TR2/3/3A Valve Adjustment?
karls59tr
Bronze
How often should the valves be adjusted on a TR3? How can you tell when they need adjustment? Should they be adjusted warm? Any other valve adjustment tips?
CJD
Funny...GM and Ford always said to adjust hot...but Triumph gives the cold adjust numbers. So set them cold.
If they start to make a lot of noise (chattering or one valve clicking above the others)...then it's time.
If you spend a lot of time at highway speeds using unleaded gas...check about every oil change.
If you have an old rocker shaft and arms, then a feeler gage will not give an accurate gap. It bridges any wear marks on the arm tips, giving a larger actual gap than measured. Use a dial indicator for worn shafts and arms to get true gap.
I make it a habit to check valves at every oil change, although that's probably overkill.
TR3driver
Great Pumpkin - R.I.P
The TR4 workshop manual says to run the valves every 6000 miles, but I've never done it that often unless there is a problem. Normally, the clearances will only change very slowly as long as the oil is kept clean and so on. So I only do it once a year, as part of what I think of as a "major tune-up".
In addition to excess noise as John mentioned, poor idle quality is another symptom of incorrect valve lash (particularly if they are too tight as a result of valve seat recession). Not getting a clear peak when adjusting mixture is another symptom.
STeve 1958
Pull all the spark plugs and gap them while you can still find your feeler gauge. This makes the engine easy to turn by hand. Then use the rule of nine.
I bought a feeler gauge and when I got home I found it had a .009 and a.011 but no .010. I just used .011 and kept them a little tight.
Steve
DavidApp
When I started to run my engine I had a valve tick. Checked the clearances again and it still ticks. So I removed the valve cover and ran the engine and put pressure an the rockers in turn till I found the culprit. I did noticed that I was getting oil to the rockers.
The ticking rocker was not lose in fact it seemed a little tight so I slackened the adjuster right off to check for wear on the end of the rocker. No wear but the bushing was worn allowing the rocker to move up and down on the shaft.
Have to order new bushes and shaft. I do have a spare that I am cleaning up to see if that can be pressed into service.
I suppose the morale of the story is a ticking valve may not have too much clearance but have a worn rocker bush.
David
poolboy
Or an bad spark plug wire...I adjusted and checked (obsessively) valve lash even swapped rocker assemblies trying to eliminate a louder than normal tick on 'tick over'.
Gave up...but much later for some other purpose I checked wire resistance..I found a bad one, replaced it and then the ticking sounded normal again.
6TTR3A
I just modified the feeler gauge to compensate for rocker arm wear at the
valve stem contact point.
TR3driver
You can actually buy feeler gauges with narrow tips, for that reason.
Personally, I prefer to have the rockers rebuilt when they get that worn. It's easy to remove the shaft, and there is a service out here that does them. I don't recall the numbers offhand, but the total cost with shipping was very comparable to what I would spend for just the parts to do it. The results came back looking like new, I still don't know if they actually replaced the arms or just gave them a flash coat of copper. But only the pedestals and caps were obviously original.
They've moved up north, but originally they were located in the same city where I worked.
https://www.rockerarms.com/
DavidApp
Started to clean up the spare rocker assembly.
The rockers look like they are bronze bit the tip is steel? I need to check them with a magnet. No wear on them.
David
TR3driver
The workshop manual says case hardened steel.
DavidApp
Got the spare one cleaned up and checked that the oil passage was clear to all the rockers. No play on the rockers so I swapper the rocker assembly out with the one on the car. Took the opportunity to re-torque the head bolts.
Set the gaps to 0.010" inlet and 0.012 exhaust as the book says. Or has that been updated?
Still get some ticking. Maybe that is the normal amount on these motors.
David
TR3driver
Unless you have a TR2 or early TR3 with cast iron rocker pedestals; the exhausts should be set to .010".
But .012" won't hurt anything, except a little more noise.
And yes, they always make some valve noise. The curse of solid lifters.
DavidApp
Hello Randall
I thought I remembered they were both 0.010" but could not find the info in a quick leaf through my books so I went with 0.012" to be safe. I well re set later this morning.
The noise sounds more even now. Before there was a definite location for the louder noise.
David
TR3driver
My apologies, misremembered the change point. The aluminum pedestals were introduced to production at TS12564E, which isn't even TR2, let alone an early one! My earlier engine must have been retro-fitted at some point.
Anyway, the .010" number can be found in the back of the factory workshop manual (Engine section of the TR3 supplement), or in Practical Hints (page 31 in the 6th edition)
https://drive.google.com/open?id=0B2H2NJt34OffNjQ4MTkyNjItZTVmYi00M2U2LWJhYWUtMjEyZDgxMzUyNzUw
bobhustead
Karls59
You would have a hard time getting the flatness (parallel to the shaft) and the roundness (perpendicular) right.
DavidApp
A file will probable not make any impression on them. The tips are very hard.
A machine shop with a flat grinding wheel would be able to do it.
David
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
R TR2/3/3A Rule 9 Valve Adjustment Triumph 8
G Valve adjustment and easiest way set cam position Austin Healey 15
S TR2/3/3A All new valve train - no adjustment at rocker arms Triumph 12
L TR6 Bypass valve adjustment Triumph 1
wangdango BJ8 valve adjustment? Austin Healey 3
Martinld123 Why too much valve clearance after adjustment? Austin Healey 2
Boggsy64 MGB Valve adjustment MG 6
Darwin GT6 GT6 Valve adjustment Triumph 6
nevets Valve adjustment intervals? Austin Healey 15
6 Valve adjustment stock 948 Spridgets 11
glemon Valve Adjustment/Wear Triumph 4
Rut 1275 valve adjustment Spridgets 10
Rut timing, cams, valve adjustment Spridgets 6
BOBBYR VALVE ADJUSTMENT Austin Healey 1
G MGB MGB valve adjustment MG 3
M 1275 valve lash adjustment "shade tree" Spridgets 10
Marvin Gruber Valve adjustment Part 2 Jaguar 11
Marvin Gruber Valve adjustment Jaguar 15
I Valve adjustment basics - help please Spridgets 21
M valve adjustment? Triumph 5
I TR6 TR6 valve adjustment help Triumph 3
Woodie valve adjustment Spridgets 5
66healey Valve adjustment Austin Healey 11
newmexTR3 valve adjustment q's Triumph 4
T Valve adjustment 'how-to- on YouTube? Triumph 3
R Valve Adjustment Question Austin Healey 12
malice Valve Adjustment Triumph 2
TRclassic3 TR2/3/3A TR3 Valve Adjustment Triumph 10
H Valve adjustment question MG 10
M TRactor Motor Valve Adjustment Sequence Triumph 5
sparkydave How sensitive is the valve adjustment? Spridgets 11
B valve adjustment Austin Healey 7
R Valve adjustment Austin Healey 6
S Valve Clearance Adjustment Austin Healey 17
M Valve adjustment MG 12
J Valve adjustment help. Triumph 5
tahoe healey valve adjustment Austin Healey 14
sim looking for 2 valve spring kippers for a 948 Spridgets 3
R Valve Drain Pipe Austin Healey 13
R T-Series Valve gap for an MGTD 1953. MG 5
6 Valve Oil Seals Spridgets 10
P TVR Big Valve 4.3 TVR 0
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
J MGB BRAKE VALVE ? MG 11
jehuie PCV valve explanation? British Motor Corp 5
R 3000 Heater Valve Austin Healey 4
T TR2/3/3A valve springs Triumph 15
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
T TR2/3/3A valve guides and piston clearance Triumph 6
