General MG Replacement gauge faces
Bob Branson
I don't need them rebuilt, but wonder if anyone has either a source for replacement gauge faces or knowledge of someone who has managed to use a computer program to reproduce them. Can a Cricut do this?
NutmegCT
Simmo
Send the faces to Speedograph Richfield Ltd Nottingham UK. They do a fantastic job and are reasonably priced. They have a web page
K TR2/3/3A Replacement Temperature Gauge Triumph 5
S BT7 Dash Gauge Light Bulb Replacement Help Needed Austin Healey 16
hymodyne gauge replacement question Triumph 7
NutmegCT TR2/3/3A Fuel gauge needle replacement TR3A Triumph 0
I Gauge gasket replacement Triumph 11
prb51 Ammeter gauge replacement Triumph 8
S Wedge Help with TR7 Fuel Gauge replacement Triumph 3
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
scottkilpatrick TR4/4A Difficulty Level Opinion - Differential Gasket Replacement 62 TR4 Triumph 10
WHT Rocker Arm Shaft Replacement Austin Healey 21
Celtic 77 MGB Seat webbing replacement. MG 1
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Celtic 77 MGB Seat Diaphragm replacement MG 0
Celtic 77 MGB 1977 seat webbing replacement. MG 1
tr6nitjulius General TR Fan Belt Replacement '72 TR6 Triumph 1
K TR2/3/3A Wing mirror replacement again... Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
B T-Series Battery replacement mgtd MG 2
F TR4/4A Speedometer cable replacement access Triumph 0
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
T TR2/3/3A Replacement radiators Triumph 8
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
F TR4/4A Replacement air filter for SU HS6 Triumph 6
BobHaskell Mini Cooper rear subframe replacement British Motor Corp 3
A MGB MGB 1974 windscreen centre rod replacement MG 5
B Poor quality BE replacement spring boxes Spridgets 0
AUSMHLY BJ8 Laygear Replacement Options Austin Healey 0
B TR6 Fuel tank replacement Triumph 0
S MGB clutch replacement MG 7
S Wiring Harness Replacement Spridgets 1
JPSmit Not something you see everyday - a warranty replacement Spridgets 1
M 1972 Midget Seat Belt Replacement Spridgets 4
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
T TR2/3/3A tr3 front carpet replacement Triumph 5
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
D Engine replacement. Rover / Land Rover 0
EWD TR6 Dash Pad Replacement Triumph 3
R TR6 fan shroud replacement Triumph 5
C Replacement wheels Rover / Land Rover 1
B TR4/4A Floor pan replacement Triumph 4
DrEntropy MGB Replacement starter MG 7
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
P TR6 1970 TR6 Passenger Sun Visor Replacement Triumph 1
M General MG Midget MK1 windshield replacement MG 2
M TR6 Replacement Steering Rack ? Triumph 7
Kurtis TR4/4A Rear wheel brake cylinder replacement Triumph 1
