TR6 Timing adjustment
Firsttimer
It’s winter so of course i’m fiddling with my 1975 TR6. I decided to check the timing and the initial setting looked pretty good. However when I went to loosen the nut to allow me to turn the distributor, I discovered that the adjustment was maxed out. My question is whether you can advance the timing by some other means? This car has electronic ignition but I would think that doesn’t matter.
dklawson
Our GT6 is under cover out in the rain so I can't go look at the moment. The following is from memory.
Are you using a Delco, Lucas, or aftermarket distributor? I don't remember the Delco dizzys having any external timing adjustment so you have to turn the distributor body to set the timing. The Lucas distributors typically have a knurled thumb nut to make minor timing changes. I cannot say what aftermarket dizzys have. In all cases you can loosen the pinch plate and turn the dizzy body a few degrees to alter the timing.
Please elaborate a bit about what you have and what is limiting your distributor travel.
F
Firsttimer
The distributor looks standard, it just doesn’t have any points. I’ll try to take a couple of pictures later. Basically there is the standard slotted pinch plate attached to the distributor that allows you to turn the distributor body when the nut is loosened. In this case the bolt is already at the end of the slot so I can only turn the distributor one direction. Inside the distributor it does look like you can loosen a small screw and make another adjustment but I’ve never had to do that in the past. I’m pretty busy with family stuff this morning but will try to get a couple pics later today.
dklawson
The GT6 used the Delco distributor. I believe at least early TR6 used the Delco as well. I'm sure some have been converted to use use the Lucas. I'm posting two picture links below to help you identify which you have. Electronic ignitions can be fitted to either.
Delco:
https://cdn8.bigcommerce.com/s-5e3d...s/15292/3282/D46H_w__42286.1532440056.jpg?c=2
Lucas:
https://www.74tr6.com/pics/newengine 177 (Small).jpg
On both you will notice a pinch plate at the distributor base. If you loosen the "horizontal" pinch bolt the distributor can be rotated clockwise or counterclockwise just about as far as you can imagine until you run out of room to swing the vacuum advance OR the tach cable limits the possible motion.
charleyf
To add to what Doug has stated. Before you loosen the pinch plate and try to move the distributor by hand make a mark on the distributor and a matching mark on the pinch plate so that you can tell where your present setting is. Sometimes a distributor is hard to move and you move it a lot more than you intended.
poolboy
It does sound like you have loosened the bolt that holds the clamp onto the pedestal instead of the clamp's horizontal pinch bolt and fastener around the waist of the distributor....Only the tach cable would prevent over advancing if the distributor was installed properly oriented as Doug pointed out.
glemon
Sometimes people tighten the pinch plate too much and gouge the distributor body, I would check and make sure that isn't the problem preventing easy, full movement.
F
Firsttimer
Thanks Doug, It looks like I have the Lucas distributor. Attached is a picture showing the nut that allows for adjustment of the distributor. You can see the slot. The bolt is tight against the end of the slot so no more adjust is available at that point. The second pic is the interior of the distributor. I was looking at the small screw with the slot and wondering if an adjustment can be made there. 6D3C1019-D683-4025-803C-C532927ECB73.jpgFA5FB990-E67C-436B-BEE0-8EFDA96A6D4A.jpg
F
Firsttimer
Pool boy, I think you are right. I’ll take another stab at it by loosing the horizontal clamp. I don’t need much adjustment so this should be the solu5ion.
3798j
Bronze
dklawson
If the engine appears to be running well, I would not make any adjustments to the placement of the electronic ignition components inside the distributor. I would focus only on that external pinch clamp.
Per our earlier discussion, there are vertical and horizontal bolts for the dizzy clamp. The vertical bolts are shown in your first picture. The long horizontal bolt is not clearly shown but it will be obvious which it is. Loosen the horizontal pinch bolt and turn the distributor body to adjust the timing where you want it.
I also feel it is worth pointing out that you may be missing a distributor component. Your pictures show what appears to be a 25D6 series Lucas distributor. Look at the bottom, right of the distributor body in your second picture. You will see a "C" shaped opening. There is normally a thumb nut in that location. The thumb nut should be mounted on a threaded rod that is connected to the breaker plate. By turning that (missing) thumb nut you are able to advance or retard the timing by a few degrees as needed. The nut really needs to be there so the timing doesn't randomly change on you while driving. Of course... a previous owner may have locked the breaker plate to prevent that wandering timing... but that would also disable the vacuum advance.
I am not very familiar with the 25D6 distributor... only 4 cylinder 25D4. Can someone confirm whether the 25D6 should have the advance/retard thumb nut?
poolboy
While the thumb wheel can be added to the TR6's Lucas 22D6 distributor with a vacuum Retard module, they didn't come that way.
If added, the retard module would have to have been 'unpinned' so that it can move as the thumb wheel is rotated. The module in "Firstimers" module is pinned, therefore the points plate will only move in reaction to vacuum in the retard module.
dklawson
Thanks for that. As I mentioned, I am more familiar with 25D4 dizzys than 22D6.
Rut timing, cams, valve adjustment Spridgets 6
bugedd Timing adjustment Spridgets 15
poolboy Lucas Dizzy with micro timing adjustment question Triumph 20
RobT Twin Cam Timing Chain Adjustment Lotus 14
P TR4/4A Ignition Timing Adjustment on a TR4A ? Triumph 13
S TR6 TR6 Timing Adjustment Triumph 4
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
Got_All_4 TR5/TR250 Timing chain tensioner completely shot Triumph 11
mt10flyer TR2/3/3A Timing Chain Tensioner - again Triumph 13
M 1275 Timing Cover Vent Spridgets 2
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
K TR2/3/3A Timing chain rattle on start up? Triumph 2
D Cam Timing question. Spridgets 11
KVH General Tech Valve Timing--No Marks Triumph 20
drooartz MGB Question on timing and vacuum MG 11
E Ignition Timing Austin Healey 14
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
K TR2/3/3A Timing marks on pulley? Triumph 10
LAW75 Timing Chain Cover Gasket Austin Healey 12
Lin Ignition timing question Spridgets 2
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
A Timing cover access Spridgets 6
BN6_2197 BN6 Static Timing Austin Healey 2
vette Timing Marks! Austin Healey 12
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
J TR6 73 TR6 Static Timing Questions Triumph 6
P TR6 1970 TR6 Timing Question Triumph 2
TRclassic3 TR2/3/3A Timing and temperature Triumph 13
B TR4/4A New valve gears/timing Triumph 21
K TR2/3/3A Ignition Timing? Triumph 11
K TR2/3/3A The timing mark on the crank pulley.... Triumph 5
M 100-4 Timing Pointer Austin Healey 5
D TR2/3/3A Timing chain tensioner. Triumph 3
KVH TR4/4A No Marks on Timing Gear Triumph 30
Got_All_4 TR6 Newly purchased poor quality timing gear Triumph 5
vette MGB 74 1/2 Timing Specs. MG 16
B Timing Light question Austin Healey 0
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
Got_All_4 TR6 Timing chain Triumph 10
Got_All_4 TR6 Double row timing chain in a 69? Triumph 2
D BT7 Timing Advance Austin Healey 17
D BT7 ignition timing Austin Healey 5
R TR2/3/3A Timing Triumph 3
F TR2/3/3A Ignition Timing - Again Triumph 11
T Even but low compression on 3.8 - timing slightly off? Jaguar 7
B Engine timing Spridgets 8
tinman58 TR2/3/3A Timing ? Triumph 21
