MGB Stuck in now, engine swap time
drooartz
Now that winter has arrived (some snow on the ground today) it's time to get going on the engine swap. The plan is to pull out the engine in the car (the original one) and put in the one from this car. This gets the B back on the road, and I can do a full rebuild on the original engine as I have time. I admit that I was tempted by a full rebuilt engine and supercharger that was for sale over on MGExp, but I resisted. Need to focus the $$ on the Bugeye.
So off we go. This will not be a quick project, but I'm trying to do at least something every few days so I can chip away at it. Really tempted to strip and repaint the engine bay (stupid black paint) but that needs to wait. Goal is to have the B back on the road by spring.
Also wondering if I can get my health insurance to cover to the cost of a lift as a preventative measure to hold off back pain... :grin:
Progress so far:
Always exciting to have the tools out and ready for a project:
The parts pile so far. Oil cooler will get replaced:
Progress. Couple more passes at disassembly and it'll be engine out time.
Platinum
Progress, indeed!
Aluminum radiator! Best thing I've done down here to keep running temps under control in July.
Keep the photos comin'!
Rut
Drew,
Are you going to drive your B before spring? If not, I would be inclined to force myself to rebuild the original engine and save on labor. That’s time spent you could use on the rebuild!
Rut
drooartz
drooartz
Drew,
Rut
I had considered this option, but the truth is that I don't have the time right now for the full rebuild work, and this engine I'm swapping in is a known runner. I look at this as a 2-year solution; gets me driving the car again for a couple years while I devote time to finishing the shop and working on the Bugeye. Once that dust has settled I can get back to the B and dive into the engine. The donor was cheap enough (and came with a working OD trans) that it's worth the small effort. When the plan is all done I'll have a spare engine and OD trans on the shelf for future use.
This swap shouldn't be too hard. I'll throw in a new clutch, oil cooler, and hoses and back in it goes. I'm off over the Christmas break (a nice perk of working for a public school district) so I may try and take that time to get things really going.
drooartz
drooartz
Boy, time does get away from me... had hoped to button this up over the winter, but that didn't come close to happening. This morning I got motivation and got to work. The engine is now out!
Next step is to order up a few things I need and get the replacement engine set up and ready to slot back in. I'm going to try very hard to resist the urge to clean and repaint the engine bay...
drooartz
drooartz
I would at least clean the gearbox and spray the motor.
Plan is to clean the donor motor and trans, and pop in a new clutch. Also likely new engine and trans mounts. Don't want to go too deep on this one, just want to be driving again. The engine I pulled (the original) will get rebuilt and eventually will go back in.
Mickey Richaud
Good on ya, Drew!
And don't you love construction scraps such as your custom OSB engine "rest"? I have several pieces here, along with some leftover log ends from the house we built. Amazing what gets thrown out/burned during construction.
drooartz
drooartz
I've a whole stack of these OSB cutoffs from the shop build. Used them to build my work bench, and they keep coming in handy for other projects.
Mickey Richaud
Yup - have two garden benches fashioned from pieces cut from logs on our home, sitting atop decorative concrete/cinder blocks. Sealed them to match the stain on the house. Also made both of the work benches all from 4X4s, 2X4s and OSB leftovers. Still plenty more pieces to play with.
But back to the build - what are your plans? Any "massaging" in the works?
drooartz
drooartz
Plan for now is to swap in the donor motor (from a friend's rusted out 70 GT) so that I can get it back on the road and drive it. The original engine needs a rebuild. At a minimum I'll build it up with reasonable performance parts. I'd love to go supercharged, but that may be beyond the budget.
The full reality is that once this is done I need to swap the transmission in the Morris and then work on the Sprite, so this engine may be in the B for a while -- but at least it will be driving again.
drooartz
drooartz
I’ll check back in fives time when the motor will still be fitted in the car.
It will likely be years :grin: but at least it'll be on the road. That's the main goal, to be able to be driving again so that I can take the time (and I certainly will) to rebuild the original engine.
Grantura_MKI
Gotta love spell check!
Hear, hear on the road is best.
There are many inexpensive things that I would do before fitting that unit.
Good luck.
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
D TR2/3/3A engine :"stuck" even before it starts! Triumph 28
T TR4/4A Geez - this head is really stuck on the engine Triumph 6
A TR2/3/3A First Time TR3A Owner with stuck engine Triumph 10
angelfj1 Stuck Engine - help needed Restoration & Tools 4
angelfj1 Stuck Engine. Help!!! Triumph 91
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
R Healey 100 Dipstick Stuck Austin Healey 12
DrEntropy General MG Stuck splines? MG 3
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
KVH General TR Shifter Stuck Triumph 6
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
L Stuck in Overdrive Austin Healey 10
M General Tech J Type OD Stuck in OD - Fixed Triumph 2
A MGB Stuck water temperature sensor MG 26
Rut TR4/4A Stuck clutch, again Triumph 19
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
K TR2/3/3A High beams seem to be stuck on when the headlights are turned on? Triumph 3
C Side-Change Gearbox Stuck in Top Gear Austin Healey 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
R TR2/3/3A Help, I am stuck, or think I'm stuck Triumph 32
J TR2/3/3A Oil drain plug stuck Triumph 10
N Stuck Needle Valve - Rough Running Austin Healey 15
M battery helmet stuck on post help Austin Healey 8
JimLaney 1098 stuck lifters problems Spridgets 5
Michael Oritt Oil release valve plunger stuck Austin Healey 9
HighAltitudeTR3 TR2/3/3A What is non magnetic metal and gets stuck in Pressure Relief Valve? Triumph 48
D TR2/3/3A Exhaust pipe flange stuck to manifold Triumph 5
nevets stuck rear brake drum Austin Healey 18
D TR4/4A badly stuck suspension sleeves Triumph 7
jfarris TR2/3/3A Head stuck on block Triumph 8
R General Tech Pressure Plate Stuck? Triumph 5
R Pressure Plate Stuck? Austin Healey 3
R stuck valve Austin Healey 14
C Overdrive stuck Austin Healey 10
B stuck in 4th gear bj8 Austin Healey 8
jfarris TR2/3/3A Reverse shift rod stuck Triumph 7
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
C TR6 ZS 175 CD2 stuck air valve/piston Triumph 5
Rut Stuck fasteners Spridgets 1
T General Tech Brake caliper - piston stuck Triumph 4
trotti Stuck drum - any ideas? Austin Healey 5
KVH General Tech Removing Stuck Head Studs from Block Triumph 18
bugedd Looks like you guys are stuck with me Spridgets 10
K TR2/3/3A Help!..Installed new Clutch....Trans stuck in Gear? Triumph 8
J Rear spring front pin stuck Austin Healey 8
M Broken off dip stick plastic tube, stuck oil pan, and I think too much... Spridgets 10
T TR2/3/3A caliper piston stuck Triumph 12
M 99 L/H Drive X308 Hood latch Stuck Jaguar 0
richberman e-brake stuck on Austin Healey 36
