Results 1 to 7 of 7
Thread: Lotus Turbo Esprit Issue
Discussions of Lotus Sports Cars
  1. #1
    Join Date
    Oct 2018
    Location
    Highland, MI USA
    Posts
    5
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Hi Guys, new to this forum. My name is Tim Beaubien / TRB57 and have a 1977 MGB, a 1952 MG TD and just recently picked up a 1988 Lotus Turbo Esprit. I actually chased this car for 10 years and we finally came to a price.
    The car has 19,000 original miles and is very clean. I bought from the second owner and he put very few miles on it. He would start the car about once a year and do about a 10 mile drive then back into heated storage.
    Recently the car is running rough on start up but levels off after about 5 to 10 minutes. Still runs very sluggish and then stalls after about 20 minutes and will not start until the next day. Iím thinking fuel pumps??? Any feedback would be appreciated.
    Thanks, TRB57 / tim B.
  2. #2
    Great Pumpkin DrEntropy's Avatar
    Join Date
    Sep 2005
    Location
    Elsinore, DK
    Posts
    33,340
    Thanks Thanks Given
    47
    79
    Thanked in
    Re: Lotus Turbo Esprit Issue
    Your first guess seems to be spot-on. Fuel pump first, run time suggests a possible cat-converter too. Remember that ethanol clogging things can also be involved.
    '64 MGB, '67 Lotus Elan S-3 DHC,'69 Lotus Elan +2
    '78 Alfa Romeo Spider-undergoing surgery: O=\*/=O
    '84 300D Turbo-"Diesela"-Now my Daily: Oo|≣|oO
    '02 Toyota Camry- SWMBO's 'new-to-her' Daily. <sigh>
    Chaos & Mayhem PTY, LTD..C.I.O. & Floor Sweepervisor
  3. #3
    Join Date
    Oct 2018
    Location
    Highland, MI USA
    Posts
    5
    Thanks Thanks Given
    Thanked in
    Thanks for the feedback DrEntropy.
  4. #4
    Jedi Trainee Alfred E. Neuman's Avatar
    Join Date
    Dec 2016
    Location
    Atlanta, GA
    Posts
    216
    Thanks Thanks Given
    3
    15
    Thanked in
    Very quick test for CAT is to hit the thing and see if it rattles. Could be a broken piece of the CAT clogging the exhaust. If not conclusive and the FP checks out, pull the front O2 sensor so the exhaust has somewhere to go and then take it for a drive. If it pulls strong with the O2 sensor out, bad CAT.
  5. #5
    Join Date
    Aug 2010
    Location
    Strafford, NH
    Posts
    1,759
    Thanks Thanks Given
    9
    17
    Thanked in
    I have no knowledge of the Esprit but just started following this forum since I have an Elan Plus 2 on the way which should arrive this week. However, I have and have had several cars from this era and have to say that the fuel pump guess certainly fits the symptoms. Has the Esprit got an OBD port? I know the early OBDs weren't all that good but might be a place to start in the unlikely event that the FP is not at fault.
    Tom
    1960 TR3A TS73117 (under endless restoration, owned since 1964)
    1959 TR3A TS58023 (in case I never finish the one above)
    1969 Triumph Herald 13/60 (a whim)
    1970 Lotus Elan Plus 2 /0023/N
    1992 BMW325IC (fun to drive)
  6. #6
    Join Date
    Sep 2005
    Location
    Elsinore, DK
    Posts
    33,340
    Thanks Thanks Given
    47
    79
    Thanked in
    Quote Originally Posted by Tom
    not likely.
    Ethanol fuel and time in static could be a factor. Not so much the fuel pump as ethanol gumming up jets and small ports in the fuel delivery.
    But the run-time still suggests a CAT-converter clog.
  7. #7
    Esprit2
    TRB57 / tim B.
    Did you ever resolve this issue?
    Regards,
    tim. E.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
