Rear axle - small leak .....?
SteveHall64Healey
My major winter project this year was removing and restoring everything from the drive shaft back to the brake drums. This included removal of rear axle, brakes, suspension, shocks, etc. 4E29F22B-5156-488A-A274-95695E0C3EFE.jpg t4E29F22B-5156-488A-A274-95695E0C3EFE.jpg
Re-assembly went smoothly, including setting the wheel bearing clearance to within spec. New gaskets and o-rings were used throughout. When complete, I over-filled the differential by about 500 ml, allowing the excess to drain away through the upper-most port in the diff.
A few weeks later, I noticed a very small amount of oily liquid running down the backplate. See picture attached. Total volume maybe 5 ml. Pulling the drum revealed a completely dry and clean wheel hub and brake assembly - no oil at all. If this means that the hub is not leaking into the brake area, could the small amount of oil be from initially over-filling the differential? I checked the fluid level in the differential and it is still fully topped up.
thanks
steve
vette
Wipe it up see if it does it again. Try to identify a track from you top vent on the diff to where it dripped. Also if it is really overfilled, the oil expands with running and heat. Make sure it is filled just to the bottom of the fill plug.
S
SteveHall64Healey
Thanks for the suggestion. There is no fluid track from the vent.
I cleaned it up thoroughly and shot another 100 ml of oil in. That was 6 hours ago and most of it ran back out from the filler plug over the last 4 hours. So far, no oil is appearing at the backplate...
S
SteveHall64Healey
Thanks Steve. The gaskets came from Ahead4Healeys and they are quite thick, at 0.014”.
the car has not yet been driven, so the bearing really hasn’t been spun. The area outboard of the backplate is completely dry....
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
KVH General Tech Rear Brakes and Solid Axle Triumph 2
drooartz Bugeye jack points to remove rear axle Spridgets 18
R BJ7 Rear Axle Maintenance Austin Healey 5
A Rear Axle Oil Seal Austin Healey 4
W Rear Axle Hub Seal Austin Healey 8
R For Sale TR6 REAR AXLE HUBS Triumph Classifieds 0
drooartz Rebuilding rear axle Spridgets 19
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
M TR2/3/3A Rear Axle Bearing Grease Triumph 5
J TR6 Differential / Rear Axle Triumph 1
Tr3aguy TR2/3/3A Rear Axle Rebuild Triumph 3
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
BN6_2197 Rear Axle rearing up Austin Healey 12
K Rear Axle Breathers Austin Healey 17
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
John Turney BN4 to Early BJ8 Rear Axle Austin Healey 12
P TR2/3/3A Rear axle hub dis-assembly Triumph 1
T TR2/3/3A Will cable ties hold rear axle rubber buffer securely? Triumph 7
P MGB Noisy Rear Axle / Differential MG 1
R Rear Axle Restoration Austin Healey 6
Lin Rear Axle Hub Nuts Austin Healey 3
E For Sale Tr3 rear axle, rear end Triumph Classifieds 6
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
K TR2/3/3A The rear axle "tube" seal replacement. Triumph 6
warwick-steve Oil for rear axle? Austin Healey 3
J Wanted Need tr3 rear axle housing Triumph Classifieds 0
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
B How often should you change the rear rear axle oil Austin Healey 9
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
Jim_Gruber Source for 3" cotter pins for bump rubber on BE Rear axle Spridgets 5
T TR2/3/3A Rear Axle Vent Triumph 12
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
B TR2/3/3A Checking oil in rear axle Triumph 2
D TR4/4A Seals on TR4 Solid Rear Axle Triumph 5
F Leaking rear axle hub [BT7] following instalation of new seal! Austin Healey 9
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
K TR2/3/3A Odd question re: rear axle hitting fuel line? Triumph 4
K TR2/3/3A Rear axle hub removal? Triumph 8
catfood BN1 Rear Axle drain plug. Austin Healey 7
KVH TR4/4A Here'a Another Rear Axle Hub Question/Problem Triumph 7
Don_R TR2/3/3A Rear Axle bearings Triumph 3
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
bugedd Rear axle bump stop Spridgets 7
AUSMHLY BJ8 rear axle oil seal Austin Healey 6
AngliaGT Easiest Way to Remove/Replace Rear Axle Seals/Etc.? Spridgets 9
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
GTP1960 TR2/3/3A replacing rear axle buffer? Triumph 6
MadMarx Wedge IMSA TR8 - Spax on the rear axle Triumph 3
