TR2/3/3A Putting windshield back together
Redoakboo
During the restoration of my 54 TR-2, I removed the windshield to replace the rubber and Dzus fittings. I have the frame and side mounts together and need some hints on the best way to install the upper and lower rubber weather trim. I also have new dzus fittings along with some aluminum washers. How do I install these washers to the fittings? I know I have to first put the dzus fasteners through the hole but what I do to attach them ??
Dick
R
Redoakboo
Dzeus fitting worked fine. I followed Post #157 which was very helpful in getting the bottom rubber installed, now for the top. The screw driver push worked great for the bottom rubber, but not for the top. P 157 doesn't address this install. I even removed one of the side molding to try and slide it up the side and on to the top; it keeps coming out of the slot.
Any hints on this would be a great help.
Dick
CJD
For the top, the side braces must come off. The top rubber then slides into the slot, and finally the ends are trimmed to match the side braces once they are re-installed. If the top rubber will not slide easily, then the previous rubber is likely broken off and cracked, still remaining in the channel.
Post #158 shows all this.
M_Pied_Lourd
Kinda like a Chinese Food Menu John...Order by number :cool:
Cheers
Tush
DennisT
Hi,
I am putting my windshield back together and noticed the two of the threaded backing pieces are missing inside the windshield channel, these are the ones that hold the three screws that hold the windshield to the stantions. I wanted to ask if anyone knows the thread size of the three screws that hold the windshield to the stantion. Also I also need to know the thread and size of the miniature countersunk machine screw tha holds the threaded backing plate in the window channel which accepts the 7/8 and 1 inch oval head machine screws . I called moss and they could not give me the specs on either of these screws. Does anyone have an answer for me? Thanks Dennis
CJD
I’m pretty sure the 3 stanchion screws are Witworth...the big 3 should stock them. If you are making the pieces yourself, then tap the countersunk screw to a standard size. You will need a witworth tap for the mounting screws, though.
Dr_Mike
I ran 10-32 screws into the empty threads and they seemed to fit perfectly. Not sure if this is close to Whitworth and I would not like to mix them up. Same thread (10-32) appears in other small places on the car!
I installed the Dzus fasteners in the hood as described by Moss (and others) using a flathead bolt, but make sure the washer on the top is small enough not to smash your paint .
I have the opposite problem with the hood fiiting! too big a gap on the left, but I am reluctant to drill into the paint. Yes, it fitted perfectly when it was primed!
John: the numbers will be very helpful!
Dr. Mike
martx-5
Actually, those are BA (British Association) threads. The 10-32 screw you used is very close to a 2BA size, which measures 0.185" x 31.4 tpi. A lot of threads smaller than 1/4" on the TR are BA threads. Besides having a different pitch, the angle of the treads is also different. See the link below.
This link is to British Tools & Fasteners which has taps & dies for all sorts of British threads.
Most of the BA sizes that I have run into on my TR3 are 2BA and 4BA.
https://britishfasteners.com/threads/
Dr_Mike
Thank you: I confirmed that ( very easily) with Moss so you have saved me difficulty down the road: I hope someone local has the right tap as I try to avoid cross border shopping.
Michael
DennisT
The link to British fasteners is very helpful, they have the tap, I ordered it and it came two days later. What I need to know I’d the size and pitch of the tiny flat head machine screws that hold the small backing plates which the oval head 1”&7/8” screws thread into. My frame has two missing and I need to fabricate new ones which I will drill and tap with the two different size threaded holes.
thanks,
Dennis
CJD
If you are making the pieces yourself, then tap the countersunk screw to a standard size. In other words...it doesn't really matter.
GregW Putting the windshield back together Austin Healey 10
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
algot1901 Putting the doors on Other British Cars 11
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
69MGC MGC Putting a 12v battery in the trunk MG 10
T TR2/3/3A Is there any problem in putting TR6 plastic wheel covers & TR6 lug nuts on TR3 wheels Triumph 4
B General TR Putting the rebuilt gear box back in the TR6 Triumph 1
F Chocking the rear wheels and putting in gear when jacking up the front Austin Healey 8
2billydavies TR2/3/3A looking for suggestions on putting engine back in Triumph 17
S Putting my 68 on the road. Spridgets 12
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
S TR2/3/3A putting the sleeves into the block Triumph 7
K TR2/3/3A Putting an XKE engine in a TR3? Triumph 10
K TR2/3/3A Putting traction bars on a TR3? Triumph 3
T TR5/TR250 Downside to putting TR250 fan on TR3 Triumph 13
Trevor Jessie Putting a 1275 in a rubber Bumper car Spridgets 17
K TR4/4A Putting H6 SU's on a TR4A intake manifold. Triumph 1
B TR6 Putting a 205 75 tire on a tr6 Triumph 4
B TR6 Putting a Tr4 top on a Tr6 Triumph 14
G Where you 6 guys putting fuel pumps? Triumph 10
J Putting the IRS on stands ??? Triumph 5
J Putting BE dash together from box of random parts- Spridgets 12
tomshobby TR6 putting scuttle door on 76 TR6 Triumph 9
J AH 1962 - Putting on Front Fenders Austin Healey 8
G putting on new top MG 5
T First time putting front hubs on - any tips Triumph 7
doughairfield TR4/4A Putting the motor back in the TR4 Triumph 9
Got_All_4 TR2/3/3A Putting a J type in a TR3A Triumph 14
hondo402000 TR6 TR6 Final Paint pics and Putting it back together Triumph 31
K TR4/4A Putting aTR4 motor and trans in a TR3 Triumph 4
T Putting the clutch master cylinder back together Triumph 13
UmmYeahOk Dammit! Quit Putting Holes in My Car!!! Triumph 32
pjsmetana Spitfire Putting the Spit in a car show saturday Triumph 2
liljohnTR250 TR5/TR250 putting new top on TR250 Triumph 7
J Putting my head back together. Triumph 3
Newkie Putting weatherstipping on windscreen MG 11
J putting the diff back together tonight Triumph 2
Thor Putting in 1275 motor into 1500 Midget Spridgets 4
7 Putting the front wheel bearing back together. Triumph 0
L Putting Humpty Dumpty Back Together Again Austin Healey 3
Steve Putting it all back together MG 3
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
D TR2/3/3A Windshield glass doesn't fit Triumph 6
P Post-War Other Herald Windshield: Is it the same as.... Triumph 2
D TR2/3/3A Windshield assembly question Triumph 6
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
T TR2/3/3A TR3A Windshield Question Triumph 4
