Results 1 to 11 of 11
Thread: drilling out shifting tower for a dip stick
  1. #1
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,254
    Thanks Thanks Given
    Thanks Thanks Received
    27
    Thanked in
    Has anyone drilled out the shifting tower for a dip stick? Perhaps it might be best to take it in to a machinist. I do have a drill press.
  2. #2
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Arlington, TX, USA
    Posts
    5,278
    Thanks Thanks Given
    6
    26
    Thanked in
    Re: drilling out shifting tower for a dip stick
    I would think it would be easy with a decent drill press. It is just a straight, vertical hole, slightly larger than the dip-stick.
    John
    1955 TR2
  3. #3
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,254
    Thanks Thanks Given
    27
    Thanked in
    I guess my concerns are cutting the cast aluminum and having a quality finish on the edge. I was once told to stop worrying about the mule going blind and load the wagon. For me, one time things like this are difference between framing some house with wood or pouring 50 yards of concrete. One is easily fixable the other not. I guess I have an old shifting tower somewhere to practice on and it was probably drilled and not cast in first place by an Englishman after WW2. Somehow, I should be able to apply Randall’s story about George Washington’s axe.
  4. #4
    Join Date
    Aug 2010
    Location
    Strafford, NH
    Posts
    1,685
    Thanks Thanks Given
    7
    11
    Thanked in
    I wonder what you'd gain. It's pretty easy to check by the removing the filler plug at engine oil change intervals and if you don't have a puddle under the transmission after it's been parked, there would be no reason to check the level more often.
    Tom
    1960 TR3A TS73117 (under endless restoration, owned since 1964)
    1959 TR3A TS58023 (in case I never finish the one above)
    1969 Triumph Herald 13/60 (a whim)
    1970 Lotus Elan Plus 2 /0023/N
    1992 BMW325IC (fun to drive)
  5. #5
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Arlington, TX, USA
    Posts
    5,278
    Thanks Thanks Given
    6
    26
    Thanked in
    Just something cool about being able to reach over and check your tranny oil with your best suit on!
    John
    1955 TR2
  6. #6
    Join Date
    Mar 2016
    Location
    Central California
    Posts
    112
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Or...if you have a TR2 or TR3 gearbox, you could simply purchase a transmission cover with the hole already drilled in it, and transfer over any shifter mechanism parts you need to in order to maintain a smooth-working mechanism. Having the dipstick hole in the top of the cover makes refilling the gearbox very easy when changing the lubricant. Using a small funnel and one of today's squeeze-bottle oil containers, it's much easier than using the later-style side plug for filling.
  7. #7
    Join Date
    Jul 2010
    Location
    Annandale, NJ
    Posts
    845
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Im not sure of the details but I had my tr3b trans with first gear syncro built with an earlier dipstick top.
    I like It.I can access the drain plug easy and fill from the top.As mentioned the drain plug is easily reachable without jacks but filling at the side plug not so easy.
    Tom
  8. #8
    Luke Skywalker sail's Avatar
    Join Date
    May 2007
    Location
    IA
    Posts
    1,965
    Thanks Thanks Given
    5
    Thanked in
    I had my cover drilled by a machinist and I put a plug in the tunnel for it. I Got the dip stick off eBay, doesn't get used much but nice to have for a quick check. In the process I learned shops that aren't interested in doing piece work and thankfully found one who was and they also put HeliCoils in the trailing arms.
    Richard
    65 tr4a
  9. #9
    Join Date
    Oct 2012
    Location
    Albany, OR
    Posts
    407
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Steve-Not only do you have to drill the top cover, but also make a dip stick. Not a difficult job, if you have the equipment. A simpler plan B might be to just drill a hole in the tunnel cover in line with the fill plug. This gives the same advantage as the dip stick, being able to check&add oil without crawling under the car. Make the hole to fit a plug like the one used in the floor for the jack. I made this mod to my TR6 and found it very useful.
    Berry
  10. #10
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,254
    Thanks Thanks Given
    27
    Thanked in
    I got a hole drilled in the top cover without any problems. There is an existing hole that is about that almost goes through on the inside, but there is a lot of metal left on the sides. I drilled hole, roughly-from the inside out using the hole for guide. The drill press was my father-in laws and he had a bunch of old bits that where pretty old; I could not see any markings on it. I just picked through until I found one that fit nice into top cover that had an original dip stick hole. I used the old drill bit after sharpening it with a little stone dermal bit because the bit had a bunch of dings in it plus I was too cheap to buy one; unless I really had to. Anyways, it cut right through; the stuff is soft.
    steve
  11. #11
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Arlington, TX, USA
    Posts
    5,278
    Thanks Thanks Given
    6
    26
    Thanked in
    One more step closer!
    John
    1955 TR2
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
