford Ranger pickup I bought new and it still has the original flasher in it! 33 years with the same flasher, among other things, that says something for American made products! :encouragement:
PAUL161
PAUL161
I bought two new flashers made in the UK with the proper mount, they work fine.PJ
JPSmit
But surely it is confusing using RHD flashers on a LHD car? :rolleyes:
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
6 Turn Signal Flasher Spridgets 8
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
N Turn signal flasher?? Spridgets 8
KVH TR4/4A Turn Signal Flasher and Perceptions Triumph 3
KVH TR4/4A Three Questions: Distributors, Idling, Turn Signal Flasher Triumph 29
K TR2/3/3A Turn signal flasher stays on? Triumph 3
M Where is the turn signal flasher relay? Austin Healey 7
J AH -Turn Signal Flasher Mystery Austin Healey 22
MGB922 Turn Signal Flasher Problem MG 1
T Voltage stabilizer, turn signal flasher, hazard Spridgets 2
M 87 XJ6 Turn Signal/Hazard Flasher Switch Problem Jaguar 16
BoneIdle MGB-GT Turn signal flasher location 1974 GT MG 0
Moose33 '71 B turn signal flasher removal MG 7
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
K TR2/3/3A The horn and turn signal assembly. Triumph 3
KVH General TR Green Turn Signal Dash Indicator Triumph 8
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
B General MG Turn Signal Issue MG 1
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
M Europa turn signal problem Lotus 7
R Spitfire Turn signal wiring Spitfire Triumph 5
S TR2/3/3A Rear turn signal lamp and trim installation Triumph 5
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
R Turn Signal Knob goes off center Austin Healey 9
E MGB Turn signal bulb MG 5
Nelson Turn signal beeper. Spridgets 14
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
M TR6 Turn signal switch stalk Triumph 1
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
K TR2/3/3A Turn Signal Control Head Alignment Again Triumph 1
J 1997 Vanden Plas X300 ,Help With Turn Signal Blowing Fuses Jaguar 3
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
B Turn Signal Indicator Light Always Flashing Austin Healey 10
R TR2/3/3A The Turn Signal Challenge Triumph 2
TR3TR6 TR6 TR6 turn signal puzzle Triumph 11
S Turn signal nightmare ! Spridgets 4
S Turn signal nightmare ! Austin Healey 4
J BJ8 Turn signal help needed. Austin Healey 6
glemon General Tech Turn Signal Issue Triumph 12
TR3TR6 TR6 Turn signal lights don't flash when under load. Triumph 5
R Turn signal switch [trafficator] Austin Healey 1
R TR2/3/3A Turn signal wiring Triumph 1
S Bizarre turn signal issue Austin Healey 10
bighealeysource Turn signal gremlins on BN2 Austin Healey 2
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
bighealeysource Turn signal issues Austin Healey 6
