Ideas needed for under dash radio mount, cup holders, glove box
BoyRacer
Listers,
I have eliminated the heater on my BT7 nasty boy, resto-mod, since I never needed a heater anyway. I now have a clean slate to create a true glove "box", with some kind of mounting for a radio and hopefully some cool looking cup holders. Any input , and/or photos, will be greatly appreciated.
Richard
steveg
I was looking at this VW cup holder a while back on eBay. Very discreet when retracted:
BoyRacer
BoyRacer
Thanks. That's just what I need.
HealeyRick
You could probably do something like this that would put the speakers nearby: https://newhillgarage.com/2011/11/12/article-49-upholstery-of-center-console/ You'll want some kind of amplifier if you want to have any hope of hearing any sound in a Healey. I have a Becker Europa Stereo II AM/FM that has an attached amp that looks appropriate and with an adapter cable that hooks up to the pin adapter in the rear allows me to play music through my iPhone.
If you don't mind cutting your kick panels I have 6" round speaker there and the enclosure makes a nice little speaker box that gives plenty of bass.
Michael Oritt
Richard--
I have one of these units installed in my 100 which has a five-speed with center-shift stick.
https://www.cupholdersplus.com/model-a-vagabond-shorty-console.html
Depending upon how much room is created by eliminating the heater you might be able to adapt one of their units to accommodate a radio, etc. However, Rick's point about being able to hear a radio is very well taken and after dicking around with various radio/speaker combinations I finally gave up and went soundless for a number of years. Then, after I got hearing aids I purchased a bluetooth device which links to my cell phone and I can actually hear either music or vox at speed.
Michael Oritt
The attached pic somehow got inverted 90 degrees but in any case shows how the unit I linked to above fits on my 100. Because the Toyota box provides a center shift I am able to use this drink holder which is designed to sit on a fairly flat section of tunnel, and this would not work with side-shift cars.
BoyRacer
BoyRacer
Thanks for all the great info. I'm going with the VW cup holder and put it under the parcel tray. That Healey Marque article completely changed my thinking.
I'm using '95 Miata seats that have speakers in the headrests but I'm also taking Randy's idea and adding speakers in the kick panels. At least I'll have some tunes during city driving.
Patrick67BJ8
I had provisions for speakers in my kick panel area when I had Jule do my new frame and they appear to be headlight buckets. I didn’t end up doing the speakers but I have the option of doing them so they fit flush and are not obtrusive.
Deleted member 21878
i bought a 5v transformer for around 6 bucks. it is small and hidden up on the bulkhead. there are 2 dongles on it for charging. i use one to charge a good bluetooth speaker and keep it on the shelf until ready to listen to music. then move it out on the tran tunnel and bluetooth to my phone. since the transformer has two dongles, i can charge the speaker and the phone if need be. speaker is loud so it works pretty well. and if i am at a car show, i can continue to listen to music and not use the car battery.
but then, i don't have speakers in my seats....
vette
For the cup holders I felt that the stow away holders under the dash would be in the way of the knees and everything else when they are deployed. Unfortunately in the Healey cup holders are in the way no matter where you put them. If there is no radio or heater the ones like Michael have look pretty appealing. But I decided to put mine to the rear of the shifter, centered on the tunnel between the seats. I made my own out of metal and first made them shallow then decided to give them some height to accommodate deeper cups. I covered it in vinyl and it just sets on the tunnel. Unfortunately I am not good at taking pics while I'm working and I don't have a pic of it in the car. But it works well. It works as a nice arm rest when there are no cups in it. You do have to be aware of the cups when shifting but on long day trips an easy shift with handy cups is most pleasant. See Pics.
Michael Oritt
Vette--
Actually I do have a heater (see pic) though as I remember the unit in 6-cylinder cars is a lot larger.
I'd like to have a cup-holder mounted aft of the stick but I am afraid it would interfere with shifting much as you describe.
Michael Oritt
I see that in my last post the image is inverted and in an earlier post it is rotated 90 degrees ccw. Seems to me that some other folks experienced something like this a few years back and the problem lay somewhere in a setting. Can anyone "straighten me out"????
Editor_Reid
Platinum
I opened it (from your post), then saved it, then opened it (from my desktop) and rotated it, then saved it, then uploaded it here:
I don't know what to tell you to do differently because I can't duplicate the glitch.
steveg
I use an Android phone with a Windows PC. I email the photos from my phone to my gmail account on my pc. I open them from gmail and, if necessary rotate and/or crop, then make a screenshot which I upload to the forum. I like the screenshots because the file size is smaller.
On the Mac, you can probably rotate your photo in iPhoto. You can then use command-shift-4 to make a cropped screenshot.
Unlike Reid, I've had a problem with rotating the photo on my desktop, then having it still upload sideways. I get around that by uploading a screenshot.
Michael Oritt
Reid/Steve--
To be clear, I followed the same procedure with these two photos that I always do: I take the shots on my android phone, gmail them to myself as attachements and save them on my Mac, and they appear in correct format on my Mac.
This issue first appeared yesterday when I made post #7 and the image was 90 degrees out in a ccw direction, but I charged it off as an unimportant glitch until the same thing occurred in today's post #12 where the image is inverted by 180 degrees.
I know I could have adjusted their "rotation" in my saved files to compensate for what is happening when I upload them to BCF but swince I am quite certain that this same phenom happened a few years back I thought I would bring it to the attention of the "proper authorities" rather than simply fix it by making adjustments to the image in my computer.
Let's see if it happens when I post the image from post #12 again without any manipulation of it in my computer.....
Michael Oritt
Hmmm--Still upside down on the forum and right side up in my computer!
Editor_Reid
Platinum
How are you creating the "Attached Thumbnails" format? I don't even know what the process is to do that. (And notice the thumbnail is in a gray, rounded rectangle.)
Try the Insert Image tool above the text field of a new post. It's right of the Link tool and Unlink tool, and left of the Insert Video tool. Look in the Quick Reply box below ... see it?
(Notice that when I uploaded your image to my post there is no gray, rounded rectangle and no "Attached Thumbnail" title.)
steveg
Michael - on your Mac, when you get the image correctly rotated, take a command-shift-4 screenshot of it. Then you don't have to worry about the orientation when you upload it.
I've tried to upload these when I've rotated them on my computer and it doesn't "stick".
Another way that works is to rotate a pic in your phone gallery, using the "edit" command so that when you download it from gmail, it's already correctly oriented.
When you upload the picture to your Forum entry, double-click on it for the window where you make it medium or large.
Use the "Go Advanced" button, then scroll down to "Manage Thumbnails" to delete extra thumbnails.
Michael Oritt
Steve/Reid--
Thanks for the suggestions and I will do things that way in the future as an imbedded image is certainly better than an attached thumbnail.
As to Reid's question, I have simply been clicking on the "manage attachments" button and then selecting a downloaded file off of my computer which always posts a thumbnail. I'm still not sure how things got inverted/rotated on these two occasions but in any case will try using the keystrokes as suggested.
RJS Top Frame Repair - ideas needed Triumph 8
D help...? Air Filter ideas needed...nothing fits! Spridgets 23
B Cove Paint Color Ideas Austin Healey 10
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
L Tyre diameter less than 680mm but bigger than 640mm, any ideas? Austin Healey 11
Y MGB Battery relocation ponderings and considerations [and ideas?].... MG 6
pbraun Ideas on tires for Bugeye with 13x6" wheels Spridgets 3
nathandarby67 Ideas for organizing hardware when plating Restoration & Tools 6
Sarastro General Tech Any good ideas for removing liners? Triumph 20
Sarastro TR4/4A Any ideas for repairing jack damage? Triumph 13
Jim_Gruber Need your ideas on a How To Do it - SpeedHut Gauge Install Spridgets 11
Rut TR4/4A Shop with lift ideas Triumph 21
maxwedge5281 third brake light ideas Austin Healey 34
B TR6 Seat Belt Brackets - Any Better Ideas? Triumph 1
M TR4/4A Covers at side of H frame over the trans tunnel...ideas please. Triumph 9
M General Tech Creative ideas, shop equipment, fabbing techniqes, etc Triumph 0
chuckmcb Baffled by BJ8 Ignition light...any ideas? Austin Healey 9
MikeAH100M Ideas for an Alloy Racer Austin Healey 13
trotti Stuck drum - any ideas? Austin Healey 5
CJD TR2/3/3A Engine Storage Ideas Triumph 2
T TR4/4A Lowering my TR4a - ideas? Triumph 18
catfood Any Ideas? Austin Healey 7
aeronca65t Christmas Card ideas Other British Cars 5
RickB Any temporary Bugeye grille ideas while I send mine off? Spridgets 16
bthompson Using the brakes kills the engine! Any ideas why? Spridgets 17
I Bugeye bonnet hinge bolt head busted off - ideas? Spridgets 8
Mychael Ideas for a parcel shelf in a Frogeye Spridgets 8
T ideas on fixing - one carb keeps "rusting" Triumph 4
I TR6 TR6 difficult to start - ideas? Triumph 6
M Any Ideas Triumph 26
K Any ideas for a Handbrake Warning Light??? Triumph 11
bighealeysource ideas on how to fix dents on frame Austin Healey 15
Darrell_Walker Alternator cleaning ideas Triumph 10
ahealey1004 bn4 drum brake issues...any ideas? Austin Healey 7
apbos TR2/3/3A Ideas for moving my TR3a????? Triumph 4
M 948 vs 1275 - Looking for opinions and ideas Spridgets 34
Brosky Upholstery makers in England? Any ideas? Triumph 21
T Ideas on fixing this? Triumph 19
eschneider leakdown test readings - ideas? Restoration & Tools 12
A TR4/4A TR4 mistery engine problem - any ideas Triumph 14
startech47 Any ideas? Spridgets 8
gubba Slight front end shimmy @ 52 mph any ideas? Triumph 13
T Ideas on getting this bolt unstuck Triumph 42
RickB New steering wheel, ideas about adapting? Spridgets 23
bighealeysource Ideas on where to get ID plates stamped Austin Healey 3
M Need Engine Swap Ideas for '76 Midget Spridgets 21
T TR2/3/3A TR3A vibration - looking for ideas Triumph 38
RickB Ideas about modifying seats to fit rollbar? Spridgets 6
R front emblem rehab ideas??? Triumph 16
scubabatdan Ideas on cleaning a yellowed rear window? Spridgets 1
