Results 1 to 8 of 8
Thread: Will cable ties hold rear axle rubber buffer securely?
  1. #1
    Join Date
    Apr 2012
    Location
    Raleigh, NC, USA
    Posts
    593
    Thanks Thanks Given
    Thanks Thanks Received
    1
    Thanked in
    1 Post
    I am planning to replace the rear axle rubber buffers (p/n 115456) on my TR3 with the ones that are split to allow them to fit around the axle. I am thinking of using long cable ties around each side the of the rubber buffer, rather than the stock wire method. Has anyone tried using cable ties, and will they securely hold the buffer in place? Thanks!
  2. #2
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    2,272
    Thanks Thanks Given
    10
    26
    Thanked in
    Re: Will cable ties hold rear axle rubber buffer securely?
    Hello Bob
    I used a combination of wire ties and a cable ties. I did have a bit of trouble getting the wire ties wound up to my satisfaction and wished I had bought several spares.
    My concern with cable ties is will they become brittle and disintegrate.
    David
    TR3A TS75524L
  3. #3
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    19,034
    Thanks Thanks Given
    4
    86
    Thanked in
    Yup, I've used tie wraps. Got the black UV-resistant ones, they seem to have held up well. They do get hard, but I've never seen one break.
    Make sure you get them as tight as possible though; I have had trouble with them slipping off. Apparently, hard cornering can put some side force on the rubber stops.
    Randall
  4. #4
    Join Date
    Apr 2012
    Location
    Raleigh, NC, USA
    Posts
    593
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Thanks for the quick replies!
  5. #5
    Yoda Geo Hahn's Avatar
    Join Date
    Sep 2001
    Location
    Mt Lemmon, Arizona
    Posts
    9,330
    Thanks Thanks Given
    8
    Thanked in
    I used wire tightened with my twirly safety wire pliers, but Harbor Freight sells stainless steel zip ties that might work well.
  6. #6
    Join Date
    Apr 2012
    Location
    Raleigh, NC, USA
    Posts
    593
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Geo, good idea about the stainless steel ties. Thanks!
  7. #7
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,115
    Thanks Thanks Given
    20
    Thanked in
    Twisting wire is all in the first set up and is easier on round surfaces. Practice on a pole about the size of the axle. Start by getting the wirer tails about 2 inches longer than needed, or 4 inches bigger than the pipe. Make the first twist by hand and have both tails at about 45 degrees to each other with a nice clean symmetrical fold/ twist in the center. Then grab the tails down low right at the top of the first twist with some piles, and pull back some as you twist. Maybe twist around 4 times and trim.
    IMHO the wire is best because it sinks down in the rubber creating a small grove and will stay in the grove. Masonry supply stores sell special pliers and wirer with small loops on the end and you pull back on the special pliers and that does a perfect twist. They should have wire to fit an axle because the diameter is small.
    steve
  8. #8
    Yoda TR4nut's Avatar
    Join Date
    Jan 2006
    Location
    Nacogdoches Texas
    Posts
    3,869
    Thanks Thanks Given
    3
    Thanked in
    I’ve used stainless ties from Band-it on a few cars now and really like them. Was lucky to find a used kit so cost was still cheap.
    Randy
    70 TR6 - running
    59 TR3A - slumbering
    64 TR4 - got another one!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
