TR4/4A Cracked Zenith-Stromberg float assemblies
Merlin63Tr4
Got a call from a friend about a sudden rich running problem with his ’64 Tr4, strong smell of fuel, sputtering, etc. I told him to stop running it till I got there.
When I got to his place there was a strong smell of fuel inside the garage were he kept the car. So being on the cautious side I told him that we should push the car outside to troubleshoot it.
After starting the Tr it did’t take long to figure out the problem since fuel was dripping out of the front air filter, onto the lower inner fender and the ground….
So we took the front Z-S carb apart expecting a stuck needle valve but instead we found the float assembly cracked wide open! So as a precaution we took the rear carb apart to see its condition and we found another cracked float assembly, not as bad as the front’s, but still cracked.
As far as my friend knows these floats are original to the car (he has owned it since 1967) so they could be 55 years old.
So the car is out of commission waiting for replacement carb floats.
Wonder if the replacement floats will last 55 years…..
M.
glemon
The floats for these carbs weren't available for a while, they are last I checked, they are supposed to be made of stuff impervious to gas, alcohol, etc. Though I know that the statement in the advertising doesn't make true.
Merlin63Tr4
Merlin63Tr4
Yes, he ordered a pair of float assemblies made of Nitrophyl.
Guess I should check the floats in my carbs.....
M.
Geo Hahn
Do check them - even if they haven't cracked to the point of total failure they may have a seam that is allowing some fuel into the float. That will cause poor running.
I have even had a partially fuel-logged float that wold cause the engine to die on hard left-handers. Felt like fuel starvation but really if was dumping fuel into the intake and killing the engine.
I now have the Nitrophyl and hopefully 'problem solved' for a long long time.
Merlin63Tr4
Merlin63Tr4
The floats in my carbs are probably ready to crack if they're not cracked already, they are even older than the ones in my friend's Tr4.
I think I will just order new Nitrophyl floats tonight, no use taking the carbs apart and then find out you need parts.....
M.
Gliderman8
M.
Where's the best place to order the floats from?
Can you post a link?
Merlin63Tr4
Merlin63Tr4
dklawson
Several years ago I had a float sink on our GT6. No one had replacement floats, not even Joe Curto. Fortunately I was able to get a working float from a spare carb I had. These are the 150 CD carbs, not the more common, later CD2 series for which floats are available.
Where did you find the new floats? I can tell from the photos you posted that they are the same style of floats as used on the GT6. However, I assume the TR4 has 175 CDs. I'd like to get some new ones if they are available for the 150 size.
Merlin63Tr4
Merlin63Tr4
dklawson
From the quick searching I did, I was only able to locate some floats for GT6 Mk2 (68-72).
Thanks for looking. Unfortunately that is the same thing I found a couple of years ago. Our GT6 is a '67 so the later floats are not a direct fit.
When the problem happened I ordered one of the later CD2 floats to experiment with. I believe what might work is to use the later CD2 float by cutting off one of the two float valve actuating arms and putting a spacer on the pivot shaft to hold the later float horizontally in the correct position. After that it will take some experimenting to get the equivalent level of fuel in the float bowl.
That's why I used the donor float from an extra carb. I was too lazy at the time to experiment. Hopefully I won't have to take up those experiments anytime soon.
Merlin63Tr4
Merlin63Tr4
Doug,
That's too bad.
Do you know how much smaller the 150CD floats are than the 175CD floats? Could the 175CD floats be made to fit?
M.
poolboy
The floats for the ZS carb in the TR4 is different from the float in the TR6 carbs...but Joe Curto has both and shipping will be closer to the actual price and not based on price of items.
A phone call is best...not email.
Merlin63Tr4
Merlin63Tr4
Ooops, finally noticed that Gliderman8 was posting about Tr6 floats.
I have corrected my post by adding a link to Tr6 carb floats
M.
Merlin63Tr4
Merlin63Tr4
Poolboy,
Sorry for the late response, things got a little hectic around here.
Took your advice and called Joe Curto.
He is the originator of the TR Nitrophyl carb floats.
His floats are around half the price of the other vendors with a very sensible shipping cost.
Thanks for the heads up.
M.
P Cracked windshield Other Cars 0
M TR2/3/3A Cracked Welds on Steering Idler Arm Triumph 5
P TR2/3/3A Windshield Cracked Triumph 12
Kleykamp TR2/3/3A Cracked Block??? Triumph 6
D MGB MGB Cracked Cylinder Heads Question MG 4
BoyRacer 6 cyl aluminum head - cracked valveseat Austin Healey 1
TimK 2 cracked windshields Austin Healey 13
aeronca65t Cracked Rostyle Spridgets 6
scoutll Exhaust manifold has cracked-Anyone have a spare? Spridgets 2
MCNX_BFF Cracked and leaky Triumph 20
M cracked head ??? Triumph 6
Carlos TR4/4A TR4A cracked cylinder head Triumph 8
Stewart cracked head? MG 7
tweety It wasn't a head gasket or anything cracked..... Spridgets 1
tweety I'm assuming head gasket, cracked block or head??? Spridgets 4
eschneider MGB MGB sunvisor rivets [and now cracked glass] MG 4
Baz Cracked coil spring! Spridgets 25
SilentUnicorn 1500 Cracked head? Spridgets 3
B Piston is cracked MG 7
U cracked exhaust manifold Spridgets 19
G TR2/3/3A TR3A cracked frame Triumph 3
J cracked wishbone! Spridgets 17
J New Soft-top, or reupholster cracked window? Triumph 6
G Quarter Light Frames Cracked! MG 0
M TR2/3/3A Cracked TR3 block... Triumph 0
N TR2/3/3A TR-3A cracked exhaust manifold Triumph 8
M TR6 Help- TR6 rear shock mount cracked Triumph 3
aeronca65t Cracked WIndshield Restoration & Tools 15
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
Celtic 77 MGB Tinny Zenith air regulator MG 0
P Zenith Carburetor Triumph 2
V MGB Zenith Stromberg and a Cat on an earlier model car? MG 22
P MGB Zenith water choke gasket needed MG 4
P MGB Zenith 175 cd carb damper oil MG 2
doc50 For Sale Zenith carb, fits many cars. Other British Classifieds 0
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
sparkydave Zenith auto choke coming loose Spridgets 2
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
bfitz Zenith Stromberg O ring question Other British Cars 8
C TR6 Zenith Strombers won't start when warm. Triumph 2
sparkydave Zenith auto choke coming loose Spridgets 3
Zimmycobra TR4/4A Zenith Stromberg questions Triumph 13
L zenith-stromberg carbs Lotus 11
Airfix Wedge TR8 Zenith Stromberg carbs slow deceleration Triumph 1
W Zenith stromberg carbs Jaguar 3
A Zenith 175 CD's Triumph 19
A Zenith 175CD carbs Triumph 9
CZ_Dave Zenith Carb MG 13
R Zenith Stromberg CD 175 float replacements? Triumph 3
eschneider TR4/4A TR4 Zenith-Stromberg CD175 tuning question Triumph 4
