TR6 Body Jig
Got_All_4
Anyone have plans for a jig to hold and work on the body tub while the frame is being rebuilt. Seen on at a body shop the other day that the owner built for his VW Bug. Built out of 4x4 and 2x4s.
M_Pied_Lourd
Have you seen my version of the wooden rotisserie that I am using on my TR250 project? It has worked out quite well. I used this in conjunction with steel reinforced door openings and cross bracing.
Let me know and I can post a video for you to take a look at if you are interested.
Cheers
Tush
M_Pied_Lourd
Here you go. Let me know if you are interested and I'll post a link to the original plans that we modified slightly.
https://youtu.be/KiIT37D2HD8
Cheers
Tush
Got_All_4
Got_All_4
I actually did see that some time ago. Pretty nifty! Sure send me the plans and I'll consider it. Limited space in my "working" garage.
M_Pied_Lourd
Here are the original plans posted on the Moss Motors website. Mine are a slightly modified version and I also decided to double the thickness of the plywood to make the bucks more sturdy.
https://www.mossmotoring.com/diy-rotisserie/
Cheers
Tush
Scot1966
image.jpgI made basically the same a Tush. Worked great - I could flip it by myself.
Scot1966
Dollies on the bottom are next level genius. I would have drug it around my garage and drive for months before that occurred to me.
Oh yes, I forgot to mention I added those ! They came in handy, with swivels on the front - as I wheeled it in and out of the garage countless times for sand blasting.
Gliderman8
Here are the two jigs I made when restoring my 6 a couple of years ago. One is the rotisserie and the other jig was very useful in moving the body around; the wheels were most helpful .
Got_All_4
Got_All_4
Here I am almost a year later and that tells you how far behind I am on this project. Imagine that! But does anyone have a copy of the plans for the wooden rotisserie as the Moss link doesn't work any more? Planning to get the body off the frame soon.
Got_All_4
Got_All_4
Ok got my 4 basic boards cut out. Did anyone compensate for the angle of the B post or just let it ride? Thinking of cutting out some spacers to make it square to the body and floor.
I also don't see how the front board is attached to the 2x4 that is attached to the A post. I bought 4 lag bolts and was going to go into the sides of the 2x4s.
Got_All_4
Got_All_4
Thanks all we did it! Didn't try to flip it but proably Monday. Got to clean out the other garage then flip it on it's side and be ther till the frame is done. Going to start another tread as I found more stuff.
T For Sale Free - Body Jig for TR3/TR3A Triumph Classifieds 6
J Can a TF engine be installed in a TD body? MG 7
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
Got_All_4 TR6 Seal To Body Mounting Bracket Welded? Triumph 7
K TR6 Goodparts Trail arm kits mounting just to the frame( no body) and shims? Triumph 9
Editor_Reid V-12 E-Type Body Number Location Jaguar 3
5 MGA Body and Chassis Separation? MG 2
Bayless How does '67 Sprite top attach to body? Spridgets 3
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
1 TR2/3/3A Best Rustproofing for inside of body. Triumph 7
K TR2/3/3A The "wide body" TR3? Triumph 6
W TR2/3/3A Interior and Body Colours Triumph 14
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
D Body/Paint Shop Recommendations Austin Healey 1
apbos TR5/TR250 TR250 rolling chassis and body for sale Triumph 3
T TR2/3/3A Question on TR3A front body mounting Triumph 6
M BJ8 Inner Body Panel Repair Austin Healey 2
T TR2/3/3A Body Tub Weight Triumph 8
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
D TRIUMPH TR6 BODY SHELL Triumph Classifieds 1
B After bead blasting the body I noticed some interesting things… Spridgets 2
S Inner Body Alignment Austin Healey 0
B Body Reassembly Austin Healey 2
S TR2/3/3A Body Mounting Bolts. Triumph 14
F TR2/3/3A front body mounts Triumph 7
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
Csarneson Body panel assembly order? Austin Healey 6
J Wanted WTB Triumph TR6 Body/ Rolling Chassis Triumph Classifieds 0
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
nichola TR6 Recommendation for tail lamp to body gasket Triumph 16
X Production year based on body number ? TVR 3
TRclassic3 TR2/3/3A Body leans to right side Triumph 10
S For Sale Austin Healey Sprite and MG Midget Factory Body Parts Manuals - 1958 - 1974 Austin Healey Classifieds 0
J For Sale La Dawri 'Del Mar' fiberglass body for TR-2 thru TR-6 Other British Classifieds 1
T For Sale MGB Pull Handle Tub Body Shell for sale MG Classifieds 0
BJ8Healeys Body Parts Code Austin Healey 5
BOBBYR Body Panel measurements and angles Austin Healey 6
S TR2/3/3A Frame off vs. body on restoration Triumph 21
B Longbridge 100-6 Windshield Posts - Body Color or Silver? Austin Healey 16
A Recommendations for body repair near NYC Restoration & Tools 2
H GT6 Replacement body panels Triumph 4
Jim_Stevens TR2/3/3A Rear fender stays: black or body color? Triumph 8
J TR2/3/3A Body Restoration - Inner Sill Replacement Triumph 38
J TR2/3/3A Body Mounting Strip Adhesive Triumph 10
R TR6 Body Parts Source, Upper Midwest Triumph 6
2 Wanted SU-h6 Carb. BODY ONLY needed, badly worn. for TR3A Triumph Classifieds 5
