Results 1 to 15 of 15
Thread: How to clean a cloth wiring harness
  1. #1
    Jedi Warrior BoyRacer's Avatar
    Join Date
    Aug 2009
    Location
    Portland, Oregon
    Posts
    425
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    I am reusing a newer wiring harness on my BT7 ... fabric covered. Not greasy or oily - just dirty. Any ideas on getting it clean without damaging it?
    Richard Mayor
    Vintage Racer HBN7L-466
    Portland, Oregon
  2. #2
    Yoda steveg's Avatar
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,490
    Thanks Thanks Given
    78
    118
    Thanked in
    Re: How to clean a cloth wiring harness
    What about spray carpet cleaner? The kind that foams up then when dry you brush it off.
    Steve Gerow
    Altadena, CA, USA
    Maker of most complete Big Healey rear disc kit
    Check out my galleries:
    http://www.pbase.com/stevegerow
  3. #3
    Yoda HealeyRick's Avatar
    Join Date
    Apr 2004
    Location
    Massachusetts
    Posts
    5,627
    Thanks Thanks Given
    12
    28
    Thanked in
    Quote Originally Posted by steveg View Post
    I'd be leery of anything that leaves a residue you have to brush off as I'd be worried the residue would get caught in the weaving and be impossible to get out. I haven't done it so you'd have to test it first, but maybe wiping with alcohol would work?
    Rick
  4. #4
    Yoda John Turney's Avatar
    Join Date
    May 2002
    Location
    Concord, CA
    Posts
    3,423
    Thanks Thanks Given
    39
    24
    Thanked in
    Quote Originally Posted by HealeyRick View Post
    I'm thinking that wiping alcohol on/off would have the same issue. Also, alcohol might affect the colored thread. I would probably try Windex or something where wiping isn't required to soak it and let dry.
    John, BN4
  5. #5
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,490
    Thanks Thanks Given
    78
    118
    Thanked in
    You'd need something that would release the dirt and float it away. The carpet cleaner would release the dirt, then dry to dust; perhaps it could be blown off with compressed air. I'd think spray upholstery cleaner would be similar.
    I'd be worried about alcohol and the paint.
    Steve Gerow
    Altadena, CA, USA
  6. #6
    Join Date
    May 2004
    Location
    Fingerlakes in upstate NY
    Posts
    560
    Thanks Thanks Given
    2
    Thanked in
    I used alcohol on my wires once. Wiped off the color coded stripes! That was the wire not the cloth.
    I used Scotch guard on my new cloth wiring harness to protect it. A carpet guy gave me the industrial strength stuff. Though I haven't driven the car enough to know if it worked.
    Dale
    BJ7 frame up restoration of "the car that would not be restored"; began Dec. 2005, est. complete 2023
  7. #7
    Luke Skywalker RAC68's Avatar
    Join Date
    May 2010
    Location
    NJ Shore
    Posts
    1,983
    Thanks Thanks Given
    16
    Thanked in
    Boy Racer,
    When considering how to clean the fabric, remember that the fabric was used to allow a wet harness to drain and dry. Depending on the condition of the fabric (over time the heat and cold, wet and dry cycles take a toll and the treads grow brittle so would never consider physical adjuration). I would use a detergent like Dawn mixed in hot water and sprayed it on the harness. I would then rinse it with and water spray and allow to dry. If you want to take a chance, I would use a small amount of washing bleach in the washing mix to brighten some of the lighter colors but I would first test on a small section. Keep in mind that the threads of the woven cover are either strong enough to sustain the wet/dry cycle or not and, if not, the cover (not the harness) will need to be replaced. I would never expect it will look new.
    Good luck,
    Ray(64BJ8P1)
  8. #8
    Join Date
    Aug 2009
    Location
    Portland, Oregon
    Posts
    425
    Thanks Thanks Given
    Thanked in
    To be clear, the harness is out of the car. And, the cloth fibers are in very good condition. Based upon what Ray just said, I think I should be able to put the entire harness into a bathtub with a mild detergent and gently agitate to get it clean? I was originally concerned that there might some kind of plastic wrapping under the cloth that could trap water and not completely dry out.
    Richard Mayor
    Portland, Oregon
  9. #9
    Jedi Warrior BigGreen's Avatar
    Join Date
    Feb 2011
    Location
    Netherlands
    Posts
    560
    Thanks Thanks Given
    23
    4
    Thanked in
    Steam works wonders
    White Terry cloth to wipe it dry
    The least I can do is keep my CarClean.com
    Jaguar X type 2.5, 2003 Carnival Red Metallic
    Austin Healey HBJ8L/40871,MkIII ph2 April 1967 Original MGBeige, now BRGreen
  10. #10
    Luke Skywalker vette's Avatar
    Join Date
    May 2002
    Location
    Pa.
    Posts
    1,648
    Thanks Thanks Given
    13
    Thanked in
    Richard, here's what an old timer who ran a motor rewind shop told me once. When I was restoring my Healey the original starter was i terrible condition but still worked. I disassembled it and the innards were just coated with grease and grime. I took the field winding out and the cloth fabric wrap and insulation was just disintigrating. I asked the old fello if the winding could be saved and he told me to go home and gently wash them with soap and water, let them drip dry in the sun for a few days then paint them with automotive enamel. I told him I didn't have any enamel but I had some clear coat. He said then use that. I did exactly as he told me. That was 18+ years ago and the starter is still in the car and working today. A lot of hard summer driving every year.
    If your harness is in good shape, you could assist the drying with some low air pressure from the air hose.
    About TV Shows-
    "...you really can't restore a car in 10 days. I don't want to watch a race where people have to restore it in a week. It's not going to drive, and those cars never work. In real life, it takes years to get it right. " Jay Leno.
  11. #11
    Great Pumpkin Keoke's Avatar
    Join Date
    Apr 2004
    Location
    LosAngeles Calif.
    Posts
    12,538
    Thanks Thanks Given
    7
    Thanked in
    Quote Originally Posted by BoyRacer View Post
    Yep I think U got it right , use a bit of Dawn no bleach N the grease will be gone, I asked a baby duck---LOL
    1966 Daimler V8 Saloon; Safely Fast, Built to Last & and; Smooth as Glass.
    1966 BJ8 [ 2 ] Lil Red & Miss bLU
    1985 XJ6 Saloon
    1948 & 70 Lincoln continentals
    1973 Volvo P1800ES
  12. #12
    Member Westcoast M5's Avatar
    Join Date
    Mar 2018
    Location
    Vancouver, Canada
    Posts
    36
    Thanks Thanks Given
    1
    Thanked in
    You could always have it re wrapped. I believe auto sparks will rewrap it, or sell you the wrap to do it yourself. https://www.autosparks.co.uk
    Rob
  13. #13
    Join Date
    Nov 2003
    Location
    Boston, MA
    Posts
    1,218
    Thanks Thanks Given
    2
    3
    Thanked in
    This is how it has been done for decades. While it is out, take the time to closely examine all of the end connections and replace any that look questionable. Be careful not to cut back any of them if you do not know how much "spare" length you have to work with. While most can easily accommodate a half inch cut back, some cannot.
    Things I need:
    3/8 generator pulley for 1965 BJ8
    Please PM me if you have one for sale.
    All the pieces falling off my car were engineered to the highest British standards.
  14. #14
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,490
    Thanks Thanks Given
    78
    118
    Thanked in
    Richard - when you do the cleaning, would apprectiate hearing back on how it went.
    Steve Gerow
    Altadena, CA, USA
  15. #15
    Join Date
    Aug 2009
    Location
    Portland, Oregon
    Posts
    425
    Thanks Thanks Given
    Thanked in
    So far, very good. I took the smaller rear harness, put it in a 5 gallon bucket with some warm water and laundry detergent. Then, using a toilet plunger, I agitated it for about ten minutes or so. I then rinsed it thoroughly, I used a bath towel to blot up as much moisture as I could. I then used compressed air to blow out the connectors and the two wires that were encased in a plastic sheathing. Then I hung it up to dry. Its nice and clean and no damage was done to the cloth. The main harness is larger so I will do that one in my shop sink ( a laundry tub).
    Thanks for all the ideas. I love this forum!
    Richard Mayor
    Portland, Oregon
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
