62 tri-carb fuel line connection
  • Thread starter Deleted member 21878
  • Start date
i am having a bit of trouble trying to come up with a conversion from my fuel line to my carbs.
i bought a new main fuel line from Healey Surgeons and it came with a fitting soldered to it on the carb end. i bought a pipe fitting with a 1/4" hose barb on the other side. threads up nice, but it leaks.
not sure what i was... or wasn't... thinking at the time but the fitting bottoms out before it seats. So it will leak.
Today i went to the auto parts store, a couple of them actually, and came up with a plan that looked better. i bought 5/16 inverted flare fuel line fitting. but when i got home they would not thread up. wrong thread. So i went to Lowes and looked at compression fittings. again the 5/16 would not thread up.
So it looks like only a 1/4" pipe thread is the right thread. back to the original fitting. but again it is too deep a thread to seat the fitting on the line.
as i have it right now, i took the neural out of the 5/16 compression fitting and put it in the pipe fitting i have hoping maybe it will press enough edge to seal the line. it was too late to test today. but i know this can't be the right answer.
i was hoping someone here had bought bought a fuel line from the Surgeons and had found the answer. i can also try to call them in the morning and see what they suggest. i went on the Moss website to see what they do. they show a 7" hose there but it is NA.
suggestions?
Healey Nut
I have an untouched tri carb set up in my shop ready for my project . I will have a look at it on the weekend when Im in the shop engine building at what the connection is and take a couple of pics .
Does the fitting you have maybe just need a copper washer ?
It to freakin cold to venture to the shop right now .
No. It is where the main line ends and a hose connects to go to the front carb. The book shows a hose with a fitting. I thin maybe the hose was like a brake line flex hose with a fitting on the end. That probably has a more shallow female end. And probably some sort of flare in it to fit the male fitting on the main line.
And dont go go out for this. Ain’t worth it.
Healey Nut
Not sure if this helps ?
John Turney
If it's like mine, the main (hard) line ends in a flare fitting. The tubing is 5/16" dia with a flair and a male flare fitting on it. It's like a brake fitting, only larger.
the main line has a male fitting on it. thinking it is a 1/4 BSF fitting? i have looked at the Healey Surgeon catalog and it appears they make a hose with a connection for the first carb, which is what i need.
also think i could buy the "fuel line to front carb" for the MGA from Moss. Cut the line in half and make it work. they look to have the same main line fitting. just don't know if that line is 5/16 or 1/4. Going to try and order a line from HS first.
Thanks
John
man, i swear that was not listed a few days ago. it showed n/a. but yes that is what i am looking for.
well except, if you look at the picture of the hose it shows a fitting on both ends. that would not be correct. the one end just uses a hose clamp on the carb float bowl. so i wonder if they just added this as something that would work. if it comes the way it shows, you would have to cut the line. And then i wonder if you could not just use the one for the MGA. it is only 18.49 vs 33.99.
either way, i am fine. got a hold of Healey Surgeons today and they had one to ship me. So i should have that in a couple of days and be fine. Now i need to decide if i want to put the fuel filter i was using back in or leave it out.
while i was waiting for this hose... i decided i did not want to fight with the nuts on the air breathers anymore so i took a cue from someone here on this site and drilled a hole in each stud. then slid a cotter pin in each one. well except the very back one on the back carb. it is too hard to see the hole to get the pin in. so on that one i put the nut back on. at least on that nut, i can get my half wrench (cut in half) on it to turn it.
also made sure the nuts would go over the holes (and cover them) in case i ever wanted to go back to nuts but i can't imagine wanting to do it. So much easier to pull the pins.
My line came today from Healey Surgeons and it looks like it is going to do the job. i am guessing they take one of the other lines and cut one end off of it. then add the robber end for the hose connection. this hose was like 20" long and only needs to be about 9. i cut it in half and move the rubber end.
the only change for me is that i had a fuel filter installed at this location. i have a solid line from the pump to this flex hose so a good place. these cars did not come with a fuel filter and i wonder what the thinking is on installing one. i have a brand new fuel tank, new pump and lines. when i took the filter off there was some small bits of sediment in there but not a lot.
thoughts on putting the filter back in? easy to cut the line again and insert the filter.
John Turney
Each of the carbs and the pump should have fine screens on the inlets. Those should be sufficient, but my filter is near the pump under the rear seat. The way my rear seats are held in place, it only takes two screws to remove each one.
John
thanks for that. you made me think for a minute. first thought was my car is not a concours restoration.
So i put the fuel filter back in. while the screens in the carbs may do the job, it has got to be more of a pain to clean them than to clean one filter if the need arises.
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
D Tri carb: order of installation question. Austin Healey 5
Healey Nut Tri-Carb Project Austin Healey 213
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
D 62 tri-carb upper fulcrum pins Austin Healey 4
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
lbcspinners 1962 Austin-Healey 3000 Mk II BN7 Tri-Carb 2-Seat Roadster: for sale on BaT Austin Healey 2
D Grose valves / Tri-carb Austin Healey 11
D Tri-carb PCV valve Austin Healey 61
C Tri carb Austin Healey 7
T Tri-carb questions. Austin Healey 10
J BT7 [Tri-Carb] Restoration Upgrades Austin Healey 2
D 62 tri-carb tuning question Austin Healey 8
D BT7 Tri-Carb Distributor Cap Austin Healey 9
D BT7 tri-carb linkage set up Austin Healey 23
D BT-7 tri-carb Two more questions Austin Healey 18
D BT-7 tri-carb ring gap Austin Healey 10
D BT7 tri-carb installing my crank Austin Healey 4
D 62 / BT7 tri-carb engine Austin Healey 16
D 62 tri-carb wiring harness Austin Healey 10
HealeyPassion Tri-carb intake manifold balance tube size Austin Healey 10
steveg Rare colored tri-carb BT7 on eBay Austin Healey 13
davidb AH 3000 tri-carb throttle shafts Austin Healey 13
W Barrett Jackson Auction 62 2 Seater Tri-carb only brings 48k Austin Healey 19
Norman Tri carb - overheating issue ???? Austin Healey 10
K Tri-carb help Austin Healey 11
K Tri-carb help please Austin Healey 0
AH67 62 MKII Tri Carb, done with some pictures Austin Healey 9
M WTB: Tri Carb Choke Linkage Parts Austin Healey 8
BoyRacer What are MK II [tri-carb] 2 seaters selling for? Austin Healey 12
D BT7 Tri carb Backfire Austin Healey 2
M Tri Carb Camshaft Austin Healey 4
B tri carb problems Austin Healey 17
B Gas mileage Tri-Carb Austin Healey 2
A tri carb on ebay Austin Healey 14
C Cold air box for Tri Carb 3000 BT7 ??? Austin Healey 9
G tri carb vapor lock Austin Healey 30
J Seeking tri carb help Austin Healey 16
M 100-6/ 3000 tri carb set up Austin Healey 13
Patrick67BJ8 Ruddspeed Tri-Carb Set-up Austin Healey 9
6 BN7 tri-carb will not start Austin Healey 7
6 BJ8-BT7 Tri-carb Conversion? Austin Healey 7
B PCV Valve Tri Carb Austin Healey 11
C Tri - Carb assistance ! Austin Healey 5
Dave Richards WOW! a "RARE" tri-carb Austin Healey 12
C AH 3000 Tri-Carb conversion. Austin Healey 4
V Choke cables for tri-carb Austin Healey 5
