Fuel pressure
aero3113
My engine is set up with a fuel pressure regulator, but it didn't have a pressure gauge. I wanted to see what my fuel pressure is so I bought a gauge and installed it on the regulator. With the key in the on position the fuel pump turns on but I'm not seeing any pressure at the gauge?? How can this be?(engine runs fine) Shouldn't I see pressure at the gauge with the key on? I didn't start the engine today to see if there was any difference, raining today. This is on a Chevy 350.
roscoe
I'm assuming your gage has a range of something like 0 to 10 psi and you are not using a 500 psi gage that might not be sensitive enough.
Does your regulator have more than one port that can take a gage? Be sure your gage is on the down stream side of the regulator. Other than that I have nothing. It is possible that your fuel pressure is low but high enough to keep the float bowls full when running.
aero3113
aero3113
Here’s a pic of how it’s installed. It’s possible it’s set too low to read.
Michael Oritt
Aero--
If the regulator is cranked all the way closed your fuel pump may still run continuously depending upon what kind it is as some of the Facets hammer on regardless of whether or not the engine is running. In any case you should set your fuel pressure regulator up with the engine running and at different rpm's. If at that point you have no indicated pressure you might have a bad gauge.
steveg
See the previous thread from 10 days ago:
https://www.britishcarforum.com/bcf/showthread.php?115059-Holley-fuel-regulator-questions
I have a similar regulator setup with a Facet gold box pump. When the float bowls are full, the pump keeps running, but zero pressure shows on the gauge.
I was loosening the 4 screws to bleed the pressure out, then starting the pump again to display the approximately 2 psi the regulator is set at. I could then take the car for a drive, during which no fuel problems, then observe the gauge displaying zero pressure like the picture above.
I then timed 60 sec of flow into a gallon can and observed 27 gph (18 gph needed for BJ8).
Gave up worrying about it as everything seems to be working properly and I've driven it 30 miles since then.
vette
Most float needle valves can only hold back up to about 7 lbs. Anything more than that is a good chance of pushing past the needle valves. That includes and American down draft carb or an English SU. Typical early, old school carbs operate on about 4 lbs.
If fuel is weeping past the needle valves you might not see any pressure on a gauge.
RAC68
Hi All,
I have noticed that modern (fuel injected) cars typically use high pressure pumps that continuously flow fuel to and from the engine. Pressure is maintained to supply a sufficient flow for engine combustion with excess flowing back to the tank. This seems to allow the pump to maintain a constant pressure without the generated resistance inherent in a stop and go operation. Although non-continuous running pumps, like our Healey's SUs, were designed for low pressure and stop and go operation. However, replacements this type of unit with a pump designed to operate continuously would require a bypass valve built within the single path pump to allow excess fuel from building pressure or have a fuel backup cause problems within the pump.
I replaced the original pump in my TR7 with a continuous running electric pump a while back and this thread started me wondering what would happen if the bypass valve in it or a continuous running Facet pump installed on a Healey gets plugged or fails?
Just a thought,
Ray(64BJ8P1)
RAC68
Hi All,
Good point Steve. That is probably why AC Delco also provided an input filter on my TR7's continuously running pump. I wonder if installing a return tank line on a more powerful continuously running pump supplying the correct fuel pressure and volume to the carburetors via a regulator would provide even greater reliability and performance? But then again, why go to all that trouble when the SU has been quite reliable and has satisfied my Healey's fuel requirement for the past 54 years.
Ray(64BJ8P1)
steveg
...I wonder if installing a return tank line on a more powerful continuously running pump supplying the correct fuel pressure and volume to the carburetors via a regulator would provide even greater reliability and performance? But then again, why go to all that trouble when the SU has been quite reliable and has satisfied my Healey's fuel requirement for the past 54 years.
Ray(64BJ8P1)
According to Des Hammill, such return line setups have been used by racers when the SU float bowls weren't keeping up with power requirements.
In my case, I never had an SU pump; my car came with a West German plastic SU-style pump IIRC from Beck Arnley. When I started having delivery problems, I tossed it and went with the Facet, which has worked flawlessly for probably 18 years.
red57
Aside from racing applications, some production cars, like the Datsun 240Zs, had the return line. I always understood it was not to increase fuel delivery/flow but rather to help fight vapor lock by having a constant supply of cool fuel from the tank replacing the 'cooked' fuel in the lines in the engine bay.
For the last 25 years I have used Carter constant flow rotary pumps in the 2 to 4 psi range and no regulator with good results.
Deleted member 19315
Absolutely correct regarding the return, its a common set up on race cars and those with high under bonnet temps to mitigate for vapour lock. Its a simple enough mod and works best if the return goes back to the tank rather than the pump suction side ( the large tank volume helps with cooling). Its easy to set the carb delivery pressure with a regulator but does need a pump that will tolerate constant running as the system constantly circulates fuel. I've had my best success with the facet pumps doing this as the SU's tend to have a lower (3 to 4 psi delivery for a given volume) so the loss with the tank return flow is hard to compensate for and maintain proper delivery pressure. I run 3.5 PSI from a facet pump via a malpassi regulator, its not best practice to leave the gauge in place as its offers more leak paths if something fails.
Michael Oritt
I am with Red here and use the Carter 2040 pump on both my Ginetta G4 (Ford pre-crossflow 1498 cc) and Elva MK IV (Coventry Climax FWB 1460 cc) both of which are fitted with two Weber 45DCOE's. On both engines I have the fuel pressure gauge and adjuster that have been the subject of this string. They are set to approximately 4.5 psi pressure which holds from low to high rpm's, at least with no load as I have not observed the setting during dyno sessions.
At one time I was experiencing fuel delivery problems with the Elva Courier--MGA 1622 with twin 1-3/4 SU's supplied by a Holly Blue (higher pressure pump) also regulated by the Holly fuel pressure adjuster and gauge. I considered doing a fuel return set-up but finally solved the issue by increasing fuel pressure beyond the recommended 4 psi to about 5 or a little more which solved the problem and never resulted in flooding, etc. A return line might ensure delivery but requires more fittings, may lead to increased temperature/less density of fuel, etc. and is best avoided if possible.
In any case I have had absolutely no fuel delivery problems with the Carter pump and if and when the double headed SU on my Healey or the Holly on the Courier should break (before I can sell it) I will go over to the Carter as it has proven to be trouble-free for several years of racing conditions.
RAC68
Hi All,
That's really interesting and something I hadn't thought of. In our cars, I can easily see the reasoning for countering vapor lock. However, since return lines are common on modern fuel injected sedans that don't appear to have issues with under bonnet heat, I seem to remember someone mentioning it was present there for flow and to maintain constant pressure to each injector. Could it be that modern cars use this solution to counter a totally different issue then that which motivates Healey owners to implement a return line?.
Ray(64BJ8P1)
dklawson
With an electric pump in a street you can prevent vapor lock by mounting the pump at the rear of the car below the fuel tank rather than mounting it in the engine bay. This keeps engine heat away from the pump and pumps work better as pushers than pullers.
Michael Oritt
John--
I have one as well--rebuilt/converted a few years' back by Dave DuBois--and have it wired so that I may select BETWEEN one motor or the other via an "On-Off-On" switch mounted through the bulkhead behind the driver's seat. I assume you have wired your pump so that one of the "On" positions connects both sides of the pump to a hot lead.
Please correct me if I am wrong but--assuming proper motor operation and unimpeded flow--why would running both motors supply more fuel and/or more fuel pressure? I have always assumed that the limitation of flow and pressure is a function of the pump's design and operation and not a lack of power to it.
My 911 has two facet pumps either of which can be switched on . I just tried both on with the guage refitted as it's not something I usually do. I can confirm both on gives 3.5 psi as does one or the other. I didn't bother checking delivery rate. In neither case did the webers flood.
The twin pumps is a nod to the race cars of the 70s which ran two pumps for reliability.
Fuel injection systems require a constant output and high pressure. The system design often includes an accumulater to further reduce pump related pressure fluctuations. They usually run recirculation too. Very different to our relatively simple installations.
In essence an SU pump will give 3 to 4 psi and doesnt really need a regulator as the float valves on SU cars can cope with that pressure.
Double ended pumps may deliver more volume I'm sure some one will chime in with an answer. Recirculation is a good way to ameliorate for vapour lock if its a problem for you after all the usual heat protection has failed.
Michael Oritt
Haasad--
Though the double-headed pumps might be a good thing in a race application my understanding is that they were primarily fitted to cars with two fuel tanks, such as some of the Jags and, I believe, Aston-Martins, and that they were set up to select between tanks versus run simultaneously.
RAC68
Hi All,
Self regulating pumps, as the intermittent SU or possibly the continuously running Facet, were designed to maintain a max fuel delivery line pressure. If this is correct, adding pumps will not add additional line pressure but will only stimulate the self regulating internal function the pump employs.
Also, the 2-headed SU pump uses 2 triggering heads to activate 2 solenoid coils on a single central pump chamber. The regulating function of the pump is to maintain a max fuel line pressure and is shared between the 2 halves of the pump. As a result, the pump would maintain the same max fuel line pressure whether running 1 or 2 halves simultaneously.
Is my understanding correct?
Ray(64BJ8P1)
BobHaskell SU Fuel Pump Pressure Austin Healey 1
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
B Fuel Pressure Regulator Spridgets 5
KVH General TR Fuel Pump Pressure Triumph 16
T TR2/3/3A Is 5.5 lbs too much fuel pressure? Triumph 9
M TR4/4A Fuel Pressure Regulator Installation. Triumph 3
N Fuel pressure regulator? Spridgets 10
A 100/4 Fuel pressure advice needed Austin Healey 1
bthompson What fuel pressure does a Weber DGV like? Spridgets 2
M How Do I check Fuel Pressure at Injector Rail 99 XJ8? Jaguar 5
S Fuel pressure Regulator is it really needed? Triumph 9
Henson80MGB Newbie w/ low fuel pressure issue MG 11
TR4 TR4/4A TR4 Fuel Pressure Triumph 20
mrsprite fuel pressure question Spridgets 6
T Fuel pressure regulator settings???? MG 7
T Recommended fuel pressure Spridgets 32
M 1987 XJ-6 Fuel Pressure Jaguar 9
P T-Series MGTD Fuel Pump Pressure MG 2
healeyboz fuel pressure question Spridgets 6
R correct fuel pressure Austin Healey 4
6 What Fuel Pressure? Spridgets 7
Bob Claffie Too much fuel pressure Austin Healey 9
Morris Midget EFI fuel pressure problem Spridgets 10
P fuel pressure problem MG 2
T Fuel pressure regulators Spridgets 25
H Fuel pressure regulator question MG 2
kennypinkerton Fuel pressure test gauge? Alfa Spider... Other Cars 2
G fuel pressure Spridgets 4
T fuel pressure, roll bar Spridgets 15
P ideal fuel pressure for webber or dellorto carbs Triumph 11
Hegg Excessive Fuel Pressure - how do I stop the leak? Triumph 8
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
A TR6 How many fuel filters-TR6 Triumph 25
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
