Fuel pump question
metropolisman
all,
i just converted my 66 bj8 to negative earth and purchased a new su negative ground fuel pump. I checked the power coming in to the pump and I’m getting 12 v ,the ground wire is properly attached to the mount bracket bolt and when I turn the ignition on I only hear a click, the pump is not cycling like it should .could this be that the pump is not properly grounded or is it something else? I retained the su pump box and it is marked negative ground. Thanks in advance for any advice you can offer.
What kind of pump, points or electronic (points pumps can be polarity-sensitive depending on what they use to shunt the back current from the coil)? If it's a points pump, the points can oxidize sitting on the shelf and may need to be cleaned to function properly, if it's a solid state pump it could be defective. Also, the ground wire is usually attached to a spade lug on the screws on the coil body; the pump head is effectively isolated by the diaphragm. If you've attached the ground wire to a mounting stud, that may be the problem. Can you post a photo of your installation?
M
metropolisman
Bob,
Good morning Thanks for the prompt reply! This pump is a brand new solid state genuine su - ground. I will play around with the ground wire. I completely replaced this wire as it was buggered. I’ll also contact Moss this morning to see if they have had problems with these pumps in the past, have a great weekend! -jeff
Michael Oritt
Jeff--
Start at the beginning:
If the pump is not yet installed bring known-to-be-good power and ground to it (e.g. from a battery or benchtop 110VAC--->12VDC power supply) and see if it runs.
If it is installed bring NEW wires, again direct from the battery, to it.
Report back....
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
M_Pied_Lourd TR2/3/3A Fuel pump sediment bowl gasket question Triumph 12
vette New Question About Fuel Pump Austin Healey 12
nevets SU fuel pump question Austin Healey 21
P TR6 Fuel pump question Triumph 10
B Question about Dual Polarity Electronic Fuel Pump - How to Connect Wiring? Austin Healey 9
T Question on 1994 XJ12 fuel pump Jaguar 3
6 Fuel pump question Spridgets 14
M Fuel pump torque question Triumph 14
B Series 1 E-Type fuel pump question Jaguar 2
nevets another SU fuel pump question Austin Healey 10
J TR2/3/3A TR3 fuel pump question Triumph 7
JFS Wedge TR8 Fuel Pump Question Triumph 3
richberman Dumb SU fuel pump question? Austin Healey 9
V Solid state fuel pump question Spridgets 2
JPSmit Fuel pump question Spridgets 7
T Quick fuel pump question - mounting angle MG 3
G Fuel pump question Spridgets 2
drooartz Question: power for the fuel pump Spridgets 9
Stinger TR4/4A TR4A Fuel Pump Question Triumph 2
M Fuel pump Micro polish, and shaft seal question Triumph 14
M_Pied_Lourd TR2/3/3A TR3 Mech/Elec Fuel Pump Question Triumph 9
M_Pied_Lourd Old Electric Fuel Pump Question Triumph 15
jvandyke fuel pump relay question Spridgets 5
Bayless SU fuel pump question Jaguar 37
B Question about a fuel pump Triumph 3
sparkydave Electric fuel pump question Spridgets 13
T Electric fuel pump question Triumph 29
Brosky Fuel pump internal valve removal question Triumph 10
S Fuel pump question Spridgets 0
budk1953 Fuel pump question Spridgets 2
MadRiver Tiger fuel pump question Sunbeam (Rootes) 2
RedTR3 TR2/3/3A Rebuilding TR3 Fuel Pump question Triumph 5
Monark192 SU Fuel Pump Install Question MG 4
David_DuBois A different Fuel pump question Austin Healey 3
Michael Oritt Fuel Pump Question Racing 4
Michael Oritt Fuel Pump question Austin Healey 5
SCguy TR4/4A TR4 Fuel line to fuel pump question Triumph 8
MadRiver Fuel pump question Triumph 11
Sarastro Facet fuel pump question Spridgets 5
DerekJ Bellows Fuel Pump question Austin Healey 2
nevets fuel pump question Austin Healey 1
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
D MGB Fuel Pump MG 2
Martinld123 Electric Fuel Pump Austin Healey 6
