TR2/3/3A brake reservoir on a tr3
sp53
So I am back on what type of brake fluid type story to use. I called around and had a difficult time finding dot5 and when I did find some the guy told me he had one quart left. I asked what he meant by that, and he said it is in low demand.
In addition, to that-- you know the brake reservoir on a tr3 and how it has the separate clutch cup with a rubber gasket which I guess is to prevent all the brake fluid leaving if the clutch leaks, but what if that rubber fails? Wouldn’t the brake fluid leave then? So, did they have 2 smash washers originally on the clutch to separate it and someone used just a rubber washer inside and crush washer out in this one? I thought they all had rubber to separate to the 2 cups.
Steve
TR3driver
Great Pumpkin - R.I.P
TRF has the best price I've found on DOT 5 (even with shipping), and they always seem to have it in stock. It's very hard to find in local stores, and generally very expensive when you do.
I've only taken a few reservoirs apart, but all of them have had a pliable (maybe not necessarily rubber but similar) gasket under the inner reservoir. Yes, if that gasket fails, and you also have a clutch failure; then you can lose brake fluid through the clutch. Second level backup is the hand brake :smile:
But I've never had one leak.
CJD
So, when your clutch fails, most will tend to quit driving before the brakes fail...at least I would?!? I think your thinking into it too hard.
S
sp53
Thanks you guys and yes had a math teacher in college tell me you are way over thinking this; it is not that difficult. In fact same thing with English because I would either get to philological with correct grammar or try and be logical with some of the grammar. Common sense is usually very applicable.
CJD
Oh, I think I used black neoprene washers from Ace to re-build my reservoir. I tested different materials by leaving them in brake fluid for a week. Cork also did well, but the washer was pre-cut by Ace, so easier.
Got_All_4
I buy it at Advance Auto Parts. They seem to always have it in stock. Usually one 1 or 2 bottles. Little more money then DOT4 but the benefits out way the ricks.
DavidApp
I got mine in the paint/parts supply house store. They had some on clearance at $1.50 per container. Said there was no demand for it so they had discontinued it. I bought a lot of it.
David
K TR2/3/3A TR3 brake fluid reservoir outlet at the bottom..... Triumph 0
Moseso TR2/3/3A TR3 Clutch/Brake Reservoir Triumph 4
martx-5 TR2/3/3A TR3 Brake Fluid Reservoir Triumph 1
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
B TR2/3/3A Bubbling in brake reservoir. No pressure in lines Triumph 5
wangdango BJ8 brake reservoir? Austin Healey 7
vette Brake/Clutch Reservoir Austin Healey 14
M TR2/3/3A Brake/Clutch Reservoir Seal Triumph 9
H Adviced asked on unscrewing lid brake fluid reservoir Austin Healey 9
F Replacing brake master cylinder, fluid reservoir and flexible brake pipes - order? Austin Healey 4
Rob Glasgow Brake/Clutch Reservoir Lines Austin Healey 9
B TR2/3/3A Gaskets for Brake/Clutch Fluid Reservoir? Triumph 15
Kleykamp TR2/3/3A brake reservoir cap leak??? Triumph 9
krswen General TR Need help finding remote brake reservoir .... Triumph 2
krswen Need help finding brake reservoir Austin Healey 5
PatGalvin TR2/3/3A Brake Master Cylinder Fluid Reservoir Bracket needed, TR3A Triumph 6
nevets Replacing the brake/clutch fluid reservoir Austin Healey 21
Jim_Newman brake/clutch fluid reservoir Austin Healey 4
HealeyRick Brake Fluid Reservoir Leak Austin Healey 6
richberman brakes/clutch fluid out top of brake reservoir Austin Healey 11
RAC68 BJ8 Brake/Clutch Reservoir Fluid Loss Austin Healey 14
D 85 XJ6 brake fluid reservoir leak Jaguar 4
C Brake Fluid Reservoir Triumph 2
John_Mc Gray "sludge" in brake reservoir Triumph 4
A TR6 TR-6 Brake reservoir bubbles Triumph 11
F TR6 TR-6 Brake MC Reservoir Seal Triumph 1
dklawson Spitfire Brake MC Reservoir Seals for '72 Spit ? Triumph 5
Monark192 MGB-GT Remote Brake Fluid Reservoir on 67 GT MG 6
A Brake/Clutch Reservoir - any idea what it fits? Triumph 4
G My Brake MC Reservoir Fix Works! Triumph 14
G Brake Master Reservoir Weeping.......again Triumph 13
G Brake Master Cylinder Reservoir Nappy Triumph 8
mgbnew T-Series Which is which? Brake or clutch reservoir? 1 or 2? MG 7
GregW Brake tubing, Reservoir to MC Austin Healey 4
nevets brake fluid reservoir appearance Austin Healey 48
S '60 Sprite clutch/brake reservoir Spridgets 4
G Leaking brake fluid from reservoir Triumph 6
6 Brake Fluid Spridgets 1
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
E TR4/4A What Flare to put on a TR4 Brake Line Triumph 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
J MGB BRAKE VALVE ? MG 11
