Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Mirrors.
  1. #1
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    2,259
    Thanks Thanks Given
    10
    Thanks Thanks Received
    26
    Thanked in
    Mirrors.
    I have found that the rear view mirror mounted in the center of the dash has a limited view and the wing mirror is even more limited,
    It seems that a mirror mounted on the windshield stanchion would make keeping an eye on traffic behind you a bit easier.
    Has anyone come up with a good solution?
    I think that clamping to the strip that goes between the stanchion and the windshield frame would work but with the side screens on that may not work.
    David
    TR3A TS75524L
  2. #2
    Obi Wan M_Pied_Lourd's Avatar
    Join Date
    Oct 2008
    Location
    Newmarket, Ontario,Canada
    Posts
    2,375
    Thanks Thanks Given
    3
    Thanked in
    Re: Mirrors.
    Hi David,
    There is a mod to use a Harley Davidson mirror (I think) in one of the windscreen stantion locating bolt locations. If this is something that might interest you, I think I saw it on the TR Register Australia or New Zealand website. Others here may know about it as well...
    Cheers,
    Tush
    81 Alfa Romeo Spider Veloce, 81 Triumph TR8
    73 Triumph TR6 CF4874UO, 68 Triumph TR250 CD5228LO
    62 Triumph TR4 CT6716LO, 60 Triumph TR3A TS69891LO
    60 Triumph TR3A TS64870LO, 59 Triumph TR3A TS44836LO
  3. #3
    Join Date
    Feb 2011
    Location
    San Antonio, TX
    Posts
    36
    Thanks Thanks Given
    Thanked in
    Re: Mirrors.
    Hello......I purchased the HD mirrors on ebay....item captioned Harley Davidson universal 4 inch chrome mirror....you need both left and right because the stem is angled for each side. Cost about $20 each. They are mounted in the screw holes of the windshield. Hopefully the attached photo will be there for illustration!
  4. #4
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    18,989
    Thanks Thanks Given
    4
    72
    Thanked in
    Re: Mirrors.
    Might be worth mentioning that this trick only works for later cars, with bolts holding the stanchions to the scuttle. Won't work so well on earlier cars (like mine) that use Dzus buttons in that location.
    But I get along fine with the convex wing mirrors. They're a PITA to keep adjusted, as people keep bumping into them in parking lots (and I do myself sometimes, when working under the hood). But properly adjusted, and combined with the center mirror, IMO they work quite well. One of the things I really like is when pulling out from a parking space with a big SUV parked behind me, I can pull up until just the mirror peeks around the SUV, rather than having to pull out far enough for a side mirror to get a view of oncoming traffic.
    Randall
  5. The Following User Says Thank You to TR3driver For This Useful Post:
    glemon (03-23-2019)
  6. #5
    Yoda martx-5's Avatar
    Join Date
    Jul 2002
    Location
    Kings Park, NY
    Posts
    6,534
    Thanks Thanks Given
    3
    Thanked in
    Re: Mirrors.
    I have convex wing mirrors on both sides. That helps. But, I also added a mirror screwed into the stanchion where the rear bolt goes. I used a convex wing mirror from the right side, and modified the length of the stud. The original stud is the correct size (5/16"-24 IIRC), but too short. Since it was part of the casting, I just cut it off, drilled and tapped a hole and screwed in a longer stud. With a couple of flat washers for spacers, the mirror just screws right on in place to the stanchion screw.
    Edit: I tried using a clamp-on mirror on that strip. It lasted about 6 miles before it fell off and the car behind me ran over it! And, yes it will interfere with the side curtains.
    Art
    '58 TR3A TS236xxL
    '92 Mazda Miata -- Supercharged
    '07 Mazda RX-8
    '11 Mazda CX-7
  7. #6
    Jedi Warrior 6TTR3A's Avatar
    Join Date
    Mar 2008
    Location
    San Diego, CA
    Posts
    422
    Thanks Thanks Given
    2
    Thanked in
    Re: Mirrors.
    I'm fortunate to have an original set of Lucas convex wing mirrors.
    The original ones aren't quite as convex as the aftermarket ones,
    so there is a better field of vision.
    I supplemented that by converting the scuttle mounted interior
    rear-view one to a convex one as well. Went to a junk yard, got one
    of the modern passenger side exterior rear-view ones (the one
    with the little note etched in), took it to glass/mirror shop & had them
    cut it to fit in my TR3A mirror. Between the three I have virtually no
    blind spots.
    Frank
  8. #7
    Senior Member ckeithjordan's Avatar
    Join Date
    May 2017
    Location
    Shawnee, KS
    Posts
    100
    Thanks Thanks Given
    5
    Thanked in
    Re: Mirrors.
    I didn't like the wing mirrors, they were "too far away" to see properly. I did add a clamp-on mirror bought from Vintage Car Parts in England at: https://www.vintagecarparts.co.uk/ca...irror-exterior
    It's stayed on so far, using set screws to clamp the windshield side tenon (it does vibrate, though). I have not tried the side curtains yet. Attached is a picture of the mirror and on my car. A better mirror is in the other photo of the TR2, but that would require drilling/tapping into the Dzus or bolting through the stanchion mount.
    Keith
    1957 TR3 TS20447LO (2017-)
    1962 TR3B TCF1183L (1979-1982)
    1966 Spitfire MKII (1972-1975)
  9. #8
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    2,259
    Thanks Thanks Given
    10
    26
    Thanked in
    Re: Mirrors.
    Well there is one of my problems. My wing mirror is flat not convex. So I need to find a convex one to start with.
    Randall
    I do notice that it is easy to move them as you walk past in the garage. If you leave them lose enough to adjust and they move easily.
    Art
    That was what I was afraid of with the clamp on type.
    David
    TR3A TS75524L
  10. #9
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    2,259
    Thanks Thanks Given
    10
    26
    Thanked in
    Re: Mirrors.
    Hello Keith
    Thank you.
    How long is the stem? It looks like the mirror may stick out a bit and easily get bumped by clumsy pedestrians in parking lots. (or Owners in garages)
    David
    TR3A TS75524L
  11. #10
    Jedi Hopeful Graham H's Avatar
    Join Date
    Feb 2018
    Location
    Perth Western Australia
    Posts
    174
    Thanks Thanks Given
    2
    2
    Thanked in
    Re: Mirrors.
    Hello David,
    The side mirrors are still available from the tr-register.com.au look in the for sale section,P1020837.jpg as you can see fitted to my car I can't remember how much I paid but they fit well and don't get in the way of the side screen
    [SIGPIC][/SIGPIC]
  12. #11
    Join Date
    Feb 2018
    Location
    Posts
    174
    Thanks Thanks Given
    2
    2
    Thanked in
    Re: Mirrors.
    Why are my photos posting upside down? very annoying.
    Graham
    [SIGPIC][/SIGPIC]
  13. #12
    Join Date
    Jul 2018
    Location
    Perth Australia
    Posts
    150
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Re: Mirrors.
    Holding your camera upside down Graham?
    Lionel
  14. #13
    Join Date
    May 2017
    Location
    Shawnee, KS
    Posts
    100
    Thanks Thanks Given
    5
    Thanked in
    Re: Mirrors.
    David,
    I can’t tell you at the moment as my car is at Macy’s Garage getting a drive-train rebuild. I should have it back in a couple of weeks and can check then. I can’t say I really had a problem bumping it.
  15. #14
    Join Date
    May 2017
    Location
    Shawnee, KS
    Posts
    100
    Thanks Thanks Given
    5
    Thanked in
    Re: Mirrors.
    Quote Originally Posted by Graham H View Post
    Graham
    Because they’re from Down Under!
  16. #15
    Join Date
    Oct 2018
    Location
    Livermore, Ca
    Posts
    99
    Thanks Thanks Given
    5
    Thanked in
    Re: Mirrors.
    Because you are in Australia. edit: opps someone beat me to the joke.
  17. #16
    Yoda poolboy's Avatar
    Join Date
    Oct 2007
    Location
    S.W. Mississippi
    Posts
    3,673
    Thanks Thanks Given
    12
    9
    Thanked in
    Re: Mirrors.
    DRIVE 'EM IF YOU GOT 'EM
  18. #17
    Join Date
    Feb 2018
    Location
    Posts
    174
    Thanks Thanks Given
    2
    2
    Thanked in
    Re: Mirrors.
    I did think of the down under option after posting
    Graham
    [SIGPIC][/SIGPIC]
  19. #18
    Luke Skywalker Got_All_4's Avatar
    Join Date
    Dec 2004
    Location
    NEOHIO
    Posts
    1,515
    Thanks Thanks Given
    Thanked in
    Re: Mirrors.
    Cant tell you how many times I took a lot of time to adjust the mirrors just perfect just to get out of the car the next time and smack it with my wrist walking buy. In a car show you might as well plan on taking time before you go home to adjust your mirrors. Here is how I got ride of a lease 50% or more of the problem with original mounted mirrors. All i did was just slightly turn them in towards the bonnet. If you were standing behind the driver mirror (US cars) loosen up the screws and turn it counter clockwise which puts it more in a upright position instead of hanging past the fender. Too far and the bonnet will will hit it when raised. Course turn it clock wise on the passenger side.
    Now if I'd seen this tread before I restored my car the 2nd time I would have filled in the fender holes and did the windshield post mount. doesn't look as cool but functionality is what I'd be looking for.
  20. #19
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    2,259
    Thanks Thanks Given
    10
    26
    Thanked in
    Re: Mirrors.
    I have ordered a convex mirror to replace the wing mirror and a clip on mirror with a convex mirror. Ordered them from Holden Vintage and Clasic cars in the UK.
    See if that helps. I will fit the wing mirror first.
    David
    https://www.holden.co.uk/Default.asp
    TR3A TS75524L
  21. #20
    Yoda PeterK's Avatar
    Join Date
    Oct 2004
    Location
    Maine
    Posts
    3,555
    Thanks Thanks Given
    4
    Thanked in
    Re: Mirrors.
    Yes, I have Tex "spring back" mirrors on my wings. They have a spring mounted stem so if I knock it, it springs back into position. Need to keep the head tightened after it is adjusted to keep that from moving if I hit it too hard. But they do work and spring back nicely.
    PeterK
    1958 TR3A 1966 TR4A both HVDA
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
