Wanted Tr6 differential
laneriddle
If the diff(I think) is clunking some and you know the mounts are good and everything from the wheels in has been replaced ,the only thing left is the diff right?
So remove and rebuild?
I can remove the diff no problem but can’t rebuild it . If it’s not to bad could it be just a few internal parts ? What little research I’ve done,it sounds expensive.
Alfred E. Neuman
Similar situation to me. Mine developed a clunk after I welded in the frame reinforcements and I had replaced the stub axles and hubs. Ended up being a broken tooth on the crown. It would occasionally catch the broken tooth and pull it through the gears and clunk like crazy. Made it home, but the diff was toast. Replacement was much cheaper than rebuilding at the time. Don't know about used units now, but likely still the case.
I think if I was faced with the same thing again, I'd put in a used unit and rebuild my original when I could. And I'd go with a 3.45:1 ratio to get a bit better highway RPM with a non OD transmission.
R For Sale TR6 REAR DIFFERENTIAL Triumph Classifieds 3
Ripper01 Sold- TR6 Differential drive Triumph Classifieds 1
Ripper01 For Sale Sold-TR6 Differential Triumph Classifieds 0
J TR6 TR6 Differential Rebuild question Triumph 6
B TR6 TR6 Differential Followup, and inspection questions. How do you know it's good? Triumph 2
B TR6 TR6 Differential bearings. Triumph 3
T TR6 TR6 Differential Ratios Triumph 8
B TR6 1972 TR6 Differential Rebuild Question Triumph 3
SkinnedKnuckles TR6 TR6 Differential Rebuild Triumph 4
glemon TR6 tr6 differential seal Triumph 10
W TR6 TR6 Differential Question. Triumph 6
MTribe TR6 TR6 differential leak fix - what to do? Triumph 11
mgedit TR6 TR6 Differential Mounts Triumph 6
K TR6 tr6 differential - need feedback! Triumph 16
J TR6 Last TR6 differential question Triumph 16
R TR6 TR6 differential internal upgrade Triumph 0
H TR6 Tr6 differential backlash Triumph 2
Aeroken TR6 TR6 Differential Inner Shaft Seals Triumph 8
T TR6 What year TR6 did NOT have a differential oil drai Triumph 11
C TR6 TR6 Differential Oil Seal ? Triumph 0
tr6web TR6 DIfferential and support damage TR6 Triumph 20
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
