Results 1 to 4 of 4
Thread: Stromberg Dash Pot Screws
Discussions of Jaguar Automobiles of all styles
  1. #1
    Join Date
    Aug 2018
    Location
    St. Louis, MO
    Posts
    15
    Thanks Thanks Given
    2
    Thanks Thanks Received
    Thanked in
    Car is a '69 E-Type with dual Strombergs. The top (dash pot) is held on by 4 screws. I noticed a while back that one of the 4 screws is longer than the other three on both of the carbs. I was talking to a parts guy at one of the Jag parts distributors and asked him about that. He said that he vaguely remembered once at a show seeing this and that the longer screw had a hole drilled in it. He recalls that there was a wire going thru the hole with a small piece of lead crimped on it. He doesn't remember what the crimped lead looks like and has no idea what it was for. Does this ring a bell with anyone?
    Just curious,
    dj
  2. #2
    Join Date
    Apr 2005
    Location
    Giswil, CH & Fallbrook the Avo Capital, USA
    Posts
    1,590
    Thanks Thanks Given
    8
    Thanked in
    Re: Stromberg Dash Pot Screws
    Yes.
    they where set at the factory....no need to reset.
    You should switch out to adjustable needles.
    My restored car as them, but new dash pots fitted.
    Cheers,
    D.
    "If it's got t*ts or tyres, you've got problems"
    www.englishmotorsatfairbrook.org
    TVR Car Club North America Southwest Regional Organiser
  3. #3
    Yoda Geo Hahn's Avatar
    Join Date
    Sep 2001
    Location
    Mt Lemmon, Arizona
    Posts
    9,370
    Thanks Thanks Given
    14
    Thanked in
    The lead seal on mine...
    Okay, I'll admit I have a seal maker -- I do open them up.
    I installed TR4 adjustable jets to make it easy to dial in the mixture - otherwise you are left with moving the needle a bit or taping down the fixed jet.
  4. #4
    Join Date
    Apr 2005
    Location
    Posts
    1,590
    Thanks Thanks Given
    8
    Thanked in
    I used a fishing tackle weight. Crimped with pliers.
    Cheers,
    D.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
