TR2/3/3A Crankshaft Pulley Configurations
mastaphixa
Bronze
I have run across 2 different crankshaft pulley configurations. In the attached image on the left side is a solid backed pulley half and on the right is the stamped style pulley half that I am used to seeing. The front half of both are identical. Has anybody else see this style of aft pulley half before?
TR4nut
Interesting. I’ve only seen the right one. Any idea what car had the left version? Any chance it is home made?
CJD
Whichever of those you decide to use...be sure to use a speedy sleeve for a good oil seal!
M
mastaphixa
Bronze
John, the speedi sleeve repair is kind of how I got into all of this. I was inspecting the hub and noticed a deep groove in it and started looking at speedi sleeve repairs and when I measured the hub it had quite a taper on it and it was too small for the speedi sleeve that people usually use. I popped a hub and pulley off of a locked up engine I have and it had a really good hub (with a little pitting in the seal area, so it will need a speedi sleeve anyway) and I ran into this unusual configuration of rear pulley.
Steve Baker
Popeye TR4/4A Crankshaft pulley recommendations: One piece alloy, two-piece steel, wide, narrow...? Triumph 12
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
T can't find timing marks on 1275 crankshaft pulley/damper Spridgets 8
GTP1960 TR2/3/3A Moss Crankshaft pulley failure Triumph 23
C Crankshaft pulley / damper Austin Healey 5
M For 1974 MG Midget - Crankshaft pulley bolt is 1 5/16"? Spridgets 4
M Spitfire need a crankshaft pulley for 1978 Spitfire Triumph 0
vette Timing Cover crankshaft pulley seal Austin Healey 6
Tugboat Crankshaft Pulley Question Triumph 4
regularman Crankshaft pulley nut for 1500 engine Triumph 5
kyreb1862 80 B Crankshaft Pulley MG 6
R Crankshaft pulley bolt MG 8
Colin8 1098/1275 Crankshaft Pulley - Damper Spridgets 3
abarth69 Crankshaft pulley bolt Spridgets 1
tony barnhill 1275 Crankshaft Pulley Spridgets 2
BritSpit Removing Crankshaft Pulley Nut Triumph 22
R 1500 midget crankshaft pulley nut removal? Spridgets 2
Brosky TR6 Diameter of crankshaft pulley on TR6 Triumph 17
B Spare crankshaft pulley for BN1? Austin Healey 0
G loose pulley on crankshaft Triumph 3
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 2
B TR6 Crankshaft long seal surface Triumph 5
MKIII_Joey Crankshaft Bearing Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
B General MG Crankshaft Nut Removal MG 4
W Crankshaft Oil Seal Austin Healey 3
B MGB Mgb crankshaft end play shims MG 2
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
M TR2/3/3A Crankshaft Sludge Plug Removal Triumph 6
T crankshaft (rear) bearing leak Spridgets 2
T Wanted Wanted - 1956 TR3 Crankshaft Triumph Classifieds 0
R Wanted 3 main crankshaft MG Classifieds 0
glemon TR2/3/3A Crankshaft Question Triumph 3
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
AUSMHLY Crankshaft Starter Nut Austin Healey 10
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
P TR2/3/3A Crankshaft Thrust Washers Triumph 4
M TR2/3/3A Crankshaft Oil Galley Plugs Triumph 7
S TR4/4A Fair price for a crankshaft? Triumph 2
charleyf TR2/3/3A crankshaft hardening Triumph 2
Gerard Wanted: 1275 Crankshaft Spridgets 3
G Crankshaft Rotational Freeplay - What's going on with this engine? Austin Healey 12
O Wanted TR 3 Crankshaft please... Triumph Classifieds 1
P Replacing the crankshaft damper [harmonic balancer] Austin Healey 15
C Tough Bolt on front of Crankshaft Spridgets 16
TRMark TR4/4A Prepping Crankshaft Triumph 4
D TR2/3/3A crankshaft shims to align timing sprovkets Triumph 4
