Numbered Spark Plug Boots?
Michael Oritt
No, but I would suggest instead using the appropriate number of tie-wraps on each of the wires so that you can ID the correct one with low or no light.
Healey Nut
Get some electrical wire numbers tape books . They come in a book and are thin strips of tape numbered 0 to 9 and you wrap it round the wire the number is repeated along its length so you can wrap around double and not cover the number up .
Keoke
RAC68
As I remember, when accepting delivery of my BJ8P1 in April, 1964, each spark plug wire had a number (Black number on white color collar installed just past the plug boot. Is this what you are looking for?
Ray(64BJ8P1)
Patrick67BJ8
Ray(64BJ8P1)
Not sure about that color, but I bought a set from a Healey supplier that had black number on yellow collar.
steveg
I had the yellow ones from Moss. They were printed on a tube which was cut into slices as with a razor blade. Cuts were sloppy.
Replaced them with clip-on ones from one of the speed equipment suppliers. They easily fell off and I had to build wire clips to hold them on (retiree - too much time project).
IMO the shrink-on ones look like the best solution yet.
grimes6
I think you are searching for the boots which were fitted to the earlier cars and finished with the BJ7. The BJ8's used the wrap around tags.
Michael Oritt
I'll admit that using tie wraps/electrical ties on the boots as shown in the photo does require one additional step of having to count and then convert to a number (which can't be higher than six) but this is good exercise for all: For we analog folks it helps ward off senility and for those who grew up in the digital age it will help you relate to your parents/grandparents and is consistent with driving a 50-65 year old car.
RAC68
Hi Michael,
Good thing you don't have a 12 Cylinder under the bonnet.
Very nice looking engine compartment.
Ray(64BJ8P1)
Michael Oritt
Hi Michael,
Ray(64BJ8P1)
Yes Ray, that would require using both fingers and toes
John Turney
Replaced them with come clip-on ones from one of the speed equipment suppliers. They easily fell off and I had to build wire clips to hold them on (retiree - too much time project).
I bought my black on yellow ones from moss several years ago. Quality was much better then.
healey106
Contact Roger Moment, to get numbered spark plug boots. He had them made a number of years ago and I now I use them on my Longbridge BN4. Check with him if he still has any in his inventory
steveg
So Individual boots are numbered 1 - 6 -- not slip-on sleeves? Do you have a picture?
healey106
the individual boots are numbered and are not slip-on sleeves. I will try to get a photo soon. currently everything is covered for the winter sorry
:driving:
K
Kainopong
In the concours book, the early 100-6 and first series Abington BN4 used the same sleeve as the 100 except the numbers went to 6 (obviously)-they were about an inch long and the numbers were molded into the rubber.
K TR2/3/3A Numbered brass plates on the firewall above the battery? 59 TR3A Triumph 4
trglory TR2/3/3A TR3a spark plugs Triumph 1
CARSINC Spark plug thread size Spridgets 2
K TR2/3/3A Heavily carboned spark plugs in relation to a failed FO8 gasket? Triumph 12
L T-Series Spark plugs again ? MG 2
B TR6 Gas on spark plugs Triumph 7
Carlbanan56 MGB No spark and engine cranking slow MG 10
kodpkd Spark Plugs Austin Healey 3
P TR2/3/3A NO spark at points Triumph 36
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
K TR2/3/3A Spark plug inspection Triumph 5
B Healey Won't Start - No Spark Austin Healey 38
L TR4/4A spark plugs Triumph 9
BierRunner TR6 Life without Spark :( Triumph 25
J TR2/3/3A No spark in TR3 Triumph 20
G TR4/4A TR4 Lacks Spark! Triumph 22
M For Sale NOS Champon NA-10 Spark Plugs Jaguar Classifieds 2
tr6web TR6 No spark 1972 TR6 Triumph 35
PAUL161 T-Series Odd spark plug encounter! MG 10
MadRiver No Spark Austin Healey 18
K TR2/3/3A Testing spark plug wires..... Triumph 11
Gliderman8 TR6 Spark plugs for TR6 Triumph 7
B Anyone have spark advance data for Piper camshafts? Spridgets 1
B TR4/4A Spark plugs Triumph 1
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
G Opinion on spark plug color Austin Healey 15
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
S Spark Plugs Spridgets 2
AUSMHLY BJ8 NGK Spark Plugs Austin Healey 13
B MGB 1972 MGB Project Blue First attempt and fixing no spark and other checks MG 67
AUSMHLY Spark plug wires 7mm or 8mm Austin Healey 21
longbridgehealey Spark plug wires Austin Healey 8
AUSMHLY When to replace spark plugs Austin Healey 1
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
K TR2/3/3A Spark Plug Gap? Triumph 4
FlyingCat Spitfire Spark to Coil Triumph 23
tahoe healey Spark Plugs Austin Healey 20
Got_All_4 General TR Anybody Hear or Use This Hot Spark System? Triumph 10
mgedit TR2/3/3A Lost Spark Triumph 26
jfarris TR2/3/3A Which spark lug to use - copper/platinum/iridium Triumph 14
S No spark, im in the dark. Spridgets 6
G spark plugs Austin Healey 10
B Spark Plug Wire Caps Austin Healey 16
Sopwith_Camel MGB the mysterious disapearing spark MG 21
S Wedge Need help with TR8 no spark Triumph 7
vickxxx T-Series 1952 MGTD spark plugs. MG 4
S MGA 1956 MGA negative ground, True Spark Ignition distributor MG 3
B TR6 Spark plug gap Triumph 5
toysrrus TR6 Spark plug question Triumph 23
K TR2/3/3A Spark Plug cuts and diagnosing? Triumph 13
