Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
Thread: Over drive
  1. #21
    Join Date
    Sep 2015
    Location
    Michigan USA
    Posts
    94
    Thanks Thanks Given
    Thanks Thanks Received
    1
    Thanked in
    1 Post
    Re: Over drive
    Quote Originally Posted by CJD View Post
    Here is a walkthrough an A overdrive, including testing at the end. Afraid photobucket is holding the pictures hostage again, but select them and they’ll link you to better versions.
    No pics?
    60 TR3A TS66043
  2. #22
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    2,580
    Thanks Thanks Given
    12
    35
    Thanked in
    Re: Over drive
    Getting the parts together for the OD install.
    David
    TR3A TS75524L
  3. #23
    Join Date
    Aug 2018
    Location
    Durham , England
    Posts
    28
    Thanks Thanks Given
    Thanked in
    Re: Over drive
    Hi , in order lookng throught the swithch holes , from first to 4th , then reverse , dose this all look correct ?
  4. #24
    Join Date
    Aug 2018
    Location
    Durham , England
    Posts
    28
    Thanks Thanks Given
    Thanked in
    Re: Over drive
    With pics
    1st ,2nd,3rd , 4th , reverse , first looks a little bit too far Forward ?
    My worry is the switches were removed and pluged , i removed the brass plug / only gunk no bits of metal
  5. #25
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Arlington, TX, USA
    Posts
    5,277
    Thanks Thanks Given
    6
    26
    Thanked in
    Re: Over drive
    They look good to me. You use the copper washers to set the height of the switches so they engage as the gear is reached.
    John
    1955 TR2
  6. #26
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    19,243
    Thanks Thanks Given
    7
    104
    Thanked in
    Re: Over drive
    Note that the OD is only enabled in 2nd, 3rd & 4th. The reverse position is used for a reversing light (when fitted, not a common option from what I've seen), and I don't know of anything that is enabled in 1st gear.
    Randall
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
