Results 1 to 3 of 3
Thread: Gearbox Selector Shaft Tensioning
Discussions of MG Sports Cars
  1. #1
    Senior Member Simmo's Avatar
    Join Date
    Sep 2012
    Location
    NSW Australia
    Posts
    106
    Thanks Thanks Given
    4
    Thanks Thanks Received
    Thanked in
    There are three screws just behind the bell housing which bear on a spring and ball to put tension on the operating Rods.
    Does anyone know how to manover the gearbox into a position in order to remove these bolts so that I can increase the tension on these springs with the introduction of a spacer.
    At least one anyway, so as to hopefully stop the jumping out of top gear.
    Any suggestions gratefully accepted
  2. #2
    Jedi Trainee Joe Schlosser's Avatar
    Join Date
    Jul 2015
    Location
    Chester NY
    Posts
    379
    Thanks Thanks Given
    8
    Thanked in
    Re: Gearbox Selector Shaft Tensioning
    I am guessing that increasing the tension on the detent springs will not correct the problem. Your issue is most likely a worn 4th gear syncro.
    Joe Schlosser
    SCCA National License, Retired
    60 Bugeye, since 1966
    SCCA FP, sold but not forgotten
  3. #3
    Yoda dklawson's Avatar
    Join Date
    Mar 2005
    Location
    Durham, North Carolina, USA
    Posts
    6,267
    Thanks Thanks Given
    54
    Thanked in
    Quote Originally Posted by Joe Schlosser View Post
    Agreed. If not wear in the synchro it could be wear in the selector fork or the syncro hub.
    Doug L.
    '64 Morris Mini Cooper-S 1275
    '67 Triumph GT6 Mk1
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
