Plug gap for 907?
Ray Brandes
We are working on a 907 out of a Jensen-Healey.
I can't find the points or spark plug gap anywhere.
Please help! Thank you for your consideration.
Regards, Ray
Panama City Beach, FL
LarryK
I looked this up in a 80s tune book. 68-70 Lotus Twin Cam, Dwell 57-63, Gap .015, Plug gap .025, Timing 12 deg BTDC. Looks typical of the British 4 cyl points and plugs. Hope this gives you a target to get or a starting point. Maybe a Jensen owner can send a picture of the owner manual page or something more accurate. I assume this is for carb engine as fuel injection has different timing, which I cannot find, except on Jenson Healy Forum ( sorry Basil).
LarryK
Carbs done yet?
E
Esprit2
I realize this is a little late to be helpful, but file it away for next time.
0.014" - 0.016" = Points gap for a Lotus or Jensen-Healey 907
(0.36 - 0.41 mm)
Champion N7Y Spark Plugs
0.025" (0.64 mm) = Gap for Stromberg carb'd Federal engines.
0.023" (0.58 mm) = Gap for Dellorto carb'd Euro engines.
Ignition Timing:
Distributor Mechanical Advance:
. . . . . . . . . . . . Stromberg . . . . Dellorto
Below. 1000 . . . No Advance . . . No Advance
. . . . . 1200 . . . . 2.0°. . . . . . . . . 2.0°
. . . . . 1400 . . . . 4.4°. . . . . . . . . 4.4°
. . . . . 1600 . . . . 6.8°. . . . . . . . . 6.8°
. . . . . 1800 . . . . 9.0°. . . . . . . . . 9.0°
. . . . . 2000 . . . 11.4°. . . . . . . . 11.4°
. . . . . 2200 . . . 13.6°. . . . . . . . 13.6°
. . . . . 2400 . . . 16.0°. . . . . . . . 16.0°
. . . . . 2500 . . . 17.0°. . . . . . . . 17.0°
Static Advan . . . 10.0
° BTDC . . . 12° BTDC
Vac RETARD. . . .
5°-7° BTDC . . . None, all mechanical
Total Idle Adv. . .
1°-3° BTDC . . . 12° BTDC
There is a bias spring between the distributor shaft and the auxiliary shaft. If you just loosen the distributor clamp, the spring will pop the distributor out of the housing. Apply inward pressure with one hand, while loosening the clamp with the other. Maintain the inward pressure until after the timing is adjusted, and the clamp is re-tightened.
The Stromberg carb'd 907 is tuned for emissions, and it's performance is weak. If the engine doesn't have to pass an annual emissions inspection, then re-tune it a bit. Early Strombergs used adjustable jets, later ones used adjustable needles. Figure out what you're working with, then adjust accordingly to set the mixture for best running instead of low emissions. Then set the static ignition timing to 12° BTDC, and disconnect & plug the vacuum line to the distributor's vacuum capsule.
Time both cams to 110 MOP. Early J-H 907s used 115 MOP on both cams (emissions... cost 6-8 Hp). Later Federal J-H 907s used 100 Intake / 110 Exhaust MOP. It's 'that' cam timing, plus really lame ignition timing that earned the 907 the name, "Torqueless Wonder". It's a great little engine, it's the Federal emissions tuning that sucked.
BLACK OEM timing belt TENSION (Gates T104 belt):
Don't use the tension spec given in the Jensen-Healey Workshop Manual. It's TOO LOW.
Using a Burroughs BT-33-86J, or BT-33-73F tension gauge,
98-100 for a NEW belt being tensioned for the first time, to allow for initial stretch.
95 . . . .for a Used belt being re-tensioned during a routine service.
Using a Krikit KR-1 gauge, reading the POUNDS scale:
53 - 55 for a NEW belt being tensioned for the first time, to allow for initial stretch.
52 . . . .for a Used belt being re-tensioned during a routine service.
Replace the BLACK timing belt every 24,000 miles or 24 months, whichever comes first. Most Jensen-Healeys don't pile on the mileage fast enough to hit the 24k mile limit first, so just plan on every two years.
Replace the tensioner bearings with every other BLACK belt, or at 48k miles.
Gates Racing BLUE HNBR timing belt TENSION (Gates T104RB):
83-87 on a Burroughs
34-35 on a Krikit KR-1 gauge, reading the POUNDS scale.
The Blue HNBR rubber belts are very stable, and essentially do not stretch. Continue to periodically check the tension during routine servicing as called for in the manual, but the Blue belt's tension will rarely require re-adjustment.
Replace the BLUE timing belt every 7 years. That's conservative, but you're playing with an interference engine that is expensive to rebuild. The Gates T104RB BLUE belt costs more, but requires less maintenance, and lasts longer.
The tensioner bearings need to be replaced every ~48k miles, so there's really no point in trying to stretch the BLUE belt's change interval any longer. The belt has to come off in order to change the tensioner bearings anyway, so 'why' re-install an old belt?
Regards,
Tim Engel
a Lotus fan
K TR2/3/3A Spark Plug Gap? Triumph 4
B TR6 Spark plug gap Triumph 5
B Plug gap Austin Healey 16
T TR2/3/3A TR2/TR3 spark plug gap setting?? Triumph 8
D Spark Plug Gap Austin Healey 10
K TR2/3/3A TR3A Plug Gap? Triumph 6
Marvin Gruber Plug gap does make the difference Triumph 19
K TR2/3/3A Spark plug gap TR3? Triumph 1
J TR2/3/3A Spark Plug Gap for TR3A Triumph 3
Jim_Newman Spark Plug Gap Austin Healey 9
K TR2/3/3A TR3 Plug gap .032 or .025? Triumph 8
B Spark plug gap Triumph 4
F Spark Plug Gap Recommendation Austin Healey 3
R incease spark plug gap with pertronix Spridgets 3
MGTF1250Dave Spark plug gap with high voltage coil Triumph 17
VelodromeRacer Spark plug gap/heat range? Racing 8
R spark plug gap with pertronix ignition and coil Spridgets 6
vping Recommended Spark plug gap MG 26
DNK Plug Gap. Triumph 5
X Soark Plug Gap MG 14
H Spark Plug Gap Austin Healey 3
K TR2/3/3A TR3... Mods and Champion Plug Gap? Triumph 1
T Pertronix = greater spark plug gap? Triumph 4
Woodie spark plug gap Spridgets 9
vping Spark Plug Gap MG 13
H 73 Midget Plug and Points Gap MG 8
C MGB New plug wires and distributor cap MG 10
CARSINC Spark plug thread size Spridgets 2
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
Carlbanan56 MGB Manifold plug MG 5
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Spark plug inspection Triumph 5
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
S MGB mystery wiring plug MG 2
Bocaray TR2/3/3A TR3 Antenna Hole Plug/Cover? Triumph 2
PAUL161 T-Series Odd spark plug encounter! MG 10
M TR2/3/3A Crankshaft Sludge Plug Removal Triumph 6
D Socket for TR3 Gear box drain plug Restoration & Tools 6
Spock TR6 Transmission Plug Triumph 4
D TR2/3/3A Plug Leads Triumph 12
S TR2/3/3A tips for mig plug welding vertically? Triumph 11
K TR2/3/3A Testing spark plug wires..... Triumph 11
B TR4/4A Oil Drain plug size Triumph 14
HealeyRick Plug Your Pipes! Austin Healey 14
G TR4/4A Rear Oil Galley Plug Sealing Triumph 21
G Opinion on spark plug color Austin Healey 15
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
HighAltitudeTR3 TR2/3/3A Aluminum Plug in Head Triumph 16
