Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
Thread: CHASSIS SHIPPING Lotus Elan Plus 2
Discussions of Lotus Sports Cars
  1. #21
    Join Date
    Aug 2010
    Location
    Strafford, NH
    Posts
    1,727
    Thanks Thanks Given
    8
    Thanks Thanks Received
    14
    Thanked in
    Re: CHASSIS SHIPPING Lotus Elan Plus 2
    Quote Originally Posted by DrEntropy View Post
    [/COLOR]
    Yup. Take no chances. The body is attached by 16 or 18 fasteners, four fit folks can lift an Elan shell off the frame, BTDT. The +2 weighs a bit more, but with some Yankee ingenuity, planning and good tackle it should be do-able.
    Google would indicate the body can be be removed in about 8 hours. https://www.lotuselan.net/forums/lot...is-t30588.html That assumes a lift which I don't have so probably double that for jacking and un-jacking a dozen times for me without a lift. I'll figure about a week.
    Also note that Paul Matty has a chassis kit, original style chassis, that includes complete suspension and sundries at about twice the cost of the bare frame. https://paulmattysportscars.co.uk/pr...2-chassis-kit/ I should be getting shipping info soon. As you can tell, I still find the new unit attractive.
    Tom
    1960 TR3A TS73117 (under endless restoration, owned since 1964)
    1959 TR3A TS58023 (in case I never finish the one above)
    1969 Triumph Herald 13/60 (a whim)
    1970 Lotus Elan Plus 2 /0023/N
    1992 BMW325IC (fun to drive)
  2. #22
    Great Pumpkin DrEntropy's Avatar
    Join Date
    Sep 2005
    Location
    Elsinore, DK
    Posts
    33,137
    Thanks Thanks Given
    35
    68
    Thanked in
    Quote Originally Posted by Tom
    Understandable! The front uprights on these chassis are open box sections, near vertical. The drain holes are invariably plugged and rust becomes an issue. In the northeast, where salt is used to clear roads, it really makes things dicey where it comes to just patching the frame.
    '64 MGB, '67 Lotus Elan S-3 DHC,'69 Lotus Elan +2
    '78 Alfa Romeo Spider-undergoing surgery: O=\*/=O
    '84 300D Turbo-"Diesela"-Now my Daily: Oo|≣|oO
    '02 Toyota Camry- SWMBO's 'new-to-her' Daily. <sigh>
    Chaos & Mayhem PTY, LTD..C.I.O. & Floor Sweepervisor
  3. The Following User Says Thank You to DrEntropy For This Useful Post:
    TomMull (02-25-2019)
  4. #23
    Join Date
    Aug 2010
    Location
    Strafford, NH
    Posts
    1,727
    Thanks Thanks Given
    8
    14
    Thanked in
    Mine's a California car, no chassis rust apparent although no access to inside of the box sections or the vacuum tank but one side has gussets welded over the original welds at the bottom of the uprights, the other has fairly wide cracks in the same place but no gussets. Perhaps were not cracked when the other side was done. Further, both sides have considerable negative camber caused by movement in the uprights.
    With the body off, who knows what other frame issues will arise.
    Thanks for following my journey.
    Tom
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
