TR2/3/3A Coolant tap on TR3 block
DaveC
I have now purchased two block taps from Moss Motors, and one from Victoria British and they either don't fit or they leak.
Does anyone know exactly what thread size is needed, as I'm just going to put a blank in the block.
Thanks in advance for help!
dave
sp53
If you are into originality, take some black silicone or whatever and plug the hole on the original tape from the back and then if you want to drain the block remove the whole tape.
Sarastro
I have had more leakage problems with those @%!# valves than with anything else. I gave up, long ago, and just use a plug.
Here's what I did on the TR engine. The washer is soft-soldered to the bolt, so it won't leak, and the black thing is a washer I made out of delrin. You could use any solf material for the washer, probably even unhardened aluminum or a copper washer. The bolt is 1/2 fine threaded; it appears that the thread is not a pipe thread, which I would have expected.
Lin Frustrated - Coolant Leak at Drain Tap Austin Healey 2
Patrick67BJ8 Coolant Overflow Tank Austin Healey 21
B TR6 Triumph tr6 coolant leak Triumph 4
B Oil (or Coolant) Leak Austin Healey 10
FlyingCat Spitfire Losing Coolant Triumph 12
M TR6 1973 TR6 Coolant Type? Triumph 5
R Coolant temperature gauge Spridgets 8
Govtslug TR6 Coolant Temp Q Triumph 4
T TR2/3/3A TR3 coolant hoses Triumph 2
K TR2/3/3A Hot day coolant overflow issue.... Triumph 1
nevets Coolant Temperature Austin Healey 13
L BMC A-series: Oil in coolant British Motor Corp 6
Got_All_4 TR6 Oil in the coolant in my TR250 Triumph 6
K TR2/3/3A Radiator coolant level? Triumph 5
M TR6 '72 TR6: Oil in Coolant Triumph 25
W TR2/3/3A location of the coolant drains on a tr3a Triumph 4
Got_All_4 Wedge Tapered coolant hose for a PI car. Triumph 3
Paulus TR4/4A Coolant pressure Triumph 5
gfholl Coolant Leak Spridgets 9
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
M Coolant 'overflow' when not overheating.... what's up? Spridgets 34
S TR2/3/3A Replacement of Engine Coolant Drain Triumph 3
B All the coolant in the wrong place Spridgets 17
G TR4/4A Thoughts on my coolant Triumph 12
D TR2/3/3A TR3 Engine dumping Coolant out its rear end - HELP Triumph 5
D TR2/3/3A Block coolant passages plugged - pull the head? Triumph 46
JFS Wedge Low Coolant Light Triumph 7
Boink Waterless Coolant - thread from the AH forum Spridgets 18
PatGalvin TR2/3/3A Coolant System Hoses Slipping Triumph 5
RJS TR4/4A Head Leaking Coolant after Coolant Flush Triumph 15
Jim_Gruber Replacing Spridget Coolant Spridgets 21
T TR4/4A Coolant in the oil - again. Triumph 18
Jim_Gruber Coolant Bypass Nipple on 948 Welded Closed - Advice needed Spridgets 7
P Coolant level indicator wrong? Jaguar 4
sparkydave Coolant hoses Spridgets 5
T TR4/4A Oh crud - coolant in the oil Triumph 33
W Waterless Coolant Austin Healey 4
R TR2/3/3A Normal vs Max acceptable coolant temperature? Triumph 14
RAC68 Waterless Coolant Austin Healey 29
B TR2/3/3A coolant expelled Triumph 14
Keith_M 1275 burning coolant Spridgets 20
S Coolant Loss Spridgets 32
S Air/Fuel Mixture affect on Coolant Temperature? Spridgets 2
M oil in coolant Austin Healey 16
M TR4/4A Coolant. Triumph 7
mgedit TR2/3/3A Coolant spit out of overflow Triumph 20
Keoke Waterless Coolant Austin Healey 12
S TR6 waterless coolant Triumph 6
MY66AH Coolant Leak From Fill Neck Spridgets 3
tahoe healey Coolant choices Austin Healey 5
