TR2/3/3A New shocks too short?
Snowkilts
I'm redoing the front suspension on my 3A with a few upgrades. I bought some GAZ shocks, p/n GT2-2272, which are sold for the 3A by multiple vendors. Put one on and when I took the ☼☼☼☼☼☼☼☼ realized that the lower control arm is not touching the rebound bumper. It's my perception that at full droop the arm ought to sit heavily on the bumper but maybe I'm wrong about this?
In any event I compared the new and old shocks. The new one is a good 5/8" shorter than the old one. Photo shows the two shocks at full extension:
I'm assuming this is a bad thing since at full rebound the suspension will bottom out on the shock rather than the bumper. Has anybody else run across this, and what did you do about it? I'm considering modifying the bumper to add maybe 1/4" shim.
TR3driver
Great Pumpkin - R.I.P
I agree, normally it should rest quite firmly against the rebound stop.
Personally, I would return the shock (or pitch it if necessary) for one that fits the application. The 3A suspension has little enough travel as it is, without reducing it even further! 5/8" at the shock is going to be somewhere around 1" at the wheel. Hardly an "upgrade" !
PeterK
I have Konis on my 3A. I made this before I installed them. Hope this helps.
TRMark
Bronze
About as close to OE as I have around here from my 63 TR4
malbaby
The other important consideration is to measure the "car at rest" length of where the shock will fit, as this will be your mean compressed/extended length.
This of course depends on what rating springs you have fitted.
sp53
The shocks are a real pain to get in—in my IMHO. Plus perhaps the original shock can extended to far to get an accurate measurement. I just do not think they played that close, but I could easily be wrong. Malaby’s idea of the springs or maybe something else in the shock tower might be the problem.
steve
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
mctriumph For Sale lever shocks from a 61 Morgan plus 4 Other British Classifieds 0
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Gliderman8 TR6 New shocks (damper) question Triumph 4
Donald1107 TR2/3/3A TR3 Rear Shocks Triumph 11
D The best place to get shocks rebuilt. Spridgets 8
J Midget front shocks Spridgets 4
W Best source for Bugeye front shocks Spridgets 3
AngliaGT My '95 Dodge Dakota Needs New Shocks Other Cars 4
Michael Oritt Shocks and/or Springs Austin Healey 9
Z Front Shocks Austin Healey 19
P TR6 New front shocks & air in clutch Triumph 15
pkmh Rebuilding Armstrong Lever Shocks on a BJ8 Austin Healey 28
F Refilling and servicing Armstrong Lever Arm rear shocks Austin Healey 4
A Front Shocks Bushing Replacement Austin Healey 2
edkap2002 TR6 differential mounts, rear springs and shocks Triumph 1
JPSmit replace shocks in pairs? Spridgets 7
P TR6 Front shocks Triumph 11
nicko Front shocks Austin Healey 16
Rut TR4/4A Bilstein shocks Triumph 0
maxwedge5281 Koni Shocks Installation Austin Healey 18
M New Shocks for Otto and other winter projects Spridgets 22
S TR2/3/3A Koni shocks part number? Triumph 2
jfarris TR2/3/3A Whitworth fill plug for lever shocks Triumph 2
Boink Springs & Shocks Spridgets 2
T TR2/3/3A TR-3a Rear Shocks Triumph 1
M Replacing front shocks, torque setting? Spridgets 2
S T-Series girling shocks MG 0
glemon General TR Koni Shocks Triumph 19
B Front Shocks Austin Healey 6
B TR2/3/3A what adjustment should i select with Koni shocks onTR3? Triumph 4
69MGC MGC Lever Shocks are Toast MG 7
T TR2/3/3A Rear shocks and rattle Triumph 5
S Replace original suspension for shocks? Austin Healey 2
T "Cheese-Headed Screws" on Armstrong lever arm shocks Spridgets 2
T BSW Filler Plug Armstrong Rear Shocks? Spridgets 2
T Differences in Armstrong Lever Arm Shocks Spridgets 1
CZ_Dave MGB Is it worth doing the Shock Conversion Kit or Rebuilding Exsisting shocks? MG 16
Foura TR4/4A Part number for Monroe shocks on Moss telescopic conversion TR4A Triumph 1
RJS TR4/4A Replacement Front Shocks Triumph 4
mgedit TR2/3/3A Rear Shocks Loose Triumph 16
KVH TR4/4A Loose Rear Shocks on my IRS Triumph 7
T TR6 TR6 aftermarket rear shocks Triumph 35
K TR2/3/3A Harley Davidson shock oil for Lever shocks? Triumph 3
K TR2/3/3A Armstrong Lever Shocks Triumph 5
B 77 2500M Shocks TVR 0
Keith_M Rear Shocks Spridgets 5
Morris An argument against tube shocks... Spridgets 2
B Tube Shocks Conversion Austin Healey 19
D front shocks 100 m Austin Healey 12
