Spitfire Engine Back Plate
FlyingCat
The deeper I dig, the more I find! Today I just realized that the former owner of my 1980 Spitfire has taken almost all the bolts out of the engine back plate, bless his heart. Finding replacement bolts is no big deal. So here's my question: Aside from putting those bolts and spring washers back, is there anything else I need to be aware of? There doesn't appear to be a gasket or anything else holding fluids in. I just want to be sure. Thanks!
R Engine Number Plate Austin Healey 2
L TR2/3/3A Engine plate question Triumph 5
L First 100 Engine Serial Number Plate Austin Healey 13
R TR6 Engine Plate Gap? Triumph 2
Jim_Gruber Engine Adapter Plate Diagram Spridgets 5
M Attaching Info Plate to Engine Spridgets 1
Rut TR4/4A Engine number and body plate Triumph 5
WillR MGB Rear engine plate MG 8
KVH TR4/4A Front Engine Plate Curve Triumph 4
dklawson Sorry... Urgent Request for Friend - Marina Front Engine Plate Other British Cars 2
dklawson MGB Sorry... Urgent Request for Friend - Marina Front Engine Plate MG 3
Scotsman TR2/3/3A leaking front engine plate Triumph 4
R BN1 & BN2 Engine # Plate Finish Austin Healey 25
mt10flyer TR2/3/3A Front Engine Plate Triumph 8
memphis Engine Side Cover Plate Oil Leak Austin Healey 15
bighealeysource Installing new engine ID plate Austin Healey 7
S MGB MGB engine mounts - "extra" plate? MG 2
Z 100 engine/gearbox adaptor plate Austin Healey 3
vping Aluminum rear engine plate MG 9
steveg Rear Engine Plate sealing question Austin Healey 8
Lin Engine number plate Austin Healey 5
L help with engine backing plate MG 3
L replacement engine number plate? MG 6
A Rear engine plate split in two! Spridgets 9
Mickey Richaud Engine ID Plate MG 4
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
R TR6 question re: Engine Oil Triumph 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
