Results 1 to 5 of 5
Thread: Valve lash - Is this how it is done?
Discussions of Lotus Sports Cars
  1. #1
    Join Date
    Sep 2018
    Location
    Panama City Beach, FL
    Posts
    26
    Thanks Thanks Given
    Thanks Thanks Received
    1
    Thanked in
    1 Post
    We are rebuilding a 907 engine for a Jensen-Healey. We are having the valves re-ground.
    We are eliminating the paper gaskets under the cam towers and will use the 515 sealant.
    Both of these things will reduce the thickness of the shims.
    I will make some temporary shims, a bit undersized, and measure the lash.
    Based on these measurements I will grind the original shims for the proper lash.
    Regards, Ray
  2. #2
    Join Date
    Aug 2010
    Location
    Strafford, NH
    Posts
    1,759
    Thanks Thanks Given
    9
    17
    Thanked in
    Re: Valve lash - Is this how it is done?
    You make it sound easy. If you have the skills and tooling to make the shims, that will help. Also make a good chart of all your measurements. I've not done a Lotus but in the past did a Fiat and a SOHC Triumph TR7 (Also read that the TR7 shims are the same size as the Lotus). Both took me several tries to get even reasonably satisfactory clearances. The more accurate, orderly and methodical you can be (I'm none of those) the better the results.
    You might find this interesting too:
    https://www.jensenhealey.com/forums/...um_id=2&page=3
    Tom
    1960 TR3A TS73117 (under endless restoration, owned since 1964)
    1959 TR3A TS58023 (in case I never finish the one above)
    1969 Triumph Herald 13/60 (a whim)
    1970 Lotus Elan Plus 2 /0023/N
    1992 BMW325IC (fun to drive)
  3. #3
    Great Pumpkin DrEntropy's Avatar
    Join Date
    Sep 2005
    Location
    Elsinore, DK
    Posts
    33,338
    Thanks Thanks Given
    47
    78
    Thanked in
    Done many, including my own three Lotus'. Shims are available at Dave Bean Engineering (NFI). I've a set made from brass and cut to 0.040" to use as a "base" reading and do the math to come up with proper clearances. A felt-tip marker is useful to write the measurements on the lip of the head adjacent to each pot.
    BTW: The shims are hardened, need to be lapped to make 'em thinner. A real chore to be accurate with those little buggers. Best to get the proper thickness from a supplier.
    '64 MGB, '67 Lotus Elan S-3 DHC,'69 Lotus Elan +2
    '78 Alfa Romeo Spider-undergoing surgery: O=\*/=O
    '84 300D Turbo-"Diesela"-Now my Daily: Oo|≣|oO
    '02 Toyota Camry- SWMBO's 'new-to-her' Daily. <sigh>
    Chaos & Mayhem PTY, LTD..C.I.O. & Floor Sweepervisor
  4. #4
    Join Date
    Sep 2018
    Location
    Posts
    26
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Thanks guys! I have a surface grinder to set the shims to the correct thickness. I made a steel set of .085" for a base and went from there.
    I kept putting in feeler gauges going up .001" at a time until one wouldn't go. I recorded that value and the one under it that went.
    I used these measurements in a spread sheet to get the new shim values.
    Regards, Ray
    PS: Made urethane tail light gaskets for my BMW 700. Turned out great!
  5. #5
    Esprit2
    Ray,
    As with your points gap question, I'm too late to the party to be helpful, but...
    The shims are case hardened, not hardened all the way through. If you grind them much thinner, the case hardened layer will end up too thin. A couple of thousandths is okay, but if you plan to make up for both deleting the gasket and grinding the valves, I fear the shims will have to be ground too much, and the hard layer will become too thin.
    Deleting the cam carrier gasket also involves cutting a counterbore around the front oil passage/ dowel pin, and installing an O-ring there... one per cam carrier. If you know all of that, then you're good. If not, ping me and I can give you the dimensions for the C-bore and O-ring.
    Basically, you're on the right track, just watch those details. The clearances close up with wear, so always shim to the top of the clearance range. That will give the longest mileage interval before the job has to be re-done.
    0.005" - 0.007" Intake... Target 0.0065" dry.
    0.010" - 0.012" Exhaust, Target 0.0115" dry.
    The anaerobic sealants have a half-thousandth film thickness. So when the Loctite 515 or 518 is added during final assembly, the film thickness will 'float' the head up another half-thousandth, and give a final 0.007" Intake, and 0.012" Exhaust.
    515 & 518 are both good. But 518 is more fluid, easier to spread (paint it on with a flux brush), while simultaneously better at gap filling. Given a choice, I use 518. But if you have 515 it works well... it's just more difficult to apply.
    Regards,
    Tim Engel
    a Lotus fan
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
