BJ7 Carpet Install Questions
PeterB
I am installing my carpet set in my BJ7 I got from Heritage. I bought the Moss video that says for BJ7 and BJ8. Unfortunately most of it I think is for BJ8. I have 2 question so far. 1 is how does the carpet lay behind the seat in the corner where the heel board and and shut pillar meet. Where that little “ramp” section is. It almost seems if a relief cut needs to be made so carpet will lay flat on the floor but then floor will show???? Also what gets put in 1st for best fit, the floor pieces or the transmission tunnel piece. Thx any and all help, especially pictures are much appreciated.
Keoke
Floor pieces must go in before transmission tunnel.-
Patrick67BJ8
I put in my Carpet from Heritage when I did my Frame up restoration.
Invest in a good pair of sissors, about $40 to $50 range. #2 Xacto knife and a pack of blades. Tailor marking chalk.
A good brush on contact cement with throw away brushes, 1” & 2” sizes.
Your carpet will be larger and you’ll have to trim it. Take your time, measure three times before cutting.
DerekJ
Not sure how the floor pieces must go in before the transmission tunnel. The floor carpets are removable so can go in and out at any time. Plus the floor carpet edge sits on top of the transmission tunnel edge.
Keoke
I think you and me both not sure---LOL
P
PeterB
Thank you all for you help with the transmission tunnel carpeting. I did buy myself a nice pair of scissors and #2 Xacto knife and a pack of blades, make life much easier. Now I just have to figure out how to place the carpet under the seat against the heel board in the corner by the shut pillar.
Patrick67BJ8
You still need the Tailors Chalk.
Do these photos of an original carpet install help? These photos are from Carroll Phillips of Top Down Restorations in NY. I have other photos of mine in more detail.
P
PeterB
Patrick, thanks for the help. Unfortunately the area I am trying to figure out isn't in the pictures. I am trying to see how the carpet comes together behind the seats toward the heel board on a BJ7 near where the shut pillar is. Thx again, Pete
Patrick67BJ8
Okay, you’re wanting the area behind the front seats to the bulkhead located at the front of the rear seats?
Patrick67BJ8
Correct, I can’t seem to figure how the carpet lays and I am nervous to cut anything. Thx
Here's some the original BJ8 carpet photos and photos of my BJ8. The Radius Arm boxes do not apply to your Healey.
Just remember to error on excess material when trimming because you can always trim more off if needed.. Save all your cut off pieces! Carpet goes under the rear quarter panels.
I fitted and chalked and retested and retested before I cut. Always good to have you rear quarter panels handy for trial fitting!
Take your time.
Patrick67BJ8
No, I am putting Dynamat Extreme down and then the padding that Heritage supplies with their Wilton Wool.
Heritage supplied me with thick jute padding. You received something different than that? Also, are you going to use the original snaps to hold the trans and floor carpets in place?
P
PeterB
I don't believe mine is jute, it doesn't have that web backing and its not that thick. The only pieces that came with the kit go in the toe box area and under the floor. My original snaps were gone when the fiberglass on the transmission tunnel got redone only the holes remain so I have to use the ones that come with the kit.
Patrick67BJ8
Can you post photos of it?
maxwedge5281 1963 bj7 carpet install and mirrors Austin Healey 3
5 WTB: BJ7 Squab Austin Healey 13
5 BJ7 Boot Rust-Through Austin Healey 13
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
R New Hood for BJ7 Austin Healey 3
chicken BJ7 Chrome Trim Austin Healey 15
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
R BJ7 Rear Axle Maintenance Austin Healey 5
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
R Changing BJ7 Differential Ratio Austin Healey 10
X Trouble shooting trafficator - 1963 BJ7 Jaguar 9
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
chicken BJ7 Door Fit Austin Healey 27
T Wanted BJ7 parts needed Austin Healey Classifieds 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
D BJ7 Clutch Austin Healey 6
R BJ7 Back Seat-Rest Austin Healey 1
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
HealeyRick BJ7 Side Window Alignment Austin Healey 31
B BJ7 Interior Finishing Details Austin Healey 2
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
chicken BJ7 Door Seal Austin Healey 5
chicken BJ7 Rear Quarter Panels Austin Healey 6
B BJ7 Boot Trim Austin Healey 7
T Early BJ7 Vent Window Seal Austin Healey 2
D BJ7 Underdash Trim Austin Healey 9
G Steering Arm Installation Recommendations - BJ7 Austin Healey 2
D BJ7 Rear rail trim Austin Healey 0
D BJ7 Hood frame mounting plate Austin Healey 7
D Wanted BJ7/8 front grill top cowl Austin Healey Classifieds 4
BLong63AH BJ7 Hard Fuel Lines Austin Healey 20
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
T Installing Garmin GPS in a BJ7 Austin Healey 19
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
P BJ7 Upholstery Austin Healey 1
B BJ7 back end rebuild Austin Healey 1
Marvin Gruber BJ7 door panels Austin Healey 4
Marvin Gruber BJ7 Top Installation Austin Healey 1
B Rear shroud connection to the floor pan on a BJ7 Austin Healey 21
P BJ7 HS6 Carb Baseline Setting Austin Healey 10
Marvin Gruber BJ7 tach cable location. Austin Healey 3
T Toyota 6 cylinder eng & trans in a BJ7 Austin Healey 0
BJ8Healeys BJ7/BJ8 Exhaust Systems Austin Healey 24
W For Sale Hardtop for BJ7/BJ8 on BaT : No Reserve Austin Healey Classifieds 2
