Well, this should be interesting.....
After many, many, many years of looking, watching, lurking, my wife and I found ourselves at the right place at the right time. 1973 GMC motorhome. 55,000 miles +/-, always stored indoors, pretty much original and unmolested. 455 Olds Toronado drive train. Some of you may recognize this as an EM-50, points if you do. We're keeping things as original as possible - yes, the interior is STAYING! :smile: This should be fun. There is a very strong following for these and they seem to be well supported. Wish us luck. Can someone give me something, anything to make this an honorary LBC, please, oh please?? :D LoL
JPSmit
Ooo - honourary LBC just because of straight cool factor! well done man!
:cheers:
Mickey Richaud
VERY COOL, PETE! Color me green with envy - as green as that great '70s interior!
So, when can we expect a visit down here in the Smokies?
Mickey
Platinum
MASOCHIST!!! :smirk:
waltesefalcon
I look forward to many sagas involving maintenance, upkeep, and travel; all accompanied by photos.
LarryK
My sis in law has one getting ready to sell. They were afraid to drive it. Drivetrain was rebuilt, but he isn't mechanical. Then, she painted 3' flowers all over it, but did the interior very nicely. We just had 6 on the St. Louis craigslist that went quick. Congratulations on your find, enjoy. There is a GMC website and forum especially for these and a place here just outside St. Louis (Fenton, Mo.) That has a website for parts just for these vehicles. Brother in law had everything in his favorites for the GMC. They went to a meet once(without the RV) and got scared for the award to the most tows in a year, one guy made a drive in for their MINI in the back.
S
I figure I should be able to pull a flat bed trailer with our Mini and Minor on it. Mini cross-wise at the front of the trainler and Minor behind it normal orientation. Will have to make sure the weight distribution works.
regularman This one should be interesting to watch Spridgets 30
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
S TR6 Should I Buy This "73 Triumph TR6" Triumph 3
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
AngliaGT Why You Should Double - Check Your Parts When You Receive them. Spridgets 2
Got_All_4 TR6 Should I paint the inside of the block? Triumph 17
KVH TR4/4A Should I Cut the Lower Windshield Gasket Triumph 2
C MGB Should I lubricate the cog gears MG 2
55modified Should I remove driver's side fender to work on footbox on my BN1? Austin Healey 14
George Zeck What fuel gauge SHOULD I have? Spridgets 3
B How often should you change the rear rear axle oil Austin Healey 9
B TR6 Should the poly diff mounts be snug to the studs? Triumph 2
Sopwith_Camel 95 xj r cheap should i run away screaming? Jaguar 2
abarth69 Should I remove this section Spridgets 8
L Should I do it?? [electrical conversion] Austin Healey 24
B TR2/3/3A what adjustment should i select with Koni shocks onTR3? Triumph 4
T TR4/4A Should I use ARP Assembly Lubricant for Engine Assembly and Fastener Installation? Triumph 2
F Exhaust gas analyser - what carbon monoxide level should I expect from my BT7? Austin Healey 7
K TR2/3/3A How long should an SU damper top up last? Triumph 22
M TR2/3/3A What oils, lubes etc should I have at my house at all times? Triumph 39
Got_All_4 TR2/3/3A What color should these parts be? Triumph 4
Joe Reed MGB Wiring problem....this should be fun :[ MG 4
stretchit2 Portable Hardtop Rack - Should it stay or should it go Austin Healey 28
M TR6 Should I buy a TR6? Triumph 24
Keoke Everone should own one Austin Healey 14
W TR2/3/3A '56 TR3 St 15000+ should have disc brakes... Right? Triumph 33
K TR2/3/3A How much oil should the steering box have in it? Triumph 6
Wirewheels General Tech Do we really care what our LBC's speedometer reads? Should we? MG 7
S TR6 Worth Saving??? What do you think we should do? Triumph 30
GTP1960 TR2/3/3A Should you paint your leaf springs? Triumph 5
2billydavies TR2/3/3A what bolts should i use to mount engine on an engine stand? Triumph 13
V General TR should or shouldn't? Triumph 19
R TR4/4A Replacing Door and Window Handles _ Should Be Simple - But Its Not Triumph 4
R TR4/4A About to put in an OD Transmission. What else should I do while in the air Triumph 7
T TR2/3/3A Should I put flat washers on sump bolts? Triumph 3
E How much should i pay for a complete 100/4 engine ? Austin Healey 4
luke44 General TR Every TR Owner should really appreciate this picture. Any guesses? Triumph 7
M TR4/4A Where should TR4A carpet snaps be placed? Triumph 10
J TR4/4A 1965 TR4 in pieces, What should we do with it? Triumph 9
Got_All_4 TR2/3/3A What color should this part be? Triumph 5
JPSmit Bring a Trailer should be banned Other British Cars 3
M How well should the water pump free spin? Spridgets 4
C What should the VIN plate look like for a BN1? Austin Healey 1
N Spitfire Should this be bent? Triumph 4
PatGalvin TR2/3/3A what color should it be...? Triumph 7
C Inner Sill Assembly Should i spend extra money on kilmartin brand??? Austin Healey 4
60TR3A Should My '63 BJ7's Carburetors Have Brass Caps or Black Plastic? Austin Healey 3
