Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 67
Thread: About to strat a full restoration TR2 / TR3 ?
  1. #21
    Join Date
    Aug 2018
    Location
    Durham , England
    Posts
    30
    Thanks Thanks Given
    1
    Thanks Thanks Received
    Thanked in
    Re: About to strat a full restoration TR2 / TR3 ?
    The car was for the most part complete , all the plates were in place ,
  2. #22
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    2,808
    Thanks Thanks Given
    13
    45
    Thanked in
    On mine the tag with the TS number was still attached with the original rivets so I covered the tag with several layers of tape and was very careful when I sand blasted in that area.
    David
    TR3A TS75524L
  3. #23
    Join Date
    Aug 2018
    Location
    Durham , England
    Posts
    30
    Thanks Thanks Given
    1
    Thanked in
    after blasting the bulkhead ,under the commission plate were rivets from a larger plate
  4. #24
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    19,410
    Thanks Thanks Given
    8
    122
    Thanked in
    Earlier cars did have a larger plate, with 4 rivets. According to Piggott, the official change to the smaller plate didn't happen until TS22014 (TR3A) but he says some earlier cars did have the smaller plate.
    I would say it hinges on whether the smaller plate used the original style rivets or not. But I can't really make it out from your photo above. The actual rivet should be aluminum with a steel pin in the center. The pin is a perfect cylinder, not a teardrop shape like a pop-rivet (but otherwise the construction is similar).
    (My plate had been somewhat sloppily oversprayed in black before I got the car. The center pin on the rivet on the right in the photo still has black paint on it, but is otherwise similar to the one on the left.)
    Randall
  5. #25
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,341
    Thanks Thanks Given
    29
    Thanked in
    Even up into the later cars there were 4 holes, maybe all the way until the tubs changed to the raised hinges. I am working on TS 27036 with a small badge and it has 4 holes with rivets in the top 2.
  6. The Following User Says Thank You to sp53 For This Useful Post:
    CJD (09-25-2018)
  7. #26
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Arlington, TX, USA
    Posts
    5,387
    Thanks Thanks Given
    6
    39
    Thanked in
    Interesting! It seems there is always more to learn about these cars.
    John
    1955 TR2
  8. #27
    Join Date
    Aug 2018
    Location
    Durham , England
    Posts
    30
    Thanks Thanks Given
    1
    Thanked in
    Hi CJD . iv been goining through your restoration thread , very impressive , are there any other threads as discriptive as yours ? you could point me too
    Regards Tony
  9. #28
    Jedi Hopeful ckeithjordan's Avatar
    Join Date
    May 2017
    Location
    Shawnee, KS
    Posts
    162
    Thanks Thanks Given
    7
    Thanked in
    One of the things I found was that the larger octagonal commission plates were used up into the TS18000s, then it was a “clipped” plate in the TS18000-19000s, then by the TS20000s, they used the smaller rectangular plate through the rest of production. The reason for clipped plate had to do with removal of the patents displayed below, according to the UK TR Register. My TS20447LO has the later rectangular plate. I also have four rivets, my commission plate is held on by the bottom two and AFAIK, has never been removed. Sorry, I don’t have access to my files, so I can’t be more specific.
    Keith
    1957 TR3 TS20447LO (2017-)
    1962 TR3B TCF1183L (1979-1982)
    1966 Spitfire MKII (1972-1975)
  10. #29
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Arlington, TX, USA
    Posts
    5,387
    Thanks Thanks Given
    6
    39
    Thanked in
    Quote Originally Posted by TRo8son1 View Post
    Regards Tony
    I do have a few...click on my CJD to go to my profile, and then on the left look for "latest started threads". There may be something in there you are interested in. AND, be sure to look up "Chef Tush" videos on Utube...lots of very good restoration videos there!!
    John
    1955 TR2
  11. #30
    Join Date
    Aug 2018
    Location
    Durham , England
    Posts
    30
    Thanks Thanks Given
    1
    Thanked in
    The tub's worst bits , front of chassis , floor pans and battery box , strange the top of the battery box should rust at the higher level
  12. #31
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    19,410
    Thanks Thanks Given
    8
    122
    Thanked in
    The charging system in a TR3 is rather primitive, and when properly adjusted, overcharges the battery slightly when the headlights are off. This in turn "boils" the electrolyte in the battery (actually converting it to hydrogen and oxygen gases), which tends to blow tiny droplets of battery acid out the vents.
    The battery is also slightly undercharged when the headlights are on; both of which contribute to shorter battery life.
    Randall
  13. #32
    Join Date
    Aug 2018
    Location
    Durham , England
    Posts
    30
    Thanks Thanks Given
    1
    Thanked in
    few more pictures
    battery box repairs , and floor pan, knocked it up with the bead roller , not spot on but you wont see it at 50MPH
  14. #33
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    2,808
    Thanks Thanks Given
    13
    45
    Thanked in
    So you repaired the battery box? It looks much better than the job the PO did on mine. One of the jobs I sometimes wish I had done over but at that time it seemed like I had a monumental task ahead of me.
    David
    TR3A TS75524L
  15. #34
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,341
    Thanks Thanks Given
    29
    Thanked in
    I like your style; I like the way you saved the glove bow with a high quality repair. Did you cut the driver floor pan in half? Judging from your work, you are going to repair the inner sill, right? I would, the doors will fit nicer to begin with anyway at least I think so that is if that is savable.--- save it? There is too much collateral damage plus the new ones do not as good.
    steve
  16. #35
    Join Date
    Aug 2018
    Location
    Durham , England
    Posts
    30
    Thanks Thanks Given
    1
    Thanked in
    Yes . cut the pan in half , it was too much like hard work to put the full lenght throgh the bead roller ,it only the very front of the sill and a small hole at the base of the A post that needs a repair , the rest is just surface pitting
  17. #36
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Arlington, TX, USA
    Posts
    5,387
    Thanks Thanks Given
    6
    39
    Thanked in
    I agree with David and Steve...interesting techniques and very nice workmanship!
    John
    1955 TR2
  18. #37
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,341
    Thanks Thanks Given
    29
    Thanked in
    Just thought I would put this out there. The early seats like you have are rare and when done correct they make the car a special original model.so if you send them out for blasting be very careful because they are thin and finding some more would be difficult
  19. #38
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    2,808
    Thanks Thanks Given
    13
    45
    Thanked in
    If the bottoms of the seat are rusted through but the back s look OK check out the bottoms supplied by the company in Australia.
    https://www.kas-kilmartin.com.au
    I got a pair of seat bottoms from them and was very pleased with the price and quality. They fit and matched the original ones perfectly.
    David
    TR3A TS75524L
  20. #39
    Jedi Trainee Graham H's Avatar
    Join Date
    Feb 2018
    Location
    Perth Western Australia
    Posts
    247
    Thanks Thanks Given
    2
    6
    Thanked in
    I got all my repair panels from Kilmartin,i belive they made copies from original panels, the floor panels come with captive nuts and the seat runners bolted straight on, good products
    Graham
    [SIGPIC][/SIGPIC]
  21. #40
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    2,808
    Thanks Thanks Given
    13
    45
    Thanked in
    Wish I had found them earlier in my rebuild journey.
    The only problem I had was they can be slow to answer e mails at times.
    David
    TR3A TS75524L
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
