Center rod, bracket and mirror info needed
Michael Oritt
I need some measurements of and information about the Spridget's "center rod", the "bracket" for it and the mirror that mounts to it, as shown on page 55 of the Moss Spridget catalogue.
1. What are the dimensions of the upper bracket (part nos. 19 and 20)?
2. How long are the rods (part nos. 26 and 28) and how do they attach to the car at their lower end?
3. How is tension applied to the rod to make it "tighter"?
4. How exactly does the interior mirror (part no. 35) attach to the rod and does it slide up and down on it? Also what is the diameter of the rod?
Thanks in advance.
zabond
on my 65 midget the rod is 3/16" dia & 12.1/2" long, the top bracket is 2.1/2"w x 3/4"deep and 1" out from frame, the mirror clamps to the rod and can be slid up/down, the rod tension is by the top acorn nut the rod goes through the bottom bracket then through the top bracket held in by the acorn[dome]nut. hope this helps
Russ
Michael Oritt
Michael Oritt
Russ--
This information is most helpful. I frequent the "Big Healey" forum and too often a "stranger" to a forum, particularly one with a car of different marque/model, is at best simply told to go elsewhere or at worst gets ignored. Because my Elva Courier uses a lot of spridget running gear I have on several occasions posted questions to the Spridget forum asking about a part, etc. I seldom received any replies and in any case I appreciate your responding to this request.
FYI I am inquiring because I would like to change the way the rearview mirror on my AH 100 is mounted and at the same time exert a better downward clamping force against the windshield frame. I am currently using a piece of SS 1x19 wire between the scuttle and the hardtop and the spridget mirror rod should not only allow me to exert more force but also provide a way to mount the mirror a bit higher and out of my line of sight forward.
nomad
I don't know how you could do this without negating the fold down screen arrangement on your 100.
Michael Oritt
Michael Oritt
Nomad--
To each his own but I really enjoy the car a lot more with a top in place--either soft or hard--and so does my wife. I installed the car's hardtop (shown below) about ten years ago and the car is way more comfortable at speed and a lot more air and water tight. I am still working on getting the side curtains to fit a bit better but this is, after all, an English roadster.
You're correct about the windshield but as far as I am concerned the 100's fold-down windshield serves no purpose except to wow the crowds at static car shows and I stopped attending them a number of years ago. That said, if for any reason I want to remove the top it is a simple matter of releasing four clamps and the tensioner rod will also be easy to undo, etc.
I see you are from South Dakota. Back in 2005 or so when AHCA Conclave was in Austin, Texas I drove my 100 from my home in Maryland across the Michigan UP and out to Bismark, then took a left and proceeded down to SD, out to the Black Hills and on to Texas. I am seriously thinking of doing the trip again to attend this year's Conclave in September. Perhaps our paths will cross....
HealeyRick
Michael,
I did something similar to what you are thinking of. I used the base and windshield mount and rod from an MGB and a day-night mirror from an E-Type (repro, it was pretty inexpensive). I did this because I didn't like the way the rear view mirror sat with the convertible top up. I did have to drill the windshield frame and pop rivet the top mount on and the mirror mount had to be shimmed as the rod wasn't thick enough. The mirror does not slide up and down, but I find the day-night feature is more of a benefit than the ability to adjust vertically.
Michael Oritt
Michael Oritt
Rick--
I actually started on this path a number of years back before I purchased my hardtop. My goal was to provide more clamping force on the front bow of the convertible top than was possible using the standard fittings that go to the windshield pillars.
I used some 1 x 19 SS wire and onto one end I swedged a threaded terminal rod while to the other I swedged a jawed terminal. I attached the jawed terminal to the middle triangular buffer that goes to the center of the 100's front bow. Then I drilled a small hole (3/16") in the scuttle in front of the rear view mirror, passed the threaded terminal down through the hole and pulled the top down against the windshield frame by using a knurled nut. This works quite well and with the proper rubber seal the top does not leak in the rain, at least along the top of the windshield. Both fittings are made by Johnson rigging and they and the wire can be purchased at West Marine stores.
When I installed the hardtop I adapted the above setup to it and that is how things now stand but I would like to use solid rod versus wire in part for esthetics and mainly to get the mirror off the scuttle where it is prone to vibrate and also get it out of my forward sightline. I like the concept of a day/night mirror. I also like your work and in any case this is another example demonstrating that I simply have too much time on my hands....
nomad
Michael
I plan on being in the Black Hill's for the Conclave this fall. I'll be in a little Healey....A red Mk3. Datsun repowered. Always did like the 100-4 but prefer the Sprite's for their "toss-ability".
Kurt
nomad
I should elaborate. By "toss-ability" I suppose that I mean that they are easy to throw around but also I like the size since there is more room on the road to throw them around. I'm currently working on a Lotus Elan that fits that description as well.
Anyway, I'll be keeping my eyes open for your red 100-4 this fall.The beer is on me!:cheers:
G Separate pitman arm from center tie rod Triumph 4
timsgolf Center Dash Switch Plate Painting Austin Healey 5
B TR4/4A What is this Steering Wheel Center? Triumph 6
BoyRacer Moss Motors Center Consoles Austin Healey 0
J Wanted MGA Coupe rear window glass center section MG Classifieds 0
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
jfarris TR2/3/3A Ground location for center panel lights 56 TR3 Triumph 5
WHT Center-Shift Bellhousing Austin Healey 10
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
M TR6 Center cap for wheels Triumph 2
D TR2/3/3A center panel indicator light color Triumph 10
R Turn Signal Knob goes off center Austin Healey 9
J Nut size for BJ8 center console trim piece Austin Healey 8
D 62 center shift gearbox Austin Healey 11
R Center Gearbox Input shaft bearing Austin Healey 9
D 1962 center shift gearbox cover Austin Healey 7
AUSMHLY Distributor cap center pin melted Austin Healey 5
BillyB62 TR2/3/3A Wood dash & center console examples Triumph 7
Rut VTO center caps Spridgets 3
glemon TR5/TR250 Steering Self Center Triumph 4
maxwedge5281 steering tight in center position of steering wheel Austin Healey 2
KVH TR4/4A Center Console Recovering Triumph 10
L Light for BJ8 Center Dash Panel Austin Healey 17
K For Sale TR3 rear cockpit center capping Triumph Classifieds 0
J Wanted Triumph Herrld center bonnet moulding, [chrome strip] Triumph Classifieds 0
55modified Splined mag wheels? Who makes or machines them without center adapter? Austin Healey 5
R Wanted TR4A / TR250 Center Console Triumph Classifieds 1
G BJ-7 Center Shift Gear Lever and bush Austin Healey 4
Joe Schlosser Transmission Tailshaft housing off center Spridgets 3
Lukens For Sale Classic center armrest/console for tr2, tr3, tr3a, tr3b, and tr4 Triumph Classifieds 0
H Third Member - Differential - Carrier Housing - Center Section - Gear Set Cleaning Spridgets 4
A turn signal knocked off center Austin Healey 14
charleyf TR2/3/3A Center main cap engine Triumph 4
Raven62 Superlite wheel center caps Spridgets 0
Lukens TR2/3/3A TR2-3-4 Center armrest Triumph 3
GTP1960 TR2/3/3A Arm rest center console? Triumph 14
D Re-fitting vinyl on center upper console bj8 Austin Healey 3
Bob_Spidell Center shift boot Austin Healey 13
K TR2/3/3A Distance from center wheel hub to center wheel hub? Triumph 6
Got_All_4 General TR How can I remove the finish on this center console for my 7 Triumph 9
Got_All_4 Wedge Can this center console be refurbished Triumph 10
M TR2/3/3A Finding top dead center Triumph 6
maxwedge5281 center shift transmission shifter Austin Healey 3
Boink Center justification on everything now... FORUM Navigation Questions 3
A TR-3A wooden center dash panel photo??? Triumph 3
F Adivce on how to center jets of SU HD6 carbs Austin Healey 3
B TR2/3/3A tr3b center exhaust hanger Triumph 3
P Turning to Top Dead Center Austin Healey 11
Boggsy64 MGB What is the purpose of the center assembly at tranny mount? MG 2
MikeAH100M Center Support for 100 Dashboard Austin Healey 8
